brotherbobby
- 750
- 169
- Homework Statement
- The upper edge of a gate in a dam runs along the water surface. The gate is 2.00 m high and 4.00 m wide and is hinged along a hor izontal line through its center as shown in the diagram below. Calculate the torque about the hinge arising from the force due to the water.
- Relevant Equations
- 1. Pressure due to a liquid at a depth ##d## : ##P=\rho gd##
2. Force as a result of pressure ##P## : ##F=PA##, where ##A## is the area of the surface. Here the force ##F## is constant at all points on the surface.
3. Torque arising due to force about an origin : ##\tau = Fx## where ##x## is the distance of the point where the force acts from the origin.
Attempt : The crux of this problem lies in the fact that the pressure of water against the gate will vary along its depth ##h## as ##\rho gh##. This makes the use of calculus inevitable. Before I proceed further, I'd like to draw an image of how the gate looks when viewed from one side and outside the dam, as shown below. Note that the bridge is hinged along the line OP. I suppose I have to calculate the torques on each half separately.
(a) The top half : Let's imagine a thin layer of water of thickness ##dx## acting at a distance ##x## from the hinge (shown in light blue). The pressure on the gate due to this layer ##P = \rho g\left(\frac{h}{2}-x\right)##, noticing that the layer is at a depth of ##h/2 - x## from the top. The (infinitesimal) force on this layer : ##dF = \rho g\left(\frac{h}{2}-x\right)bdx##, since the area of this layer is ##bdx##. The torque due to this layer about the "midrib" OP is ##d\tau=\rho g\left(\frac{h}{2}-x\right)bxdx##, as the layer is distant ##x## from the midrib. Hence the total torque due to water in the upper half above the gate : $$\tau_{\text{up}}= \rho g\int_0^{h/2} \left(\frac{h}{2}-x\right)bxdx=\dfrac{\rho gbh^3}{48}\; \text{(agrees with book answer, hence details suppressed)}$$
(b) Bottom half : (Now here I run into trouble). Proceeding as (a) above, we imagine a thin layer of water of thickness ##dx## acting at a distance ##x## from the hinge (shown in light blue). The pressure on the gate due to this layer ##P = \rho g\left(\frac{h}{2}+x\right)##, noticing that the layer is at a depth of ##h/2 + x## from the top. The (infinitesimal) force on this layer : ##dF = \rho g\left(\frac{h}{2}+x\right)bdx##, since the area of this layer is ##bdx##. The torque due to this layer about the "midrib" OP is ##d\tau=\rho g\left(\frac{h}{2}+x\right)bxdx##, as the layer is distant ##x## from the midrib. Hence the total torque due to water in the upper half above the gate : $$\tau_{\text{down}}= \rho g\int_{h/2}^{h} \left(\frac{h}{2}+x\right)bxdx=\rho gb\left[\frac{hx^2}{4}+\frac{x^3}{3}\right]_{h/2}^{h}= \rho gb\left[\frac{h^3}{4}+\frac{h^3}{3}-\frac{h^3}{16}-\frac{h^3}{24}\right] = \frac{23}{48} \rho gbh^3$$ We can put values later for calculation, but the second answer for ##\tau_{\text{down}}## does not match with that of the book.
The issue : The book does the second integral also from 0 to ##h/2## (like the first one for ##\tau_{\text{up}}##) rather than from ##h/2\; \text{to}\; h## , as I have done. It ends up with the result ##\frac{5}{48}\rho gbh^3##. My reasoning is that the gate height (or depth) be taken as a whole, even when considering each torque separately.
Request : A hint or a suggestion as to integral limits would be helpful.
