Comp Sci Fortran - Help with Truncated Infinite Series Calculator
The discussion revolves around creating a Fortran program to calculate the sine function using truncated infinite series. The user is struggling with uninitialized variables, specifically 'n' and 'z', which leads to incorrect outputs. They seek clarification on how to properly implement a loop that runs until the desired accuracy of 1.0E-6 is achieved, rather than relying on a fixed number of iterations. Suggestions emphasize the need to define 'n' and use the EXIT statement effectively to break the loop based on accuracy. The conversation highlights the importance of initializing variables and structuring loops correctly in Fortran programming.
dss91
I have an assignment to write a program for calculating the sine (and various other functions) using the method of truncated infinite series using DO statements. The DO statement is supposed to run until the difference between the current and last iterations are less than 1.0E-6. Saying that I am lost is an understatement. I have done some research on the internet and seem to have been able to piece together some code which makes sense to me, however I am just getting random junk out of it when I run it. Any help would be greatly appreciated! There are multiple menu options for different functions, which I have yet to start on, as I am trying to get the sine function to work correctly first.
I put a "!" in front of the IF statement on the accuracy checker to see if it would even compute the sine to 10000 terms correctly, but that doesn't even seem to work!
Code:
PROGRAM PROJECT2
IMPLICIT NONE
INTEGER::i,n
REAL::x,z,sinx,cosx
CHARACTER::choice
WRITE(*,*) 'Please enter a number x:'
READ(*,*) x
DO
WRITE(*,*) ''
WRITE(*,*) '  Iterative Function Calculator'
WRITE(*,*) '-------------------'
WRITE(*,*) '  A) SIN(x)'
WRITE(*,*) '  B) COS(x)'
WRITE(*,*) '  C) e^x'
WRITE(*,*) "  D) Lambert's W function Wo(x)"
WRITE(*,*) '  E) Enter a new x'
WRITE(*,*) '  Q) Quit'
WRITE(*,*) 'Please enter choice:'
READ(*,*) choice
IF(CHOICE .EQ. 'Q' .or. CHOICE .EQ. 'q') THEN
	EXIT
ELSE IF(CHOICE .EQ. 'A' .or. CHOICE .EQ. 'a') THEN
	DO i = 1,n
		n=1
		sinx=0.
	sinx=sinx+z
	n=n+1
	z=z+(-1)**n*x**(2*n+1)/((2*n-2)*(2*n-1))
	IF(n==10000) THEN
		EXIT
	!IF((abs(sinx-(sinx+z))) < (1.E-6)) THEN
		!EXIT
		END IF
	END DO
	WRITE(*,*) z
	!WRITE(*,'(A,F6.4,A,F6.4 )') 'SIN(',x,') = ',sinx
ELSE IF(CHOICE .EQ. 'D' .or. CHOICE .EQ. 'd') THEN
	READ(*,*) x
ENDIF
END DO
END PROGRAM
n is uninitialized in your DO i = 1, n loop, AND you are attempting to change the upper limit of your loop, n, inside the body of the loop.
Also, z is uninitialized. You have a statement sinx = sinx + z, and this is guaranteed to add garbage to a known value, which results in garbage.
Ok, I have edited my code a bit and I am now getting 0.0000 consistantly out when I compile and run. That is much better than what I had before, but I am still confused at what might be wrong.
Thanks in advance!
Code:
READ(*,*) x
!enter do loop for menu
DO
WRITE(*,*) ''
READ(*,*) choice
SELECT CASE(choice)
CASE('Q','q')
	EXIT
CASE('A','a')
	sindec=x
	sinx=0.
	DO i=1,n
	fact=1.
		DO j=1,2*i-1
		fact=fact*j
		END DO
	  IF(abs(sindec-sinx) <1.0E-6) THEN
		EXIT
	  END IF
	 sinx=sinx+sindec
	 sindec=sindec+(-1)**(i-1)*x**(2*i-1)/fact
	END DO
CASE('B','b')
	WRITE(*,'(A,F6.4,A,F6.4 )') 'COS(',X,') = ',sinx
CASE('C','c')
CASE('D','d')
CASE('E','e')
	READ(*,*) x
CASE default
	WRITE(*,*) 'Not Recognized'
END SELECT
ENDDO !end do loop for menu
END PROGRAM
Code:
CASE('A','a')
   sindec=x
   sinx=0.
   DO i=1,n <---
      fact=1.
      DO j=1,2*i-1
         fact=fact*j
      END DO
         EXIT
      END IF
      sinx=sinx+sindec
   END DO
Your outer loop runs from i = 1 to i = n. How many times will this loop run?
I would like to run it until the desired accuracy is satisfied (1.0E-6), I guess I am a bit unsure how to specify this. Should I get rid of that part completely and just let the DO loop run until the IF statement is satisfied or do I need to define n to be a certain value?
If you are going to run a counting DO loop (i.e., DO i = 1, n), you HAVE to define n. If your desired accuracy is reached, you can get out of the loop with EXIT, as you are doing. In any case, though, you always need to define starting and ending values for your counting loop.
