Fourier transform of distributions.
3 replies · 3K views
Klaus_Hoffmann
Is there any way to calculate the Fourier transform of the functions
[tex]\frac{d\pi}{dx}-1/log(x)[/tex] and [tex]\frac{d\Psi}{dx}-1[/tex]
(both are understood in the sense of distributions)
i believe that these integrals (even with singularities) exist either in Cauchy P.V or Hadamard finite part sense but if possble i would need a help, thanks
EDIT:= 'pi(x)' here is the prime counting function and 'Psi (x) ' is the Tchebycheff function.
what problems have you encountered just using the definitions?
The problem mathwork is that as you can see the integral is 'sngular' i was looking for a method to give a FINITE value for every frequency, for example using the Cauchy P.V however i think this method (Cacuhy's) to extract a finite value does not work.. perhaps Hadamrd finite part ??, but i don't know how to apply it
The derivative of the pi function, in the distributional sense, will be an infinite series of delta functions, as there are an infinite number of primes.
[tex]\frac{d\pi}{dx}= \delta(x-2) + \delta(x-3) + \delta(x-5) + \cdots[/tex]
So its Fourier transform for a particular frequency would be
[tex]\hat{f}(\omega)=e^{-i 2 \omega }+e^{-i 3 \omega }+e^{-i 5 \omega }+ \cdots[/tex]
I feel pretty sure that this would be a divergent sum, as the pi function is not L2 integrable itself. It seems highly improbable that the sum would converge for all frequencies.
