Four-momenta trend as a function of proper time
46 replies · 5K views
Frostman
In an inertial reference system, a particle of mass ##m## and charge ##q## is given, with initial speed ##v(0) = (v_x (0); v_y (0); v_z (0))##. Furthermore, there is an electric field ##E##, parallel to the y-axis, and a magnetic field ##B##, parallel to the z-axis, both constant, homogeneous and such that ##|E| = |B|## in natural units.
Calculate the trend of the four-momenta ##p^\mu## as a function of the proper time ##\tau## and of the initial speed.
##\frac{dp^\mu}{d\tau}=qF^{\mu\nu}v_\nu##
As a starting point I immediately thought about the equation:
From this I proceed component by component:
##\frac{dp^0}{d\tau}=qF^{0\nu}v_\nu=q\gamma E_yv_y##
##\frac{dp^1}{d\tau}=qF^{1\nu}v_\nu=q\gamma v_yB_z##
##\frac{dp^2}{d\tau}=qF^{2\nu}v_\nu=q\gamma (E_y-u_xB_z)##
##\frac{dp^3}{d\tau}=qF^{3\nu}v_\nu=0##
Now that I have the values I integrate:
##p^0=\int_{p^0(0)}^{p^0(\tau)}dp^0=\int_{0}^{\tau}d\tau q\gamma E_yv_y##
##p^1=\int_{p^1(0)}^{p^1(\tau)}dp^0=\int_{0}^{\tau}d\tau q\gamma v_yB_z##
##p^2=\int_{p^2(0)}^{p^2(\tau)}dp^0=\int_{0}^{\tau}d\tau q\gamma (E_y-u_xB_z)##
##p^3=\int_{p^3(0)}^{p^3(\tau)}dp^0=\int_{0}^{\tau}d\tau 0=0##
I have a problem solving integrals with respect to ##\tau##, maybe I solved the last component, but I'm not sure:
##p^3(\tau) - p^3(0) = 0 \rightarrow p^3(\tau)= \text{cost} = m\gamma v_z(0)##
Can you tell me first of all if everything I have done is correct and if it remains for me to understand how to solve the integrals? If so, how can I proceed in solving these integrals? Is it okay that I analyze component by component or should I write it all in a formula like ##\frac{dp^\mu}{d\tau}=qF^{\mu\nu}v_\nu##?
My first advice is to write everything in terms of ##p##, which is your goal. Notice that ##p^\mu = m v^\mu## so $$\frac{d p^\mu}{d \tau} = \frac{q}{m} F^{\mu\nu}p_{\nu}$$.
Now, using the fact that ##|E|=|B|##, look more closely to the equations ##\mu = 0## and ##\mu = 1##. Can you spot anything?
##\frac{dp^0}{d\tau}=\frac qmF^{0\nu}p_\nu=\gamma \frac qm E_yp_y##
##\frac{dp^1}{d\tau}=\frac qmF^{1\nu}p_\nu=\gamma \frac qm B_zp_y=\frac{dp^0}{d\tau}##
This from ##|E|=|B|## that is ##E_y = B_z##.
Ok, perfect, with that you can obtain very useful information that can be used in equation ##\mu = 2##. (Specially if you rewrite it in therms of ##p##)
Do you mean that?
##\frac{dp^2}{d\tau}=\frac qm F^{2\nu}p_{\nu}=\gamma \frac qm (E_y-p_xB_z)=\gamma \frac qm E_y(1-p_x)##
Frostman said:
Do you mean that?
Well... not quite, the second equality is not correct. Also I'm telling you that the fact that
$$\frac{d p^0}{d \tau} = \frac{d p^1}{d \tau}$$ can be very useful there.
Do you mean this equality?
##\frac qm F^{2\nu}p_\nu=\gamma \frac qm(E_y-p_xB_z)##?
Could it be now?
##\frac qm F^{2\nu}p_\nu=\gamma \frac qm(mE_y-p_xB_z)##?
I'm using this values:
F^{\mu\nu}=\begin{pmatrix}
0 & 0 & -E_y & 0\\
0 & 0 & -B_z & 0\\
E_y & B_z & 0 & 0\\
0 & 0 & 0 & 0
\end{pmatrix}
p_\nu = (\gamma m, -\gamma p_x, -\gamma p_y, -\gamma p_z )
So:
##F^{2\nu}p_\nu=E_y\gamma m - B_z\gamma p_x - 0 - 0=\gamma(E_y m -p_x B_z)##
Well, look better than before.
