Fracture Toughness: Stress Intensity Factor Formula
  • Thread starter Thread starter Altairs
    Fracture
The discussion centers on the stress intensity factor formula for fracture toughness, specifically K_I(mode I) = beta*nominal stress*(pi*crack dimension)^1/2. Participants explore the implications of substituting fracture toughness K_c for K_I and yield or ultimate strength for nominal stress. Key conclusions indicate that using K_c in place of K_I while considering yield strength suggests simultaneous yielding and fracture, while using ultimate strength raises questions about the significance of crack dimension in both ductile and brittle materials. The consensus emphasizes that K_I is applicable only when an initial crack is present.
  • Understanding of fracture mechanics concepts, specifically stress intensity factors.
  • Knowledge of material properties, including yield strength and ultimate strength.
  • Familiarity with ductile and brittle fracture behavior.
  • Basic grasp of the significance of crack dimensions in material failure analysis.
  • Research the implications of using K_c in fracture mechanics calculations.
  • Study the differences between ductile and brittle fracture mechanisms.
  • Learn about the role of crack dimensions in predicting material failure.
  • Explore advanced topics in fracture toughness testing methods and standards.
Engineers, materials scientists, and researchers involved in fracture mechanics, particularly those analyzing the failure modes of ductile and brittle materials.
Altairs
Reference is to the formula for stress intensity factor :
now the question is that
1.ductile:
if I use the value of fracture toughness K_c in place of K_I and yield strength in place of nominal stress what will the value of crack dimension signify ? Does this mean that both yielding and fracture occurs at same time ?
2.ductile:
if I use the value of fracture toughness K_c in place of K_I and ultimate strength in place of nominal stress what will the value of crack dimension signify ?
3.brittle
please explain. I am getting all these things mixed up.
thx
ANy help here ? :S
I think that you are mixture differents things.
K_I is the stress intensity factor that tells you how your material break if you have a inicial crack.
1.- If you material don't have any crack you can not apply Kic and you use Ultimate streght
2.- If you have a crack, you can not use neither yield or ultimate because is possible that you material breaks earlier.
19K
