Formal definition of work done
  • Context: High School
  • Thread starter Thread starter physicals
48 replies · 4K views
physicals
Energy is quite an ambiguous topic in physics. Considering this, I have been trying to get a formal definition for what work done really means, a definition that truly defines it not just in terms of math but also theoretically. The closest |(partial) definition for work done ive come to is "Energy is transferred when work is done against a force or resistance". This definition holds true for most cases but my biggest confusion lies in the differentiation of force and resistance. Aren't they the same thing? For example and example of resistance might be resistance, if work is done against inertia energy is transferred to an objects kinetic energy store. In this case could resistance and force be considered as the same thing.
Reply
  • Sad
The simplest way to describe things is that work done is the amount of energy that gets transferred in some way. Total energy is like a set of individual bank balances. And work done is like transfers from one account to another.
Resistance might mean electrical resistance, as opposed to mechanical friction. Athough, it all boils down eventually to the fundamental forces ot nature.
I do not consider the notion of "resistance" to be important at all. It is enough that a force exists.
There are at least three general notions of "work". These are the definitions that I use:
Mechanical work:
The dot product of an applied force and the displacement of the material of the contacted object at the point of application.
If the motion or the force are not constant, one may have to evaluate an integral.
If the area of application is extended, one may have to evaluate an integral.
Center of mass work:
The dot product of an applied force and the displacement of the center of mass of the contacted object.
If the motion is not in a straight line under a constant force, one may have to evaluate an integral.
Generalized work:
The amount of non-thermal energy transferred into a system across an interface.
Reply
Those are the three I focus on also. It is important to know that the first is included in the third, but the second is not. The second is also called “net work” by many authors.
Words have more than one meaning.
"Work done" is itself ambiguous if one does not specify who is doing the work and on whom this work done. The sign of this work is also important.
Let's consider a simple illustration of a block of mass ##m## initially moving with initial speed ##v_0## on a horizontal frictionless surface. At some point in time a hand exerts constant force ##F## in the same direction as the block's velocity. The block is displaced by ##\Delta x## under constant acceleration ##a## and reaches final speed ##v_{\!f}## at which point the hand is removed.
With this information we write the kinematic equation relating the acceleration, displacement and speeds at the beginning and end of the displacement. $$\begin{align} & 2a\Delta x=v_{\!f}^2-v_0^2. \end{align}$$Note that we can do this without describing how or why the block changes its speed. To do that we bring in Newton's laws.
  1. The first law tells us that since the block accelerates, there must be an unbalanced external force acting on the block. We identify the net force as the force ##F## exerted by the hand.
  2. The second law tells us that the external force exerted by the hand is equal to the mass of the block times the acceleration ##F=ma.## This is the link between what is outside the system (pushing hand) and what happens to the motion of the system (change of velocity.)
  3. The third law tells us that the block exerts force of magnitude ##F## on the hand but in the opposite direction. This force is always there and can be viewed as the "resistance" that you mentioned in post #1.
Now for some math. We multiply both sides of equation (1) by ##\frac{1}{2}m## to get $$\begin{align}
& ma\Delta x=\frac{1}{2}m\left(v_{\!f}^2-v_0^2\right)\nonumber\\
& F\Delta x=\frac{1}{2}m\left(v_{\!f}^2-v_0^2\right).
\end{align}$$The left side in equation (2) is, by definition, the work done on the block by the hand. It is positive work because the force and the displacement are in the same direction as stated in the problem. It follows that the right side of equation (2), the change in kinetic energy, is also positive. This makes eminent sense, if you push something in the same direction that it is already moving, you increase its speed.
Note that if the hand pushes in a direction opposite to the displacement of the block, the left side of equation (2) will be negative which means that the kinetic energy change will also be negative.
