Free particle wave function and Ehrenfest's theorem
10 replies · 3K views · last reply
rays
For a free particle stationary state, one would expect the expectation values are constants, for example, <x> (t) = 0. From its one dimensional wave function psi(x,t)= exp(ipx/h-iEt/h)/L^1/2, <x> is undefinied (or zero since x has odd parity).
How does one reconcile the above with Ehrenfest's theorem which states that <x> is a function of time:
<x>(t) = <x>(0) + pt/m?
Thanks in advance for your help!
rays
This applies only to operators that commute with the Hamiltonian.
for a stationary state (energy eigenstate)
psi(x,t)=u(x)exp(-iEt/h)
<A> = integral of psi* A psi dx. The time dependence exponentials cancel each other. <A> has to be time-independent regardless of its commutation properties with the Hamiltonian (there is a proof of it in Sakurai, 2nd ed., Eq. 2.1.45).
From the free particle wave function of momentum eigen state with eigen value of p, psi(x,t)= exp(ipx/h-iEt/h)/L^1/2, how does one prove
Thanks.
rays
Thanks, Demystifier.
I can understand the difficulty with the free particle wave function. But even qualitatively, the Ehrenfest theorem (a time-dependent <x> makes sense to me) contradicts what the free particle wave function says (<x> = 0 at all times).
if Ehrenfest theorem does not apply to the free particle wavefunction, which statements on time-dependency is correct?
rays
No, of course not.
In complete generality, iħ d/dt <A> = <[A,H]> + iħ <∂A/∂t>. Quoting Messiah,
In particular for any variable C which commutes with the Hamiltonian and which does not depend explicitly upon the time, one has the result d/dt <C> = 0.
I've just found out that there is a proof of
x(t) = x(0) + p(0)t/m
for a stationary state free particle in Sakurai (2nd ed. Eq. 2.2.27).
But for any stationary state <x> = const at all times.
rays
Bill_K,
Agree with your post. But the ih<dA/dt> = <[A,H]> is where the Ehrenfest theorem comes from.
In Sakurai 2nd ed, Page 73, it was proved that for a stationary state, expectation value of any observavle (regardless of whether it commutes with H) is independent of time. The proof is given in the following:
|a(t)> = U(t) |a(0)>
for an arbitrary operator B (which may not commute with H)
<B> = <a(0)|exp(iEt/h)Bexp(-iEt/h)|a(0)> = <a(0)|B|a(0)>, independent of time.
If we set B = x, <x> = const.
Using the equation you quoted, if we set A = x, it says <x>(t) = <x>(0) + pt/m, which is the Ehrenfest theorem for a free particle.
Which statement on <x>(t) is correct?
rays
It does not apply to a plane-wave free particle wavefunction. But it may apply to some SUPERPOSITION of plane-wave free particle wavefunctions, which is a free particle wavefunction itself. The superposition must be such that the superposed wave function has a shape of a localized wave packet.
Demystifier,
Thank you. I think I get it this time.
Please correct me if I am wrong: Based on what you said and some research I believe that the free particle wave function (exp(ipx)) is fundamentally flawed since it says <x>(t) = const. With a Gaussian wave packet (which is not an energy eigen state of H= p^2/2m), <x>(t) = <x>(0) + pt/m, regardless of the width of the gaussian function. I guess that the free particle wave function can be considered as a gaussian wave packet with very large width. Then, it no longer contradicts the Ehrenfest theorem as long as one does not really take the width to inifinity.
rays
rays said:
Demystifier,
Yes, now you get it. :approve:
