Solution: Prove Sum of Fourier Coefficients of a C2π Function is Finite
The discussion focuses on proving that the sum of Fourier coefficients, denoted as c_n(f), for a function f in the space C^{2\pi} \cap C^1[-\pi,\pi] is finite. The key steps involve applying the Cauchy-Schwartz inequality and utilizing properties of the inner product in l_2 space. The final conclusion is that the sum \sum_{n\in\mathbb{Z}}|c_n(f)| converges due to the boundedness of f' and the convergence of \sum \frac{1}{n^2}.
  • Understanding of Fourier coefficients and their definitions
  • Familiarity with the Cauchy-Schwartz inequality
  • Knowledge of inner product spaces, particularly l_2 space
  • Basic concepts of convergence in series and functions in C^{2\pi}
  • Study the application of Parseval's theorem in Fourier analysis
  • Explore the properties of C^{2\pi} functions and their Fourier series
  • Learn about convergence criteria for series involving Fourier coefficients
  • Investigate the implications of the Cauchy-Schwartz inequality in functional analysis
Mathematicians, students of Fourier analysis, and anyone interested in the convergence properties of Fourier series and coefficients.
P3X-018
[SOLVED] Fourier coefficients
For f \in C^{2\pi}\cap C^1[-\pi,\pi], I have to show that
\sum_{n\in\mathbb{Z}}|c_n(f)| < \infty
where c_n(f) is the Fourier coefficient of f;
c_n(f) = (f, e_n) = \frac{1}{2\pi}\int_{-\pi}^{\pi} f(t)e^{-int}\,dt
f \in C^{2\pi} means f continuous and that f(-\pi) = f(\pi).
Hint: Use Cauchy-Schwartz (CS) inequality.
(e_n = e^{int})
I just can't seem to use CS in a useful way, I keep running into dead ends:
It is easily shown that c_n(f') = inc_n(f). So by using this and splitting the sum up in 2 parts and using that e_{-n} = \bar{e}_{n}, I get
\sum_{n\in\mathbb{Z}}|c_n(f)| = c_0(f) + \sum_{1}^{\infty}\frac{|(f',e_n)| - |(f',\bar{e}_n)|}{n}
Using triangle inequality I can get
|(f',e_n)| - |(f',\bar{e}_n)| \leq |(f', e_n-\bar{e}_n)| =2|(f', \sin(nt))|.
Even here CS won't be useful. Is there a different an easier approach?
What theorems do you know? Try looking at Parseval and its proof.
I kept looking at the wrong inner product to use CS on, that is that inner product of L_2, but I should look at the inner product of \ell_2 space. So by using that (replacing the minus sign with + in the afore mentioned equation for c_n(f))
\sum_{n\in\mathbb{Z}}|c_n(f)| \leq c_0(f) + \sum_{1}^{\infty}\frac{|(f',e_n)| + |(f',\bar{e}_n)|}{n}
and then using that for |(f',\bar{e}_n)|/n (and the same for |(f',e_n)|/n) we get the summation by CS on l_2 innerproduct to be
\sum_{1}^{\infty}\frac{1}{n}|(f',e_{-n})| \leq \left(\sum_{1}^{\infty}\frac{1}{n}\right)^{1/2}\left(\sum_{1}^{\infty} |(f',e_{-n})|^2 \right)^{1/2}
Were the C^2 = \sum \frac{1}{n^2} is convergent. Before I can use Parseval's theorem, I need to extend the last sum to go from -infinity to +infinity so (1 more inequality), so I get (f', e_n) instead of (f',e_{-n}),
\sum_{1}^{\infty}\frac{1}{n}|(f',e_{-n})| \leq C\left(\sum_{-\infty}^{\infty} |(f',e_{n})|^2 \right)^{1/2} = C\|f'\| < \infty
Is this correct, or have I done some 'illegal' steps? If I haven't then the problem is solved.
  • · Replies 16 ·
