How Do You Calculate the Force to Separate Two Hemispheres?
  • Thread starter Thread starter castusalbuscor
To calculate the force required to separate two uniform rigid hemispheres, one must consider the gravitational attraction between them. The force can be derived using an integral that accounts for the mass distribution and geometry of the hemispheres. The final solution for the force is given by F = (3GM²)/(4a²), where M is the mass of each hemisphere and a is their radius. The discussion emphasizes the importance of understanding the gravitational forces at play and suggests using density and spherical coordinates for the calculations. This approach leads to a comprehensive understanding of the mechanics involved in separating the hemispheres.
castusalbuscor
[SOLVED] Forece Between Two Hemispheres
I am trying to study for my classical mechanics final, and the prof hinted that this problem would be on the final.
Two uniform rigid hemispheres eachof mass M and radius a are placed in contact with each other so as to form a complete sphere. Find the forces necessary to pull the hemishperes apart
I've been mulling over it for three days now trying to figure out how to solve it.
I tried used spherical cooridnated to solve it but I am not sure where to begin.
I possibly could find the force due to a sphere of Mass 2M, but that does not help me in finding the force required to separate the hemispheres.
The back of the book gives the soloution, but that's useless to me if I can't get to it.
How would I go about to begin solving the problem?
Is the only force between them gravitational? Is that what we're overcoming here?
Yes. the solution is \frac{3M^{2}G}{4a^{2}}
So today I was bouncing some ideas off one of the smart kids in my class, and was asking for some direction.
The way he suggested I approach it was through density.
The big arse integral I had to integrate which give the required answer was:
F = \int\frac{4GM^{2}r^{3}sin\phi cos\phi d\phi d\theta dr}{4/3 \pi r^{6}}
Which gives F = \frac{3GM^{2}}{4a^{2}}
Where:
a is the radius of the hemisphere
M is the mass of the hemisphere
and r is the distance from the hemisphere
