Fourier Transform of a Gaussian With Non-Zero Mean
The discussion focuses on the Fourier transform of the Gaussian function defined as f(t)=exp[-(t-m)²/(2σ²)]. The participant derived the Fourier transform using the method of completing the square, resulting in the expression &hat;f(ω)=1/(2σ)e^{-(σ²ω²/2+iσω)}. They compared their result with Wolfram Alpha, which provides a different form due to the omission of the 1/√(2π) factor in its definition. The discussion also highlights the use of the shift property of the Fourier transform, which states that if &mathcal{F}[f(t)]=&hat{f}(ω), then &mathcal{F}[f(t-m)]=&hat{f}(ω)e^{-imω}.
  • Understanding of Fourier transforms and their properties
  • Familiarity with Gaussian functions and their characteristics
  • Knowledge of completing the square in mathematical expressions
  • Experience with Wolfram Alpha for mathematical verification
  • Study the shift property of the Fourier transform in detail
  • Learn about the implications of different definitions of the Fourier transform
  • Explore the application of Taylor series in Fourier analysis
  • Investigate the role of normalization factors in Fourier transforms
Students and professionals in mathematics, physics, and engineering who are working with Fourier transforms, particularly those dealing with Gaussian functions and their applications in signal processing.
malevolence19
I am looking at finding the Fourier transform of:
f(t)=\exp \left[ \frac{-(t-m)^2}{2 \sigma^2}\right]
\hat{f}(t)=\frac{1}{\sqrt{2 \pi}} \int_{-\infty}^{\infty} f(t) e^{-i \omega t} dt
I did it a little differently that my professor suggested. He said use taylor series but when I do that I end up getting a triple sum (2 from the exponentials and 1 coming from an (x+m)^j; so I used binomial expansion) so I did it the traditional way you deal with gaussians: complete the square.
I combined the exponentials, completed the square and end up with an answer that looks like:
\hat{f}(t)=\frac{1}{2 \sigma}e^{-(\frac{\sigma^2 \omega^2}{2}+i \sigma \omega)}
But wolfram has this:
http://www.wolframalpha.com/input/?i=fourier+transform+of+e%5E%28-%28t-m%29%5E2%2F%282r%5E2%29%29
With r= 2 \sigma^2
I was just wondering if anyone could double check me against wolfram? I can type out steps if needed. This isn't a homework or anything, he just brought it up and I suggested completing the square instead. Apparently this means I have to present it to the class on Monday -.-
Comparing your expression for f(t) with the input to the Fourier transform at the Wolfram link, I'm not sure why you put r = 2\sigma^2 instead of r = \sigma.
Also, check Wolfram's definition of the Fourier transform. It might not include your 1/\sqrt{2\pi} factor. There is no universal consensus regarding this. [edit]: You can see their definition by clicking on the "definition" link. Indeed, their definition omits the 1/\sqrt{2\pi}
That's what I meant r=\sigma. I typed it in two different ways and I had them mixed up :/
And omitting the 1/sqrt(2 pi) gives me:
\sqrt{\frac{\pi}{2 \sigma^2}}e^{-(\frac{\sigma^2 \omega^2}{2}+\sigma^2 i \omega)}
They have the sigma in the numerator some how.
Ahhhh, nevermind I see it!
By the way, you can also solve this problem by using the shift property of the Fourier transform: if \mathcal{F}[f(t)] = \hat{f}(\omega), then \mathcal{F}[f(t-m)] = \hat{f}(\omega)\exp(-im\omega).
Thank you. I always forget about these nice shifting formulae.
