Force due to two thin charged rods acting on each other
The discussion revolves around the interaction between two thin rods with uniform linear charge distributions, positioned along the x-axis and separated by a distance. Participants are examining the electric field produced by one rod and its effect on the other rod, with a focus on the mathematical formulation of the problem.
  • Mathematical reasoning, Assumption checking, Problem interpretation
  • Participants are exploring the calculation of the electric field due to one rod at various points along the second rod. There are attempts to set up integrals to find the force acting on the second rod, with some questioning the validity of the integration limits and the treatment of constants versus variables.
The discussion is ongoing, with participants providing insights into the setup of the integrals and the need for multiple integration stages. Some guidance has been offered regarding the correct interpretation of the variables involved, but there is no explicit consensus on the correct approach yet.
Participants are discussing the implications of treating certain variables as constants and the need for clarity in the integration process. There is also a mention of seeking additional resources for similar problems, indicating a desire for further practice in this area.
Vriska
I have 2 thin rods of length L in the axial plane(x axis), they're of the same uniform linear charge distribution and are separated by a distance a .
$$E = \frac{kq} {R^2}$$
$$F = qE$$
[/B]
Let 0 be one at one end of the two rod systems such that the first rod terminate at L and the other rod begins at L+ a.
Then field E due to first rod at some point a =
$$\int \frac{\lambda k dx}{(L + a - x)^2} $$ evaluated from x = 0 to x = L. This is $$\frac{L}{a(L+a)}$$. Now I find the force on the second charge $$ dF = E'(x) dq$$ we note here that E'(x) = E(a +x) integrating this from 0 to L. gives you the wrong answer : (
Ps. Where can I find more of these infinitismal problems for practice?
a is not some arbitrary point. Your integrand appears to be the field at the start of the second rod due to the first rod, i.e. its field at L+a.
You need the field due to the first rod at an arbitrary point within the second rod.
It's the field at the start of the second rod but I'm increasing the distance a by some dx and summing it till 2L+a. Why isn't it the same as an arbitrary point when I can increase it like this?
Ps. Would you also know where I can find more of these problems? Or perhaps what these are even called?
Not that I can see. You increased x by dx, which is valid, but a is a constant, so you cannot increase that. Increase in a would be by da, and I only see one integration stage.
To get the force on the second rod, you need to find the force on each part of the rod. There will be two integration stages.
Consider an element dx at x from the start of the first rod and the field it generates at y from the start of the second rod.
But that's just adding a + y in the denominator of the integral, it's equivalent to E'(x) > E(x+a). I'm getting the same result. After looking at the answer in my book I notice it has $$ log(\frac{[L]^2}{[L]^3}) $$ term. I think exponentials do not accept dimensional arguments. Am I right in my assessment?
Also please tell me what these problems are called if you know.
Yes, for the first integral. But then you have a second integral to do.
Please post the detailed steps.
Field due to the first rod on an infinitesimal line element at a point ##(x',0)## will be
$$E(x') = \int_0^{L} \frac{k\lambda dx}{(x'-x)^2}$$
Force on the second rod due to the first one will be
$$F = \int_{L+a}^{2L+a} \lambda E(x') dx'$$
