Forward Unit Push Operator Equation
  • Context:
  • Thread starter Thread starter topsquark
    Operator Push Unit
4 replies · 1K views
Homework Helper
Insights Author
MHB
Hopefully the symbols I am using are standard. I will define them upon request.
I have a theorem that says, given a difference equation [math]\left ( \sum_{j = 0}^m a_j E^j \right ) y_n = \alpha ^n F(n)[/math], we can define a polynomial function [math]\phi (E) = \sum_{j = 0}^m a_j E^j [/math] such that [math]\phi (E) y_n = \alpha ^n F(n)[/math]. I can follow a proof to the following result:
(1) [math]\phi (E) \left ( \alpha ^n F(n) \right ) = \alpha ^n \phi ( \alpha E ) F(n)[/math]
The notes then go on to say, "therefore"
(2) [math]\dfrac{1}{ \phi (E) } \left ( \alpha ^n F(n) \right ) = \alpha ^n \dfrac{1}{ \phi ( \alpha E )} F(n)[/math]
Now, the particular solution to the difference equation is written as [math]y_p = \dfrac{1}{ \phi (E) } \left ( \alpha ^n F(n) \right )[/math] and I can use (2) to evaluate this and get the correct result. So I know that (2) is right, without any typos. But how do I get from (1) to (2)?
More details upon request.
-Dan
I might have what I would call a "formal" solution.
[math]\dfrac{1}{ \phi (E) } \alpha ^n F(n) = \dfrac{1}{ \phi (E) } \dfrac{1}{ \dfrac{1}{ \alpha ^n F(n) } } = \dfrac{1}{ \phi (E) } \dfrac{1}{ \alpha ^{-n} F^{-1}(n)}[/math]
Now, I see no reason why we can't use a negative exponent in the equation (1) in the OP and [math]F^{-1}(n)[/math] is just a function of n. So we can apply (1):
[math]\dfrac{1}{ \phi (E) } \dfrac{1}{ \alpha ^{-n} F^{-1}(n)} = \dfrac{1}{ \alpha ^{-n} \phi ( \alpha E ) F^{-1}(n)} = \alpha ^n \dfrac{1}{ \phi ( \alpha E) } F(n)[/math]
So we get
[math]\dfrac{1}{ \phi (E) } \alpha ^n F(n) = \alpha ^n \dfrac{1}{ \phi ( \alpha E) } F(n)[/math]
as required.
Now, I call this formal because I haven't really "gotten into the gears" of the equation. I've used it but haven't fully explored it so there may be some surprises I'm not aware of. The other reason is that the derivation requires F(n) to never be 0, which wasn't in the notes that I downloaded. Granted, the notes weren't expected to be a complete introduction and they were shot through with typos. So F(n) not zero may well be a requirement on this equation. I'll have to mess with it.
Any thoughts?
-Dan
Hi Dan,
I like the symbolic argument above. Here is something I scratched out in an attempt to avoid the $F^{-1}(n)$ term:
By definition of the inverse,
$$\frac{1}{\phi(\alpha E)}\phi(\alpha E) F(n) = F(n)$$
From (1) we get
$$\left[\frac{1}{\phi(\alpha E)}\alpha^{-n}\phi(E)\alpha^{n}\right] F(n) = F(n)$$
This implies
$$\left[\alpha^{-n}\phi(E)\alpha^{n}\right]F(n) = \phi(\alpha E)F(n)$$
Since $F(n)$ is an arbitrary function of $n$, it follows that
$$\alpha^{-n}\phi(E)\alpha^{n} = \phi(\alpha E)$$
Thus,
$$1 = \alpha^{-n}\phi(E)\alpha^{n}\frac{1}{\phi(\alpha E)},$$
from which it follows
$$\frac{1}{\phi(E)}\alpha^{n} = \alpha^{n}\frac{1}{\phi(\alpha E)}$$
The above, when applied to $F(n)$, is the desired result in (2).
GJA said:
Hi Dan,
From (1) we get
This implies
Thus,
I like it! Yes, I have solved a couple of systems and the [math]F(n) \neq 0[/math] condition does not seem to be a problem.
Thanks!
-Dan
Well, I just found about half the derivation in an (old) online text that was missing some pages. It was far more direct.
[math]\dfrac{1}{ \phi (E)} \alpha ^n F(n) = \dfrac{1}{ \phi (E) \alpha ^{-n} } F(n) = \dfrac{1}{ \alpha ^{-n} \phi ( \alpha E)} F(n) = \alpha ^n \dfrac{1}{ \phi ( \alpha E)} F(n)[/math]
I hadn't thought about separating the factors but [math]E^j ( \alpha ^n F(n) ) = \alpha ^{n + j} E^j (F(n)) = \alpha ^{n + j} F(n + j)[/math] so it makes sense.
-Dan