Force ##F## enables the energy transfer across the boundaries separating the hand from the block. The amount of energy transferred is the work done by the hand on the block. To extend @PeroK's analogy, the work that the hand does on the block in Joules is like money transferred from the hand's bank account to the block's bank account and could be positive or negative. Force ##F## is analogous to the bank clerk who mediates the transfer from one account to the other. If the bank charges a fee every time there is a transfer, that is analogous to a dissipative force, e.g. friction or air resistance, that reduces the amount transferred no matter which way it moves.
Resistance is completely irrelevant here.
Work is transfer of energy.
Just like:
Impulse is transfer of momentum.
Or, specifically for mechanical work:
Work is force applied over a distance.
Just like:
Impulse is force applied for a time.
Reply
If you mean electrical resistance, yes it is completely irrelevant.
Here, I think that it is to be interpreted here as "resistance to acceleration" i.e. the reaction force exerted by the system on the external agent that applies the force. It's always there as long as the system has inertial mass. That's what I tried to illustrate in post #5.
I interpreted it as resistance to motion, like drag. Which just goes to show ambiguous the term and any definition based on it is.
kuruman said:
... the reaction force exerted by the system on the external agent that applies the force. It's always there as long as the system has inertial mass.
I disagree. We use massless elements in idealized scenarios all the time. And they obey Newton's 3rd Law just fine. The only condition is that the net force and net torque on them must be zero all the time. They can also have work done on them.
Can you provide an example of such an idealized scenario of a massless particle on which work is done? Does it accelerate as a result? If "yes", how can it be since the net force and torque "must be zero all the time"? If "no", what happens to the work that crosses the system boundary?
It is easy to imagine a massless mathematical point on a massive object and talk about the acceleration of the massive object at that point. It is not easy, at least for me, to imagine a massless element that can be considered the "system" and obeys Newton's laws.
An example would be a hand pulling a cart via a massless rope. Positive work is done on the rope by the hand and negative work is done on the rope by the cart.
Another example would be a massless spring in the same scenario. In that case the positive work done by the hand may not equal the negative work done by the cart.
Reply
I understand that, as an approximation of a real situation, we can ignore the mass of the rope and consider essentially an action-at-a-distance force from the hand to the rope. However, the approximation that the rope is massless does not refute my argument. I wrote
In terms of this example, the reaction to the action of the hand is exerted by the cart on the hand via the massless rope. This reaction can be construed as a "resistance" force to the pulling force of the hand. The rope in-between is immaterial, literally and figuratively.
In the case of interaction forces, the "reaction force" is automatically there by Newton's third law. We need not mention inertial mass. Yes, this reaction force is always there. For interaction forces.
In the case of pseudo-forces such as the centrifugal force, there is no reaction force. Nor is there any "resistance to acceleration". Yet pseudo-forces do work.
That's a short cut you can take, but don't have to. You can just as well consider the work done on/by the massless rope, and it works just fine
The massless spring makes it even clearer. It can store energy so obviously you can do work on it, since even the net work is non zero.
I wasn’t intending to either support or refute your argument. Just give an example.
Why would that be? The reaction to the force of the hand on the rope is the equal and opposite force of the rope on the hand. The reaction of the force of the rope on the cart is the equal and opposite force of the cart on the rope.
As you yourself indicated, this is an approximation to a real situation. In that real situation the forces are as I described. That doesn’t change as the mass gets arbitrarily small and then goes to zero.
Thanks @Dale @kuruman @A.T. @jbriggs444 , sorry for the confusion caused here. My definition for resistance was something like inertia, according to some sources including (Chatgpt) inertia isn't a force, so It can be called as resistance. In my original post I have noticed that my wording was quite ambiguous. To clarify, this is what I meant: Energy is transferred to the kinetic energy store of an object if work is done against its inertia (considering no friction or external forces), for example to move an object that is currently at rest "work must be done" against inertia (resistance) in order to transfer energy. In this case can inertia be considered to be a force? Or is inertia an exception to the work done definition?
Inertia is another name for mass. It's not a force. Newton's second law describes the relationship between force, mass and acceleration:
$$F = ma$$
Reply
That is just one special case. The most trivial one. You can't base the definition of a general concept like work on that.
