Force exerted over a small time and big time frame
  • Level: High School
  • Thread starter Thread starter Howlin
    Force Frame Time
6 replies · 2K views · last reply
Howlin
Hi
Why is it that if you hit an object fast it requires less force to break it than if you hit the object slow and applied pressure to it?
So you are saying if I hit a block of wood or glass really fast, it takes the same force to break it than if i use a force press and it slowly applies force to the block of wood or glass?
russ_watters said:
No, he said HIGHER.
However, it may take less impulse (force times time).
But why would it be higher, shouldn't it be just the same force required to break the boards or glass, no matter if it is hit fast or slow?
When you apply a force, the object moves - even when holding it rigidly, it bends. The faster you apply the force, the more of the force that is absorbed by the acceleration of the object.
The peak contact force is higher not the force required to break .
