Fourier Transform (basic table lookup)
The discussion revolves around understanding the Fourier Transform (FT) relationship between the expressions 10 X(jt) and 20 π x(-ω). The initial confusion stems from interpreting the notation and the role of the imaginary unit j, which represents √-1. The correct transformation involves simplifying the equation and recognizing that the prefactors in the FT and its inverse must multiply to (1/2π). A key point is that the sign change occurs when switching the limits of integration during the transformation process. Ultimately, the conversation highlights the nuances of FT calculus and the importance of conventions in notation.
FrogPad
I have a practice exam I'm going through, and I am stumped on one of the basic problems.
How is this a transform pair?
10 X(jt) <-----> 20 \pi x (-\omega)
I don't see how one can make this relation. What is the 10 X (jt).
thanks in advance
Divide both sides by 10 to simplify!
X(jt)<-----> 2pi x(-w)
Still seems wrong to me. The 2pi is normally included in the defn. of the FT.
What's j ?
I'll post the exact question. I don't understand the X(jt) as I posted. Note: j = \sqrt{-1}
OK, I got it- but I don't like the j notation. Everyone else writes
x(t) <-----> X(omega)
Define FT[x(t)]= Int[e^-iwt x(t)] dt
FT-1[X(w)]=(1/2pi)Int[e^iwt X(w)] dw
(you may use a different convention, but the prefactors of FT and FT-1 must multiply to (1/2pi) no matter what convention you use)Start with FT[x(t)]=X(w)
Int [ e^-iwt x(t)] dt = X(w)
substitute w=t', t=w'
Int [ e^-iw't' x(w') ] dw' =X (t')
which is the same as writing
Int [ e^-iwt x(w) ] dw =X (t)
Substitute w -> -w
-(1/2pi) Int [ e^iwt x(-w) ] dw =1/(2pi) X (t)
The LHS is the inverse FT, which I'll call FT-1
-FT-1 [x(-w)]=1/2pi X(t)
Take 2pi to other side
X(t)=-2pi FT-1 [x(-w)]
FT both sides
FT[ X(t) ] =-2pi x(-w)
X(t) <----> - 2pi x(-w)
I seem to have an extra minus sign- but who cares? You can have fun checking if it's me or the teacher who messed it up.
Edit- the minus sign comes from changing the limits from +ininity,-infinity to -infinity,+infinity in the integral, when w-> -w
You can then turn the integral 'the right way up' with the introduction of a minus sign.
That always trips me up.
The conjugation rule is :
<br /> g\left( t \right) = \overline {f\left( t \right)} \Rightarrow G\left( \omega \right) = \overline {F\left( { - \omega } \right)} <br />- Warren
- Warren
Is that a proof?
Oops, actually, I read this too quickly. The example given is a form of the inversion rule:
<br /> g\left( t \right) = F\left( t \right) \Rightarrow G\left( \omega \right) = f\left( { - \omega } \right)<br />
And no, it's not a "proof," it's an rule of the so-called Fourier transform calculus.
- Warren
