Fraction decomposition for inverse Laplace
The discussion revolves around solving an initial value problem involving a second-order linear differential equation with a Dirac delta function as an input. The equation is y'' + 2y' + 2y = δ(t-π) with initial conditions y(0) = 1 and y'(0) = 0. Participants are exploring the use of Laplace transforms to find the solution.
  • Participants discuss taking the Laplace transform of the equation and express concerns about decomposing the resulting expression. There are questions about the validity of setting the numerator to a linear form and the implications of the exponential term in the numerator. Some participants attempt to complete the square on the denominator and explore the implications of their findings.
The discussion is ongoing, with participants sharing their attempts and reasoning. Some have provided insights into the structure of the Laplace transform and the challenges of finding the inverse transform. There is no explicit consensus, but several lines of reasoning are being explored, including the potential use of standard Laplace transform results.
Participants note the complexity of the problem, particularly regarding the decomposition of the Laplace transform and the lack of straightforward inverse transforms available in standard charts. There is also mention of the need for a Laplace transform chart to aid in the process.
nateja
Find the solution of the givien initial value problem and draw its graph
y''+2y'+2y = δ(t-π) y(0) = 1, y'(0) = 0
A Laplace transform chart would be very useful
I chose to solve the equation with Laplace transforms. I took the laplace of the whole equation and then solved for the L(y):
L(y) = (e^(-πs)+s+2)/(s^2+2s+2)
I double checked to make sure I didn't make any errors in my Laplace calculation and I did the algerbra correctly. So I have the right equation. However, my issue is now decomposing this equation - how do you do that?
You can't factor out the denominator? and I can't just set the numerator to As+B can I? The e^s term would make that useless...
Any ideas?
and just to explain, π is pi and δ is delta for dirac delta function
I tried to use complete the square on the denominator to see if I could break it up more. I got s = -1 + i and s = -1 - i... so I don't know what to do with that at all. I'll keep trying though...
Any ideas?
If you complete the square in the denominator, you'll get s2 + 2s + 1 + 1 = (s + 1)2 + 1.
Any ideas?
L(y)(s) = exp(-πs)/(s^2+2s+2) + (s+2)/(s^2+2s+2). Can you find the inverse LT of 1/(s^2+2s+2)? If so, getting the inverse LT of exp(-πs)/(s^2+2s+2) is easy, just using some standard results about Laplace transforms. You can look them up for yourself.
I got this. I also noticed my mistake in completing the square and solved that. I got (s+1)^2 +1 for the denominator now.
So I should get the inverse laplace as uπ(t)*t*e^(-t) + ?
I am getting (s+2)/((s+1)^2 + 1) which does not have an inverse laplace in the chart. The nearest thing is laplace of e^(at)*cos(bt) which is not exactly equivalent because the 'a' term doesn't match.
Also,
Laplace inverse of s/((s+1)^2+1) + 2 * 1/((s+1)^2+1) does not work out either.
The first term is close to the laplace of e^(at)*cos(bt); however, it is not exact again. The second term will be 2*e^(-t)*sin(t)
I can't see any way to tinker with the algerbra without adding on new terms and creating more inverse laplaces...
Would adding (1-1)/((s+1)^2+1) to y give you y = uπ(t)*t*e^(-t) + e^(-t)cos(t) + e^(-t)*sin(t)
I'm pretty sure adding 0 is legal. Does that check out with you guys?
