Fortran - equation of motion, astronomical units
7 replies · 2K views · last reply
SalfordPhysics
Euler method : Plot the trajectory of a body moving under the influence of the suns gravity from initial conditions x=1, y=0, vx=0, vy=1.
My trouble is figuring out my function.
d2r / dt2 = -r/r3
What I have been doing previously is breaking the function into x and y components, so for finding vx(i+1) I use Fx, as for vy and Fy.
So for this case;
Fx = -(x+0)/(SQRT(x2 + 0)3
Fy = -(0+y)/(SQRT(0 + y2)3
Is this right?
d2r / dt2 = -r/r3
So for this case;
Is this right?
I wouldn't think so. Generally, for polar coordinates, r2 = x2 + y2, thus your definitions of Fx and Fy don't make sense.
Im not here no, there is no mention on my handout but could you go on anyway? regarding polar that is
Where is the sun, at (0, 0)?
d2r / dt2 = -r/r3
Does the plain 'r' denote the magnitude of ##\vec{r}##? To be clearer, you can write it as |r|.
What does this part -- "so for finding vx(i+1) I use Fx, as for vy and Fy." -- mean?
So for this case;
Is this right?
I assume the Sun must be at (0,0) yes. And yes r = |r|.
Also, how do you do the vector notation?
Regarding your edit to the code;
I proceed as follows;
x(i+1) = x(i) + vx(i).dt
vx(i+1) = vx(i) + ax(i).dt where ax(i)=Fx i.e.; -r/|r|3
It follows as with my trajectory problem you helped with previously.
I had another question that I didn't get the quotes right, so you might have missed it.
Since I don't know what the above means, I can't comment on what you have for vx below.
# # \vec{r} # # - take out the spaces between the first and second pair of # characters.
I've solved it now I just had to go from the beginning to understand things, no need for polar.
