Fortran, reading a particular column of a matrix, allocatable
11 replies · 8K views
fluidistic
I have a program that makes a histogram from data taken in a file but it only works if the data is an array (nx1 matrix).
I've downloaded a data file which is a 159663x12 matrix but only the 8th column contains numbers I'm interested it. The other columns contain either letters and/or numbers.
So I cannot read the data file and assignate, say, a(i) to values in the first column for example because these values might not even be numbers.
What I want is something like
Code:
read(11,*) , , , , , , ,x_i, , , ,
where I don't want to read the blancked values.
I'm sure there's a way to do this, but despite reading what I could find in google it's not clear at all to me how to do.
I'll ask other questions related to allocatable probably further.
Thanks for any help.
Edit: To complicate things, some if not most columns have no values for a particular row. For example here is how the file starts:
Code:
10207538       A E M, Doshtagir                                             BAN M                            1864  0   30 0000  i
10206612       A K M, Sourab                                                BAN M                            1714  0   30 0000  i
5045886        A K, Kalshyan                                                IND M                            1943  9   15 1964
8605360        A La, Teng Hua                                               CHN F                            1915  0   30 1993  wi
5031605        A, Akshaya                                                   IND F                            2014  0   15 1994  w
5080444        A, Sohita                                                    IND F                            1447  0   30 1995  wi
5706068        A. Nashir, Mohd Khairul Nazrin                               MAS M                            1878  0   30 0000  i
10201971       A.f.m., Mahfuzul Haque                                       BAN M                            1758  0   15 0000
10202650       A.k. Azad, Akand                                             BAN M                            1692  0   30 0000  i
10210997       A.K.M. Mehfuz                                                BAN M                            2015  0   30 0000  i
24663832       Aab, Manfred                                                 GER M                            1758  0   15 1963
1701991        Aaberg, Anton                                                SWE M                            2372  0   10 1972
1513966        Aabid, Ryaad                                                 NOR M                            1698  0   15 1958
1407589        Aabling-Thomsen, Jakob                                       DEN M   FM                       2336  7   15 1985
12524670       Aadeli, Arvin                                                IRI M                            2037  5   15 0000
5072662        Aadhityaa, M                                                 IND M                            1893  0   15 1999
25034677       Aadish S                                                     IND M                            1528  0   15 1999
25088955       Aadit Bhatia                                                 IND M                            1544  0   30 2002
5086183        Aaditt, M K                                                  IND M                            1610  0   30 1996  i
25083821       Aaditya jain                                                 IND M                            1297  0   30 2000
5027942        Aaditya, Jagadeesh                                           IND M                            1811  0   15 1998
25011952       Aadityan G                                                   IND M                            1627  0   15 2001
5063485        Aadityan, N.                                                 IND M                            1758  0   15 1996
1431692        Aae, Jesper                                                  DEN M                            1881  0   30 1954
1427024        Aagaard, Gert                                                DEN M                            2049  7   15 1966
1401815        Aagaard, Jacob                                               DEN M   GM        FST            2519  0   10 1973
Here is my code:
Code:
program histogram
implicit none
real :: mean
integer :: x_i ,i  ,k
integer, dimension(0:3000) :: icount
character (5):: a,b,c,d,e,f,g,h,j,l,m
i=1
open(12,file='histchess.txt',status='old')
open(11,file='crat.txt', status='old')
icount=0
do while (i.le.159663)
read(11,*)a,b,c,d,e,f,g,x_i,h,j,l,m
icount(x_i)=icount(x_i)+1
i=i+1
end do
    do k=0,3000,1
    write(12,*)k,icount(k)
    end do
close(11)
close(12)
end program
It compiles but when I execute it, I get the error
Code:
At line 15 of file chesshistogram.f90 (unit = 11, file = 'crat.txt')
Fortran runtime error: Bad integer for item 1 in list input
real :: mean
integer i,k
integer,allocatable, dimension(:) :: x_i
character (5):: a,b,c,d,e,f,g,h,j,l,mopen(12,file='histchess.txt',status='old')
i=0
do
read(11,*,end = 200)
i=i+1
end do
200 allocate(x_i(i))
rewind(11)
do k=1,i
write(12,*)k,x_i(k)
end do
close(11)
close(12)
end programCould you try this code and let me know if it works?
Your variables a through g are 5-character arrays. The very first item you attempt to read is 10207538, which contains 8 characters. That's a problem.
I think that you will need to do list-directed input to make sure that specific items in your table go into the appropriate variables. For more information, see http://www.oc.nps.edu/~bird/oc3030_online/fortran/io/io.html or any other Fortran docs on the read statement. The section on Format Descriptors in the link I show might be helpful.
Biederman said:
real :: mean
integer i,k
i=0
do
i=i+1
end do
rewind(11)
do k=1,i
write(12,*)k,x_i(k)
end do
close(11)
close(12)
I tried it, returned a similar error that I got:
Code:
Fortran runtime error: Bad integer for item 5 in list input
Like Mark44 said, it probably has to do with the format.
Ok I will read this and try the Format statement. I don't really understand why my variables "a" through "g" are 5 character arrays.
Edit: nevermind, that's because I set it to 5 indeed. I tried several other numbers, I've had the same error (even with it's characters(9) )
I've read about format but I'm still confused.