This could be a matter of convention, but I haven't seen anyone writing ##p_\nu = \gamma(m, -p_x, -p_y, -p_z)##, anyway since our aim is to compute ##p_\nu(\tau)## it is not a good idea to write them in terms of other things, so I would keep them as simply ##p_\nu = (p_0, p_1, p_2, p_3) = (p^0, -p^1, -p^2, -p^3)##
Do you mean the fact of the indices in the four-vector expressed component by component or the minus signs from the second component onwards?
I'm saying that I haven't seen anyone writing ##p_1 = -\gamma p_x##, but this could be just a matter on how you define things.
In any case, with this definition of ##p_\nu##, your expression is correct. But again, since we want to find the functions ##p^\mu(\tau)## I think it is better to keep them in our equations.
So, now you have ##\frac{d p^2}{d\tau}=\gamma(E_y m -p_x B_z)##, after expressing them using ##p^0## and ##p^1## and using ##|E|=|B|##, what do you notice?
I have:
##\frac{dp^2}{d\tau}=\frac qmF^{2\nu}p_\nu=\gamma \frac qm (E_ym-p_xB_z)=\gamma \frac {qE_y}m (m-p_x)=\frac{1}{p_y}\frac{dp^0}{d\tau}(m-p_x)##
I'm not sure if the last step is what you ask me ...
In fact mixing the conventions used confuses me for a moment, it should be like this:
##\frac{dp^2}{d\tau}=\frac qmF^{2\nu}p_\nu=\gamma \frac qm (E_ym-p_xB_z)=\frac {qE_y}m(p^0-p^1) ##
Ok, that's the equation that will help us with the problem!
Take a moment to look at this equation with ##\frac{d p^0}{d \tau} = \frac{d p^1}{d \tau}## in mind. You should be able to find an interesting conclusion.
Since they are infinitesimal quantities, I think it means that even if integrated for a "proper time" these quantities remain the same.
Mmm... I am not sure what quantity you refer to as infinitesimal...
In any case if you still haven't spotted, try to compute $$\frac{d^2 (p^2)}{d \tau ^2}$$
Yeah
$$\frac{d^2 (p^2)}{d \tau ^2}= \frac {qE_y}m\bigg(\frac{dp^0}{d\tau}-\frac{dp^1}{d\tau}\bigg)=0$$
Yes, I can find:
$$p^0(\tau)= p^1(\tau) =\gamma \frac qm E_yp_y \tau=\gamma \frac qm B_zp_y \tau$$
$$p^2(\tau)= 0$$
$$p^3(\tau)= 0$$
Right?
I think we need to find an another way to write them as function not only of proper time but also of initial speed.
I just integrated this two times ##\frac{d^2 (p^2)}{d \tau ^2}= 0## but yes, it makes non-sense since ##\frac{d (p^2)}{d \tau }## must be a constant and ##p^2## a linear term in ##\tau##...
Which quantity I need to integrate so? I understand the fact that ##\frac{d^2 (p^2)}{d \tau ^2}= 0## because of ##\frac{d p^0}{d \tau}= \frac{d p^1}{d \tau}##
Well, I don't know how you integrated, but as you say. The integral should give you ##p^2## as a linear function of ##\tau##. In the same way the equation for ##p^3## doesn't imply that ##p^3=0##.
I have these relation:
##\frac{dp^0}{d\tau}=\gamma \frac qm E_yp^2##
##\frac{dp^1}{d\tau}=\gamma \frac qm B_zp^2##
##\frac{dp^2}{d\tau}=\frac {qE_y}m(p^0-p^1) ##
##\frac{dp^0}{d\tau}=\frac{dp^0}{d\tau}##
I can integrate this:
$$\frac{dp^2}{d\tau}=\frac {qE_y}m(p^0-p^1)$$
$$\int_{p^2(0)}^{p^2(\tau)}dp^2=\int_{0}^{\tau}\frac {qE_y}m(p^0-p^1)$$
$$p^2(\tau)-p^2(0)=\frac {qE_y}m(p^0-p^1)\tau$$
Ok, now you should relate ##p^2(0)## and ##p^0-p^1## with ##\vec{v}(0)##.
Also, now you have ##p^2(\tau)## you can substitute in the equations for ##\frac{d p^0}{d \tau}## and ##\frac{d p^1}{d \tau}##.
It should be:
$$p^2(\tau)=\gamma (qE_y(1-v_x(0))\tau+mv_y(0))$$
One question: ##p^0-p^1## are ##p^0(0)-p^1(0)## or ##p^0(\tau)-p^1(\tau)##?
