Force problem What is the electric force on q3 due to the other 2 charges?
The problem involves calculating the electric force on a point charge (q3) due to two other point charges (q1 and q2) arranged in a right triangle. The charges are given specific values, and the task is to determine both the magnitude and direction of the force acting on q3.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the need to calculate the x and y components of the forces acting on q3 due to q1 and q2. There are attempts to convert between polar and rectangular forms of the forces. Questions arise regarding the signs of the components based on the nature of the charges involved.
Some participants have provided guidance on converting forces from polar to rectangular form and emphasized the importance of correctly determining the signs of the components based on the repulsive nature of the forces between like charges. There is ongoing exploration of how to accurately represent the forces and their components.
Participants express uncertainty about terms like "polar form" and "rectangular form," indicating a potential gap in understanding foundational concepts. The discussion is framed within the constraints of an introductory physics context, with a deadline for submission looming.
Ammora
Three point charges are fixed in place in the right triangle shown below, in which q1 = 0.71 µC and q2 = -0.67 µC. What is the electric force on the +1.0-µC (let's call this q3) charge due to the other two charges?
image: http://www.webassign.net/grr/p16-15alt.gif
magnitude ____ N
direction ______°, measured counterclockwise from the +x-axis
kq/r^2
The only thing I don't know how to do is calculate the x and y components of the charge on q3 due to q1.
Here's what I did:
First I found the missing side, 6 cm. Then I converted all the cm to m by multiplying it by .1 m and then I converted all the uC to C by multiplying it by X10^-6.
q1: Fx= k(q1)(q3)/r^2
= 8.99e9 (0.71e-6) (1.0e-6)/(0.10)^2 * 6/10
Fy=k(q1)(q3)/r^2
= 8.99e9 (0.71e-6) (1.0e-6)/(0.10)^2 * 8/10
q2: Fx=k(q2)(q3)/r^2
=8.99e9 (-0.67e-6) (1.0e-6)/(0.10)^2
Total force= Fx added together. And then sqrt. (Fx^2 + Fy^2)
As for the direction, tan theta= (Fy/Fx) and then add 180 to it?
Please help me, it's due tonight, thank you so much in advance.
magnitude ____ N
kq/r^2
Here's what I did:
Fy=k(q1)(q3)/r^2
Welcome to the PF.
You should convert the polar form of the vectors to rectangular form, add the forces in rectangular form, and then convert back to polar form. Otherwise, it's too easy to make mistakes.
The polar --> rectangular conversion for the force due to q2 is easy, since all of the force is in the x direction, right? What about the conversion for the force due to q2? Can you show us the x and y components of that force? And then add the forces component-wise, and convert back to the polar answer format that they are asking for...
Welcome to the PF.
Thank you so much, this forum is awesome, you replied so quick!
I don't know what polar or rectangular form mean, I'm sorry, I'm in Intro physics.
I think the x-component of the force q2 is (0.71e-6 cos 30) and the y-component is (0.71e-6 sin 30)?
Can you please let me know if I'm on the right track?
Good, except watch your signs. q1 and q3 are both +, so the force is repulsive or attractive? And given the answer to that, you need to call the component of the force in the + direction positive if it points in the direction of the + x axis, and negative it if points in the direction of the - x axis. And the same thing for the y component of the force.
Once you have the x and y components of the forces (making sure the signs are right), add the x components to get the resultant x force, and add the y components. Then covert back to the polar form that the question asks for.
Since they're both +, the force is repulsive.
So I have:
q2: Fx= - k(0.71e-6)(1e-6)/(0.71e-6 cos30)^2
Fy= - k(0.71e-6)(1e-6)/(0.71e-6 sin30)^2
(both components are negative, because the force points in the negative x direction, since they're repulsive to the positive charge of q3.)
q3: Fx= k(-0.67e-6)(1e-6)/(0.6)^2
So, Fx= 532160742267 + -0.0167313889 = 5.32160742e11
Fy= -1.29705876e10
What does "polar form" mean?
So I have:
Fy= -1.29705876e10
Sorry, Q2 is in line with Q3 on the x-axis, so I don't understand how you have x and y components to that force. I could be spacing something, though.
Polar/Rectangular component conversions:
http://en.wikipedia.org/wiki/Polar_coordinate_system
10K
10K
