To find the tangential velocity of an object in circular motion with a radius of 100 cm and a period of 0.98 seconds, use the formulas v = rw and w = 2pi/T. The term "velocity of a centripetal force" is misleading, as force is a vector and does not possess velocity. Instead, the focus should be on calculating the tangential velocity resulting from the centripetal force. The formula for centripetal force is F = (mv^2)/r, which acts radially inward.
#1
rahmatkat
Hi, can anyone please tell me the fomular for the velocity of a centripital force with the radius of 100 cm, with one revolution revolting in 0.98 seconds?
Here are the formulas you will need to solve the problem:
v = rw
w = 2pi/T
By the way, the "velocity of a centripetal force" does not have much meaning. Force is a vector; it doesn't have velocity. You might as well have asked what the mass of the force was, or the radius of the force. I think you meant to say that you are trying to find the tangential velocity of an object undergoing circular motion due to a centripetal force.
#3
rahmatkat
Thanks for you're help, anyway i have another question. What is the formula for centripital force?, our physics teacher gave us a practical to do but he forgot to give us a note on centripital force.
Kindly see the attached pdf. My attempt to solve it, is in it.
I'm wondering if my solution is right. My idea is this: At any point of time, the ball may be assumed to be at an incline which is at an angle of θ(kindly see both the pics in the pdf file). The value of θ will continuously change and so will the value of friction.
I'm not able to figure out, why my solution is wrong, if it is wrong .
TL;DR Summary: I came across this question from a Sri Lankan A-level textbook.
Question - An ice cube with a length of 10 cm is immersed in water at 0 °C. An observer observes the ice cube from the water, and it seems to be 7.75 cm long. If the refractive index of water is 4/3, find the height of the ice cube immersed in the water.
I could not understand how the apparent height of the ice cube in the water depends on the height of the ice cube immersed in the water. Does anyone have an...
