Fourier Transform of a sin(2pi*x)
The discussion centers on the Fourier Transform (FT) of the sine function, specifically sin(2πx). Participants clarify that the negative amplitude observed in the sine graph's FT is due to the negative frequency component being 180 degrees out of phase with the positive frequency component. The Fourier Transform of sine is expressed as a complex function, which includes both modulus and phase, while the FT of cosine remains real and symmetric. The confusion arises from the nature of sine as an odd function compared to cosine's even function.
  • Understanding of Fourier Transform concepts
  • Familiarity with complex numbers and their representation
  • Knowledge of sine and cosine functions and their properties
  • Basic calculus, particularly integration techniques
  • Study the properties of Fourier Transforms for sine and cosine functions
  • Learn about the relationship between phase and amplitude in complex functions
  • Explore Euler's formula and its application in Fourier analysis
  • Review integration techniques involving delta functions in Fourier analysis
Students and professionals in mathematics, physics, and engineering who are looking to deepen their understanding of Fourier Transforms and their applications in signal processing and analysis.
BobP
I have been very briefly introduced to Fourier transformations but the topic was not explained especially well (or I just didn't understand it!)
We were shown the graphs with equations below and then their Fourier transformation (RHS). I understand the one for cos(2pist) but NOT the sin(2pist).
Here is my reasoning: The sin wave shown has a constant frequency (that is larger than the cosine function; hence its frequency values are larger). It is possible to have a "-ve" frequency because waves can travel in both directions. I do not understand why the amplitude on the sin graph is negative though? If it was negative on both it would make sense but it isn't!
I know that both FT boil down to a cosine expression (as the sin expression is lost when integrating between infinities) and that makes it even more confusing for me! Please can someone help me understand. thanks
Just a wording correction though, amplitude by definition is a positive quantity. As for your question, two functions connected through Fourier transform are in general complex, that is, they have modulus and phase. The reason why the negative frequency component in the FT of sine points down is that because this component are 180 degree out of phase from the positive frequency component.
You don't integrate the delta function alone, do you. There is also ##e^{i\omega t}## in the integrand.
But surely the cos points are also 180 degrees out of phase? I am not too sure I understand what you mean by this
Oh Wait. Do you mean because sin is an odd function whereas cos is an even function?
No, the Fourier transform of cosine is real.
A complex number ##z## can be expresed as ##z=|z|e^{i\theta}## where ##|z|## the modulus and ##\theta## the phase. You can write the Fourier transform of sine as
\frac{1}{2}(\delta(\nu+s) - \delta(\nu-s)) = \frac{1}{2}(\delta(\nu+s) + e^{i\pi} \delta(\nu-s))
EDIT: the Fourier transform of cosine is real and symmetric.
so are you saying that the "negative" ampltidue on the sin curve reflects the fact that it is the imaginary component of the sin expression (as per Euler formula)
No, the negative sign appears because of the real component of ##e^{i\pi}## instead.
$$e^{i\pi}=-1$$
$$e^{i\pi}=-1$$
I see...thanks for the help.
Truth be told, I understood none of the maths initially but your help has pointed me to videos / math books that have explained the issue to me so I now understand it (I hope!)
Really grateful!
11K
  • · Replies 139 ·
11K