I tried to avoid this problem by trying to remove columns 1 to 7 and 9 to 12 using awk
Code:
awk '{for(i=1;i<=NF;++i) if (i != 1 && i!=2 && i!=3 && i!=4 && i!=5 && i!=6 && i!=7 && i!=9 && i!=10 && i!=11 && i!=12) printf("%s ", $i);  printf("\n"); }' crat.txt >crat4.txt
. The new .txt file had indeed only 1 column remaining but not as I wanted. It even contained letters, i.e. elements of other columns. Here is a small part of it:
Code:
30
WF w
30
30
CM
30
2131
WF w
30
This leads me to think that Fortran won't be able to understand the columns of the .txt file either, even if I order it to read only column 8.
I guess I chose the wrong data file to download. Too complicated.
I would have the program read everything in the text file, but discard most of it, leaving only what you want.
Here are the first couple of lines of your text file:
Code:
I removed a bunch of spaces so the lines weren't so long.
You need to look at the text file to see how it is arranged. Each line seems to consist of a number of fields, some of which can be null, and most of which you don't care about. One possible solution would be to read in everything up to the number you want (1864 in the first line and 1714 in the second line) as one variable, read in the number as your second variable, and then read in everything else as your third variable.
The statements to do this would look something like this:
Code:
    read (12, 100) Str1, Number, Str2
100 format A50, I5, A30
Str1 and Str2 would be declared as character array variables, and Number would be declared as an integer variable. I am assuming that the number you want starts in column 51 and is no more than 5 digits.
Thanks a lot Mark44, I'm going to check this out really seriously as soon as I can. Meanwhile I could delete manually all columns but the 8th using kate. I've plotted the column I'm interested in gnuplot. I took a screenshot so you can see.
As they say, there's more than one way to skin a cat.
What are you plotting? Is it the number of chess games won by the individuals listed in the file? I'm guessing that the three-letter fields are the country, with DEN = Denmark and IND = India. If so, what do BAN and MAS mean? (If you know.)
I'm plotting the Elo ratings on the x-axis versus the number of people with such a Elo rating on the y-axis. The data is for May of this year and apparently contains all the names of active players who are "members" of the FIDE. Anyone can download the file on FIDE's website, it's around 24 Mb I think.
As for the countries you are right. By looking at the names, I'm guessing BAN stands for Bangladesh but I don't know for MAS. Probably arabic by looking at the names.
That's fixed tab pos data of known size; easy job:
Code:
!----------------------------------------------------------------------------80
!> @file elo_read.f90
! sample for reading data of known size given in known fixed tab format
program elo_read
    implicit none
    integer,            parameter :: FD     = 11
    character(len=*),   parameter :: FN     = 'elo_data.txt' ! whatever
    !integer,            parameter :: M      = 159663  ! number of rows
    integer,            parameter :: M      = 26      ! number of rows
    integer,            parameter :: HEAD   = 109     ! chars before int datum
    integer,            parameter :: TAIL   = 16      ! dto after int datum
    character(len=13)             :: sfmt
    character(len=HEAD)           :: head_buffer
    character(len=TAIL)           :: tail_buffer ! just for completeness sake
    integer                       :: data_(M)
    integer                       :: stat, i
    ! building the format string from parameters
    write(sfmt, fmt="(A2,I3,A5,I2,A1)") "(A", HEAD, ",I4,A" , TAIL, ")"
    open(unit=FD, file=FN, status='OLD', err=110, iostat=stat)
    data_ = 0
    i = 1
    do while (stat == 0 .and. i <= M)
        read(FD, fmt=sfmt, err=120, iostat=stat) &
                            head_buffer, data_(i), tail_buffer
        i = i + 1
    end do
    write(*,*) data_ ! or whatever processing is required
    goto 999
110 stop "OPEN" !> @TODO implement more specific error handling
120 stop "READ" !> @TODO implement more specific error handling
999 stop
end program elo_read
Code:
Code:
I see. What does A30 stand for though?
I've the following code to try this way:
Code:
program histogram
implicit none
!real :: mean
integer :: x_i ,j  ,k
character(5), dimension(7):: Str1
 character(5), dimension(4):: Str2
j=1
100 format (A109, I5, A30)
icount=0
do while (j.le.159663)
read (11, 100) Str1, x_i, Str2
j=j+1
end do
    do k=0,3000,1
    end do
close(11)
close(12)
end program
But I'm getting the error
Code:
At line 18 of file chesshistogram2.f90 (unit = 11, file = 'crat.txt')
Fortran runtime error: Expected INTEGER for item 2 in formatted transfer, got CHARACTER
(A109, I5, A30)
Code:
program elo_read
    implicit none
    integer                       :: data_(M)
    integer                       :: stat, i
    data_ = 0
    i = 1
        i = i + 1
    end do
    goto 999
999 stop
Thanks a lot for your time. The code is a bit over my head. I mean I can mainly understand it but I couldn't write it on my own.
You're welcome.
The code simply eats the leading 109 chars, disregards them, eats the the 4 char repr. of the ELO int, and makes that an int inside an array of ints ("data_") for further processing.
The only - slightly - tricky thing is building the fmt string for the read() sort-of dynamically; I do this to get the maximum out the known constants declared in the section with the "parameter" clauses to avoid burying those consts deep inside a format statement only or - worse - duplicating their given values somewhere in the code.
