What is the correct Fourier series for f(x) = 2x-1 on the interval 0<x<1?
The discussion focuses on finding the correct Fourier series for the function f(x) = 2x - 1 on the interval 0 < x < 1. The user initially calculated the Fourier coefficients incorrectly, resulting in values that were half of what they should be. It was clarified that the choice of periodic extension (even or odd) significantly affects the coefficients and that half-range formulas can simplify the calculations. Understanding the nature of the function's extension is crucial for accurately determining the Fourier series. The user ultimately resolved their confusion and successfully computed the coefficients.
gl0ck
Hello guys,
I have to solve one basic problem, but I got the result twice smaller that it should be. So, I am thinking that I must have missed something basic.
The problem is f\left(x\right) = 2x-1 for ##0<x<1##.
I have to find the Fourier coefficients.
I have found A_n = \frac{2}{\pi^2}\sum \frac{ (-1)^{n} -1 }{n^2}\cos(n\pi x)
but the answer says A_n=\frac{4}{\pi^2}\sum \frac{ (-1)^n -1 }{n^2}\cos(n\pi x) and B_n = -\frac{2}{\pi} \sum \frac{(-1)^n - 1}{n} \sin(n\pi x)
Also I am confused about the thing that I can see on some places formulas for An such that A_n = \frac{1}{L} \int_{-L}^L f(x)\cos\left(\frac{n\pi}{L}x\right)dx and on some places it is \frac{2}{L}\int_{-L}^L f(x) \cos\left(\frac{n\pi x}{2} x\right)dx in my case I solved with the second formula and get for ##L - 1/2## and formula for ##An = 4 \int_0^1 (2x - 1)\cos(2n\pi x)dx##, same for ##B_n## but with sin.
Thanks and hope you could understand my question(s)
gl0ck said:
Hello guys,
I have to solve one basic problem, but I got the result twice smaller that it should be. So, I am thinking that I have missed something basic.
The problem is ƒ\left(x\right) = 2x-1 , 0<x<1
You have given a function of (0,1). That is not a periodic function. Your first decision is what periodic function you are expanding, specifically what is the definition going to be on (-1,0). There are three "natural" choices. You could just use the same formula 2x-1 on -1<x<0, or the even extension of 2x-1, or the odd extension of 2x-1 on (-1,0), and extend them periodically. The first choice would be neither even nor odd and would have both ##a_n## and ##b_n## coefficients. The second and third choices being even or odd would have only ##a_n## or ##b_n## coefficients, respectively. Those last two can use the half range formulas. Surely your text talks about that.
Not sure I understand what you mean. Are you suggesting to use limits -1<x<0 or -1<x<1 ? If it is that does't it really change the answer much if it is -1<x<0 or 0<x<1.
Or you mean I should understand what is written here : http://www.math24.net/even-and-odd-extensions.html ?
The whole text of the problem says :
Find the Fourier cosine and sine series for the following functions and sketch their corresponding even and odd extensions.
Yes, you need to understand that.
The point is that the even and odd extensions are in fact even and odd functions. And because of that the Fourier coefficients can be calculated by using the so-called half range formulas. The idea is that the ##a_n## formulas for an even function have even integrands. So instead of doing an integral like ##\int_{-a}^a## you can do ##2\int_0^a##. That's the idea behind the half range formulas and you don't have to worry about (-a,0) in the formulas.
I forgot to thank you, sorry :) This helped me a lot and I solved them all :D
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
