Fourier transform of rectangular pulse
The discussion revolves around the Fourier transform of a rectangular pulse and the application of the width parameter, 2a. Participants clarify that 2a represents the pulse width in the time domain, while its frequency domain representation is typically infinite. The importance of incorporating the width into calculations is emphasized, particularly when expressing results in terms of the sinc function. Additionally, it is noted that increasing the width of the pulse results in a narrower main lobe and a flatter pulse in the frequency domain. The conversation concludes with a query about using MATLAB for graphing the Fourier transform, indicating ongoing exploration of the topic.
nao113
Calculate the Fourier transform of rectangular pulse given below. (Height, A; width, 2a)
. I tried to calculate that but I am not sure whether it s correct or not. Do I need to put A there or just omit it so it will just be e^-jwt? thank you
available in the question
Here is the question:
Here is my answer
Wolfram says your final result is correct, hold on while I check your in between steps.
one thing that I am confused, where can I use 2a as width here? I guess width represents time pr frequency, right?
Yes the in between steps seem correct to me.
I don't understand your confusion.
2a is the width of the pulse in the time domain, in the frequency domain it seems to have infinite width,
but
this is typical happening with Fourier transform, a narrow function in time domain has a wide Fourier transform in the frequency domain, and a wide function in the frequency domain has a narrow inverse Fourier transform in the time domain.
but
I mean where can I put 2a in my calculation? How can I applied in that math formula? or we don t need to put 2a in that calculation? In my answer, I only used A as height
You have 2a in your final result for F(w) but that doesn't mean that it is the width of F(w) in the frequency domain.
What math formula do you mean? The starting integral of Fourier transform?
The width appears through the bounds of the integration. As you can see, your final result depends of the width of the pulse.
Likes Delta2
Yes well it depends what equivalent expression for F(w) you want to make. If you want to express it in terms of the ##sinc x## function then you must put the 2a there.
yes, that s not 2a for width because I multiplied them with 2 in order to get 2j. Yes, integral of Fourier transform
can you explain to me where the width appears? So rather than using a and -a, I need to use 2a and -2a?
where should I put 2a? Did you mean like the picture below?
Well, theoretically speaking you can put 2a inside your calculation steps, in an infinite number of ways, for example you can multiply by the term ##\frac{2a\cos(2a)\sin(2a)}{2a\cos(2a)\sin(2a)}## which is one and nothing changes, but the point is to put it when it has some utility.
Wolfram gives the answer as $$F(w)=2A\frac{\sin(aw)}{w}$$ but if we want to express this in terms of the ##sinc(aw)=\frac{\sin(aw)}{aw}## then we have to multiply and divide by ##a##, pretty much like you did.
##SincX## function is like a basis function for Fourier transforms, many Fourier transforms can be expressed in terms of the sinc function.
No you can't put it there like this because you change the function of Fourier transform , you will compute the Fourier transform of the function ##g(t)=2aA ## ,##t\in [-a,a]##, but the problem asks for the Fourier transform of ##f(t)=A##...
basically, I don't need to multiply a in my calculation based on Wolfram, right? what does a refer to?
Likes Delta2
a is the half width of the pulse, and it is also in the boundaries of the integral of the Fourier transform.
can I just remove a in my answer? so my answer will be exactly like Wolfram
yes you can but should NOT remove it from inside the ##\sin(aw)##.
yes, I got it..
Thank you, so I don t need to put 2a there. then, why the question provide me with the information of 2a if I will not use them in my answer above?
Well, in the final result ##a## appears inside the ##\sin(aw)## so the final result depends on a, though not exactly on 2a.
Yes, that s what I mean. I also got another question,
What happen if the width 2a is changed?
My answer:
If the width of the rectangular pulse increases then the main lobe becomes narrower. Moreover, the pulse becomes flatter and the magnitude spectrum loops will be thinner and taller. In other words, the zeros (the crossings of the magnitude spectrum with the axis) become closer to the origin.
Is it acceptable?
Yes this statement looks correct to me, we can infer this statement by examining the behavior of the function ##\frac{\sin(aw)}{w}## as ##a## increases, ##a## is something like the angular frequency of the sin function.
I got it, thank you very much. Then, if I am asked to draw the wave of F(w), can I use Matlab? I tried them. Here they are. Do you think I got it right? I am still not sure how to convert the calculation result in Matlab.
The first screenshot might be the graph of ##\frac{\sin(aw)}{w}## for some ##a##, but I don't know about the second screenshot...Calculations for impedance of an RLC circuit? what those have to do here?