In general the object can also pass on the energy instead of gaining kinetic energy, or store it internally as deformation. The inertia or inertial mass of the object is irrelevant then.
physicals said:
against its inertia
Just call it 'mass'.
So its agreed: Inertia or "mass" is an exception to the work done definition right?
Reply
  • Skeptical
No:
Besides, what would that even mean? You need force to accelerate a thing, and the bigger mass the bigger the force for the same acceleration. That is all that "inertia" is needed for.
No, the general definition, which doesn't mention 'inertia, or 'resistance', applies regardless if the work done goes into acceleration or not.
The definition based on inertia that you provided is simply not the general one.
This is what happens when you try to learn physics from ChatGPT!
Reply
As others have said, no.
My preferred definition is that work is the amount of non-thermal energy transferred into a system across an interface.
Mass is not an exception to that definition. And I don’t really see how it would be an exception to any other definition either.
Reply
I think we agree but are talking past each other so let me do some math to explain what I am saying with equations instead of just words. Shown on the right are two FBDs: (A) for the massive rope plus cart and (B) for just the massive rope. Eventually, we will let the mass ##m## of the rope to go to zero. The double subscript label as in ##F_{\text{HR}}## indicates the force exerted by the Hand on the Rope.
From FBD (A) we get the common acceleration $$a=\frac{F_{\text{HR}}}{M+m}.$$From FBD (B), $$F_{\text{Net}}^{(\text{rope})}=F_{\text{HR}}+(-F_{\text{CR}})=\frac{mF_{\text{HR}}}{M+m}\implies F_{\text{CR}}=\frac{MF_{\text{HR}}}{M+m}.$$In the limit ##m=0## we get ##F_{\text{CR}}=F_{\text{HR}}##. I think that we both agree so far. At this point you have argued that when the rope is massless, ##F_{\text{HR}}## does positive work whilst ##F_{\text{CR}}## does an equal amount of negative work, therefore the net work don on the rope is zero, therefore there no change in the kinetic energy of the rope.
When I said (without equations),
I meant that, in the case of a massless rope, it doesn't matter that ##F_{\text{CR}}=F_{\text{HR}}## and that the two forces do equal and opposite work on the rope. The change in a massless rope's kinetic energy is zero because, well, its mass is zero therefore its kinetic energy is always zero no matter what work is done on it.
Arguably, the length of the rope is irrelevant; it can be reduced to zero and the rope be ignored altogether without affecting the dynamics of the cart. A string with zero length and zero mass is no string at all.
It follows that the hand pulling a cart of mass ##M## through a massless rope can just as well be FBD (C) shown on the right. There is of course the reaction counterpart of the force exerted by the cart on the hand, ##F_{\text{CH}}##, which does not belong inside the FBD.
To summarize, when a massless, inextensible, string is attached to a system on one end and to a force ##F## on the other, one can always consider force ##F## applied directly on the system in the direction of the tension. That's what is implied when we say the "tension is the same at any point along the string."
Reply
All well argued and completely true.
None of this is in conflict with the fact that the mechanical work done by the hand on the end of the rope is given by the dot product of the force applied by the hand times the displacement of the rope end.
The inertial mass of the rope does not enter in. The extensibility of the rope does not enter in. The mass of whatever the rope is attached to does not enter in. If we know force and displacement, we simply compute their dot product.
We can all agree that in the case of a massless inextensible rope subject to no other forces that the work performed by the effort on the one rope end will be equal to the work performed by the other rope end on the load.
Reply
When we lift an object such that it is further away from the ground it gains gpe. Here what exactly does work? Is it the thing that lifted the object or is it gravity?
Both. The thing that lifts the object does positive work on it while the gravity does negative work on it. Here, the negative of the work done by gravity is also known as the change in potential energy of the object + Earth system.
Is this a general rule for all energy transfers that there must be both positive and negative work done?
No.
No. If the thing that does the work pushes down on the object as it falls, both works are positive.
