Formula for a geometric series with variable common ratio
3 replies · 6K views · last reply
ATroelstein
I have the following summation where a is a positive constant and can be > 1
\sum_{k=2}^{n}a^{n-k}
I am trying to find a general formula for this summation, which turns out to be a geometric series with a as the common ratio. I have worked out the following:
\sum_{k=2}^{n}a^{n-k} = \sum_{k=0}^{n-2}a^{k}
a^{0} + a^{1} + a^{2} + ... + a^{n-3} + a^{n-2}
$$Plugging this information into the geometric series summation formula where the common ratio = a, the first term is 1 and the number of terms is n-2, I get:
S_{n-2} = 1 * (\frac{1-a^{n-2}}{1-a})
After testing this formula few times, I found that it's always slightly off. I'm wondering where I went wrong when trying to determine the formula. Thanks.
Hi ATroelstein! :)
The proper formula is: $S_{n-2} = 1 \cdot \frac {1-a^{n-1}}{1-a}$
See for instance here.
You want:
$\displaystyle S_{n-2}=\frac{a^{n-1}-1}{a-1}$
Consider:
$\displaystyle S_{n-2}=\sum_{k=0}^{n-2}a^k$
Multiply through by $a$:
$\displaystyle aS_{n-2}=\sum_{k=0}^{n-2}a^{k+1}=\sum_{k=0}^{n-2}a^k-a^0+a^{n-1}=S_{n-2}+a^{n-1}-1$
$\displaystyle aS_{n-2}-S_{n-2}=a^{n-1}-1$
$\displaystyle (a-1)S_{n-2}=a^{n-1}-1$
May be that the best first step is to set... $\displaystyle \sum_{k=2}^{n} a^{n-k} = a^{n}\ \sum_{k=2}^{n} \frac{1}{a^{k}}$ (1)
Kind regards
$\chi$ $\sigma$
