Fourier Series Homework (Discontinuous Function)
The discussion revolves around solving a Fourier series problem involving a function that was initially misidentified as discontinuous. Participants clarify that the function should be defined as sin(x) on the interval [0, π] rather than [-π, π]. The calculation of the coefficient a0 is addressed, with emphasis on careful evaluation and sign management, leading to a conclusion of a0 being 0. Further, the discussion explores the calculation of ak using trigonometric identities, with participants working through integration steps and simplifying expressions. The conversation concludes with a focus on ensuring proper notation and handling of terms to arrive at the correct answer.
CGM
I have attached a screenshot of the question.
I know how to use Fourier's theorem for one function but have no idea how to attempt it with a discontinuous function like this.
I tried working out a0 by integrating both functions with the limits shown, adding them and multiplying by 1/pi but I just got 0.
First, there is a typo in the definition of the function. It should obviously be ##\sin x## on ##[0,\pi]##, not ##[-\pi,\pi]##. You will have to show us your work for ##a_0## so we can see what you did wrong. Also, your given function is continuous, not discontinuous as stated in your title.
a0 = 1/pi [ ∫(0) + ∫(sinx)] (0 between 0 and -pi and sinx between pi and 0)
a0 = 1/pi (0 + [-cosx])
= 1/pi (0 + (-1+1))
= 0
Sorry I'm not sure about how to do the notation properly on a computer
= 1/pi (0 + (-1+1))
= 0
So the nonzero part is ##\frac 1 \pi (-\cos x|_0^\pi)##. Be more careful with evaluating that and watch your signs.
Okay so, that gives me the ao value
Then ak = 1/pi ( ∫sin(x)cos(kx) )
My tutor told me to use: sin((k+1)x) = sin(kx)cos(x) + cos(kx)sin(x)
sin((k-1)x) = sin(kx)cos(x) - cos(kx)sin(x)
to make the integration easier but I can't see what to do with this
What happens if you add the two identities your tutor suggested?
[Edit:] Or maybe subtract them?
ak = 1/pi [ ∫sin((k+1)x) - ∫sin((k-1)x) ]
= 1/pi { [(-1/k+1)cos((k+1)x)] - [(-1/k-1)cos((k-1)x)] }
= 1/pi { (-cos((k+1)x)-1)/(k+1)) - (-cos((k-1)x)-1)/(k-1)) }
Is this even close?
Is this even close?
It looks close. I think you are missing a ##1/2## you got when you subtracted. So you still have to push it through and see if you get the right answer. Put in the limits (carefully) and simplify your answer. Also note that that formula doesn't work if ##k=1## so you will have to work that separately, but it's easy. Once you have the formulas we can talk about why some of them are zero.
The last line has the limits put in but I don't know where to go from there
EDIT: Just realized I put 'x's in instead of 'pi's
So, it should be:
= 1/pi { (-cos((k+1)pi)-1)/(k+1)) - (-cos((k-1)pi)-1)/(k-1)) }
Not sure what I've done actually
So, it should be:
So keep going. I still think you dropped a 1/2, but now you need to simplify that. Remember ##\cos(n\pi) = (-1)^n## so there are lots of ##\pm 1##'s in there. Don't stop now...simplify it and go for the answer.
I can't find the 1/2 and I can't figure out how to simplify it even with cos(kpi) = (-1)k substituted in
= 1/pi { [ (-(-1)k+1 - 1)/(k+1) ] - [ (-(-1)k-1 - 1)/(k-1) ] }
Subbing in k to be an even number:
= 1/pi { -2/k+1 + 2/k-1 }
= 2/pi { -1/k+1 + 1/k-1 }
= -2/pi(k2-1)
Got it I think
EDIT: I see now where I lost the half so I don't know how I've ended up with the right answer
= 1/pi { -2/(k+1) + 2/(k-1) }
= -2/pi(k2-1)
Got it I think
Just luck. You need parentheses in there and to handle them correctly.
  • · Replies 16 ·
