Fourier sine transform for Wave Equation
The discussion centers on solving the wave equation \( u_{tt} - c^{2}u_{xx} = 0 \) using the Fourier sine and cosine transforms. The initial conditions (IC) are \( u(x,0) = u_{t}(x,0) = 0 \), and the boundary conditions (BC) include \( u(x,t) \) being bounded as \( x \rightarrow \infty \) and \( u_{x}(0,t) = g(t) \). The Fourier transform leads to a second-order ordinary differential equation (ODE) in time, yielding solutions involving sine and cosine functions. The final solution is expressed in terms of the inverse Fourier cosine transform, but the user encounters difficulties in progressing further.
  • Understanding of wave equations and their properties
  • Familiarity with Fourier sine and cosine transforms
  • Knowledge of initial and boundary value problems
  • Proficiency in solving ordinary differential equations (ODEs)
  • Study the application of Fourier sine and cosine transforms in solving PDEs
  • Learn about Green's Functions and their role in solving boundary value problems
  • Explore the method of characteristics for wave equations
  • Investigate the implications of different boundary conditions on wave solutions
Mathematicians, physicists, and engineering students focusing on partial differential equations, particularly those interested in wave phenomena and Fourier analysis.
compliant
Find the solution u, via the Fourier sine/cosine transform, given:
u_{tt}-c^{2}u_{xx}=0
IC: u(x,0) = u_{t}(x,0)=0
BC: u(x,t) bounded as x\rightarrow \infty , u_{x}(0,t) = g(t)
2. The attempt at a solution
Taking the Fourier transform of the PDE, IC and BC:
U_{tt}-c^{2}(i\lambda)^{2}U=0
U_{tt}+c^{2}\lambda^{2}U=0
which is an ODE in t, so two linearly independent solutions of the homogeneous equation are sin(\lambda ct) and cos(\lambda ct).
If I take a linear combination of these two solutions, I get zero constants, which eventually leaves me with u = 0 as a solution, or at least one that's only x-dependent.
But if u is x-dependent, U_{tt} = 0 \Rightarrow c^{2}\lambda^{2}U=0 \Rightarrow U = 0
which still leaves me with u = 0 as a solution, and, no offense, for a homework problem, that's kind of lame. That's why I'm suspicious, and asking to see if I'm doing it right.
u_{tt}=c^{2}u_{xx}=0
Solving just PDE and IC without Fourier (and without BC) yields u(x,t)=0.
Are you sure you have the right equations in your problem?
[PLAIN]http://img815.imageshack.us/img815/9894/fourier5313.png
there was a minus sign. oops.
In any case, relevant equations:
F_{c}(f(x,t)) = \sqrt{\frac{2}{\pi}} \int^{\infty}_{0} cos (\lambda x) f(x,t) dx
F_{c}(f''(x,t)) = -\sqrt{\frac{2}{\pi}} f'(0,t) - \lambda^{2} F_{c}(f(x,t))
which gives me
U_{tt}-c^{2}\left[-\sqrt{\frac{2}{\pi}}U_{x}(0,t)-\lambda^{2}U \right] = 0
U_{tt}+c^{2}\sqrt{\frac{2}{\pi}}g(t)+c^{2}\lambda^{2}U = 0
Which, by the method of Green's Functions, gives me:
U(\lambda,t) = \int^{t}_{0} -c^{2}sin (\lambda c (\tau-t))\sqrt{\frac{2}{\pi}}g(\lambda,\tau) d\tau
Taking the Inverse Fourier Cosine Transform,
u(x,t) = \sqrt{\frac{2}{\pi}} \int^{\infty}_{0} cos(\lambda x) \left[\int^{t}_{0} -c^{2}sin (\lambda c (\tau-t)) \sqrt{\frac{2}{\pi}}g(\lambda,\tau) d\tau \right] d\lambda
= -c^{2}{\frac{2}{\pi}} \int^{\infty}_{0} cos(\lambda x) \left[\int^{t}_{0} sin (\lambda c (\tau-t))}g(\lambda,\tau) d\tau \right] d\lambda
and this is where I am stuck.
But that only makes use of the regular Fourier Transform, and not the Fourier Cosine Transform.
with the answer please ?
1) u(t-2)*δ(1-t)
2) X(w)=e^-2|w| / (1-jw)
x1(t)=x(2-t)
X1(w)= ?3) x[n]=u[n] ; x(0) = ?4)Θ = -aw
x(t) = cos100 πt
Y(t) = sin100 πt
a=?
5) one side laplase
Y(s)=[1+x(s)] / [s+3]
6) Θ = -3w
y(t)=?
  • · Replies 21 ·
