How Does the DC Component Affect the Fourier Transform of a Signal?
The discussion focuses on the impact of the DC component in the Fourier Transform of a signal, specifically analyzing the system response to H(w) = 10/(jw + 10) with the input x(t) = 2 + 2*cos(50*t + pi/2). Participants clarify that the DC component '2' transforms to 4πδ(w) in the frequency domain, while the cosine term contributes to the overall response. The final output y(t) is derived using the inverse Fourier Transform, confirming that the DC input results in a response of 2 at w = 0.
  • Understanding of Fourier Transform principles
  • Familiarity with delta functions (δ) in signal processing
  • Knowledge of system response functions, specifically H(w)
  • Basic skills in complex numbers and Euler's formula
  • Study the properties of the delta function in the context of Fourier Transforms
  • Learn about the phasor method for analyzing sinusoidal inputs
  • Explore the application of the inverse Fourier Transform in signal processing
  • Investigate the exponential Fourier series and its relation to sampled signals
Students and professionals in electrical engineering, signal processing, and applied mathematics who are looking to deepen their understanding of Fourier analysis and its applications in system response analysis.
  • #31
toneboy1 said:
Since I've just been up all night here, when I stumbled across sin(w) and I was trying to inverse Fourier transform it, I thought I'd done it before, it should be "elementary!", but now looking at it I tried and found myself integrating (from Euler's Identity):
1/2pi * [(exp(2jwt)-1)/2j] ∞→-∞
which obviously doesn't work or trying to use Duality on the table with no success in getting the: j√(pi/2)*[del(t+1)-del(t-1)] that wolfram generated as the answer.
Anyway, a question for another time perhaps.
Thanks for your assistance!
Look at the link I sent you. It tells you how F{sin(wt)} is derived. They use the time-displaced delta function in the w domain in a clever way.
I don't know what field you hope to go into, but if it's electrical engineering I would de-emphasize the Fourier transform and concentrate on the LaPlace. The Fourier comes into its own in optics and statistical control system design (for which the two-sided LaPlace is equally suitable).
  • #32
rude man said:
BTW I like the following site for the Fourier transform:
http://www.thefouriertransform.com/transform/fourier.php
Right'o, I will concentrate on LaPlace because I am in Electrical Eng; I have done more LaPlace a couple of years ago, than I ever have Fourier.
In that link you sent me, I assume the Sinc and the Sin in which you refer are one and the same. I did notice that using l'hospital's rule sinc(0) = 1 for division by 0 which makes sense.
[ On what might be a side note: I'm confused because my Transform table says (using κ for tau) Pof width κ(t) is transformed to κSinc(κω/2pi) but in examples I can see Pκ(t) is transformed into (2/ω)*sin(κω/2) Which would mean that Pκ(t) is transformed into κSinc(κω/2), so where has the pi in the denominator gone? ]To be clear, we're talking about sin(w) FROM frequency domain to time domain aren't we?
(I was trying to use Duality to multiply Sin(w) by 2.pi to get the: j√(pi/2)*[δ(t+1)-δ(t-1)]
Wolfram generated.)
Cheers
  • #33
toneboy1 said:
Right'o, To be clear, we're talking about sin(w) FROM frequency domain to time domain aren't we?
Wolfram generated.)
Cheers
I goofed again. I was thinking F{sin(wt)}, not F-1{sin(w)}. Sorry.
But the technique is similar: think the time-delayed delta function.
  • #34
toneboy1 said:
Right'o, [ On what might be a side note: I'm confused because my Transform table says (using κ for tau) Pof width κ(t) is transformed to κSinc(κω/2pi) but in examples I can see Pκ(t) is transformed into (2/ω)*sin(κω/2) Which would mean that Pκ(t) is transformed into κSinc(κω/2), so where has the pi in the denominator gone? ]
The Fourier transform of a pulse of height 1 and width 2T is F(w) = (T/π)(sin(wT)/wT.
Some folks call sin(x)/x = sinc(x) but I've also seen different definitions of sinc so I avoid that designation in general.
As an aside: you can't let T → ∞ to derive F(1). You have to invoke the delta function.
  • #35
Just experimenting, I noticed if w = 3, width = 2 then
(2/w)*sin(2*w/2) is ALMOST the same as (2.pi/w)*sin(2*w/2.pi),
so you seem right about it being a notational thing, but what I can't understand is that the one with the pi in it seems more accurate because in one instance the number was finite and the other kept going. Can you see why this would be?
H'mm, I'm still not clear, I'll elaborate on where I got stuck:
x(t) = (1/2pi)* ∫ (exp(jwt)-exp(-jwt) /2j)*exp(jwt) dw -∞ to ∞
∴ (1/2pi)* ∫(exp(2jwt)-exp(0) / 2j) dw -∞ to ∞
∴ (1/j4pi)*[exp(2jwt)/2jw - w ] -∞ to ∞
And I'm not sure where to go from here. (especially with your time delay)
Alternatively using duality and linearity I attempted to make
sin(ω) = 2pi*sin(-w)/2pi
inverse transformed into: j.pi/2pi * [δ(1-t)-δ(t-1)] which is wrong according to wolfram.
Cheers for any input!
  • #36
Not sure what you're getting at here.
In the below, where on Earth did you get that equation? You're apparently trying to do an inverse transform on sin(wt)?? On a function containing t ?
I think I need to go to bed! :rolleyes:
Cheers!
  • #37
Cheers!
[I was saying
(2/w)*sin(2*w/2) ≈ (2.pi/w)*sin(2*w/2.pi)
for reasons I cannot reckon]
Woops, good call, it should have been 't'less, I.e:
x(t) = (1/2pi)* ∫ (exp(jw)-exp(-jw) /2j)*exp(jwt) dw -∞ to ∞
Heh, heh, fairenough, Night.
  • #38
toneboy1 said:
[I was saying
Why are you trying to determine F-1{(sin(w)} anyway? Its inverse is not at all a common time function ...
If I had to do it I would study the way sin(wt) was transformed, then try to apply that technique to the inversion integral.
