How Can You Calculate the Force of Impact Without Knowing All Variables?
To calculate the force of impact when a ball hits the ground, knowing the mass and speed just before impact is essential. The formula used is Force = (mass of the ball) x (speed of the ball) / (time of contact with the ground). However, determining the time of contact is challenging and can vary based on factors like the coefficient of restitution and the deformation of both the ball and the ground. Without precise values for these variables, any calculation will only yield a rough estimate. Accurate impact force calculations require careful consideration of multiple factors influencing the impact event.
Mike123mike
I have a scenario which is simply a ball hits the ground from above i know the mass of the ball and the speed in mph of the ball just before it hits the ground. No other variables are known, I need to know the force it hits the ground.
What is the best way to calculate it? I had thought F = m x a, but to calculate the acceleration I would need a distance?
Obviously I'm not a physics person and any help would be greatly appreciated.
You also need to know the length of time that the ball is in contact with the ground. The formula for the force exerted is:
Force = (mass of the ball) x (speed of the ball)/(time the ball is in contact with the ground)
In order that the force is measured in Newtons you must use the following units:
mass: kilograms
speed: metres/second
time: seconds
Thanks for that dave I don't suppose you can assist in calculating the time it is in contact with the ground as I suppose that time would vary depending on the speed too?
Impacts are tricky to just guess at. You'd have to make an educated guesstimate bases on Coefficient of restiution, deformation of ball and ground.
Even then you are only coming up with a very rough average to the impact event.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 20 ·
  • · Replies 26 ·
9K
  • · Replies 35 ·
  • · Replies 19 ·
