Forces in equilibrium. Tension, ring on string.
The discussion revolves around calculating the horizontal force P acting on a ring of weight 2N, which is suspended on a string fixed at two points A and B. The ring is in equilibrium with the string inclined at angles of 40° and 20° to the vertical. Participants utilized vector resolution methods to derive the equations of equilibrium, ultimately determining two possible values for P: approximately 0.35N and 1.15N. The confusion regarding the two values arises from the interpretation of the angles and the direction of the tension in the string.
  • Understanding of vector resolution in physics
  • Knowledge of equilibrium conditions in mechanics
  • Familiarity with trigonometric functions, specifically sine and cosine
  • Basic grasp of tension in strings and forces acting on objects
  • Study the principles of static equilibrium in mechanics
  • Learn how to resolve forces into components using trigonometric identities
  • Explore the concept of tension in continuous strings and its implications
  • Investigate similar problems involving forces and angles to reinforce understanding
Students studying physics, particularly those focusing on mechanics, as well as educators and tutors looking for examples of equilibrium problems involving tension and angles.
afrocod
A ring of weight 2N is threaded on to a string whose ends are fixed to two points A and B in a horizontal line. The ring is pulled aside by a horizontal force P Newton parallel to AB. When the ring is in equilibrium the two sections of the string are inclined to the vertical at angles of 40° and 20°. Find the two possible values of P.
The sum of all the forces = 0 and because it says the 2 possible values of P, I'm guessing the Cosine rule is relevant.
I tried to separate out horizontal and perpendicular vectors like : X = P + T1Sin20 - T2sin40 = 0 and Y = -2 + T1Cos20 + T2Cos40 = 0. and it doesn't work out. I'm also thinking the tension in both segments = 2N
I've followed lots of different tactics out but it just never comes out right and it's draining my will to live. I'm almost certain the problem is, I'm just not able to see what are the relevant forces in the problem, I'm having a hard time making a mental model of it.
Also I'm self studying this material, so I've got no one else to turn to. Please help me out.
hi afrocod! :smile:
(try using the X2 button just above the Reply box :wink:)
afrocod said:
]I tried to separate out horizontal and perpendicular vectors like : X = P + T1Sin20 - T2sin40 = 0 and Y = -2 + T1Cos20 + T2Cos40 = 0.
Well, that should work.
(Don't forget that it's a continuous string, so the tension is the same all the way along)
If it still doesn't work, show us how far you get. :smile:
So I set X = Y because they're both = 0
P + T1Sin20 - T2Sin40 = -2 + T1Cos20 + T2Cos40
P = T1Cos20 - T1Sin20 + T2Cos40 + T2Sin40 - 2
P = T1(Cos20 - Sin20) + T2(Cos40 + Sin40) - 2
P = 0.6T1 + 1.41T2 - 2
But since you say then tension is the same for the whole string then T1 = T2
P = 2.01T - 2
And I'm guessing the tension is equal to the weight of the ring = 2N
So, P = 2.02
Which is not the right answer. What baffles me more is why is there 2 values for P?
sorry, afrocod, but this strategy is crazy
you had two equations, with two unknowns (P and T)
you've just reduced it to one equation, with two unknowns! :rolleyes:
that's not solvable!
solve Y = 0 first (for T), then use that solution in X = 0 …
what do you get? :smile:
It all seems like perfect logic till someone calls you crazy.
Y = 0.94T + 0.64T = 2
T = 1.27
X = P + (1.27)Sin20 - (1.27) Sin40 = 0
P = 0.39N
Which is close enough to one of the answers (0.35N), if I took a few more decimal places I probably would have got that.
But now I'm still left with the question what is the other possible value for P, and why does it even have two values?
hmm :rolleyes:
what makes you think that the two strings have to be sloping in opposite directions? :wink:
All I can think of is that when P = 0 but the other answer is actually 1.15N
you're reading too much into the question …
read it again, carefully …
how many different ways are there of drawing this? :smile:
Oh, I see... facepalm... Sloping the same direction.
Thank you for all your patient help Tim.
Your the man.
I am having problems with the same question can you explain a bit more on how you reach the answer?
welcome to pf!
hi sareba! welcome to pf! :wink:
show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
I came up with the exact same strategy i.e. resolving the firces into components but you guys lost me on afrocod's third post where he seems to be using T cos 20 + T cos 40 = 2 but cos 40 = .766 not .64 which is cos 50
EDIT: Oh i put in cos 40 and it gave .35 the correct answer... Thanks a lot tim for the quick reply!
But still how do i get to the other answer? I mean i understand what you mean by same slopes. We have toadd the forces instead of subtracting them but that does not give the right answer...
hi sareba! :smile:
it should :confused:
show us your equation :smile:
Ah... Its all good now there was a little mix up i nthe equation but I figured it out. Thanks a lot again TIM! I don't know how you do it but you be tha man!
  • · Replies 103 ·
13K
