Understanding Net Force and Normal Force in a Frictional System
  • Thread starter Thread starter muna580
    Forces
The discussion focuses on calculating net force and normal force in a frictional system involving two blocks. The net force is defined as F - f = (m1 + m2)a, where 'F' represents the applied force, 'f' is the frictional force, and 'a' is the acceleration. The normal force (Fn) is calculated using the formula Fn = mg*μ, resulting in a value of 9.87 N for the larger block. The frictional force between the two blocks must balance the weight of the smaller block, leading to further calculations for the normal force and acceleration.
  • Understanding of Newton's laws of motion, particularly Newton's third law.
  • Familiarity with the concepts of net force and frictional force.
  • Basic knowledge of calculating normal force in physics.
  • Ability to perform calculations involving mass, gravitational force, and coefficients of friction.
  • Learn how to derive the equations of motion for multiple bodies in contact.
  • Study the concept of friction coefficients and their impact on normal force calculations.
  • Explore free body diagrams (FBD) to visualize forces acting on objects.
  • Investigate the application of Newton's second law in complex systems involving multiple forces.
Students studying physics, particularly those focusing on mechanics, as well as educators and anyone interested in understanding the dynamics of frictional systems.
muna580
http://img255.imageshack.us/img255/9655/untitled1vq1.jpg
Okay, so I have no idea how to do this problem. Well first of all, the net force of the whole system is F - f = (m1 + m2)a. I have no idea what a is. Also, since friction is involved we need to find the normal force. How do I find the normal force?
wow that's a wild and wooly problem. first, word normal here is in the perpendicular sense. so when two bodies are in contact, its the reactive force (Newtons third law) in response to our weight on the floor which keeps us from falling thru it. The floor pushes back. Curiously common sense fails us here as frictional forces have nothing to do with surface area, only the magnitude of the force keeping them in contact times that coefficient, mu.
So here we have two normal forces at right angles.
Lets start with the easy half, the normal force between the big block and its supporting surface. Thats easy, Fn=mg*mu=9.8*4.2*0.24= 9.87 (weight times friction)
Now the other half of the problem is less intuitive. But in principle no different, the opposite of the force of the big block on small block.
(Here I am a bit fuzzy, do we have to worry about both blocks or just the big one.) No worries, If wrong someone will come to our rescue.
Lets take the case where we only concern ourselves with the big block;
now we know that in order for the smaller block not to fall, the force impressed on it must be equal to .7kg*9.8*.38=2.61N
the Sum of forces=ma must then be 2.61
So Fx-Fn=2.61 where Fn=9.87
Adding the two gives 12.49. May be dead wrong, but hope its of some help. Seems like a very complex problem for someone with no idea how to compute Normal force.:rolleyes:
Oh I get it now. Thanks a lot. I have to slove for normal forces on both blocks. Thanks a lot.
NP. let me know if the answer was close. First time I seen one like that.
If you look at a FBD of the small block, the friction force between the 2 blocks must be balanced by the small block's weight, and therefore equal to 0.7g Newtons. You should now be able to calculate the Normal force (N) between the blocks in the positive x direction, and then use Newton 2 to solve for the acceleration.
  • · Replies 17 ·
  • · Replies 20 ·
