Possible webpage title: Calculating Frequency Shift for Moving Sound Source
The discussion revolves around calculating the frequency shift of a train whistle heard by a man standing by a rail track, with the man perceiving a frequency of 10419.7 Hz while the train approaches at 39.9 m/s. The student's calculation yielded a frequency of 9207.612 Hz, while the correct answer is 9164.147 Hz. The discrepancy arises from the assumed speed of sound, which is typically 343 m/s at 20 degrees Celsius, but can vary with temperature. The problem does not specify the temperature or speed of sound, leading to confusion in the calculations. Accurate results depend on knowing the environmental conditions affecting sound speed.
buffgilville
A man standing by a rail track, hears the whistle of a train at a frequency of 10419.7 Hertz. The train is moving towards the man at a speed of 39.9 meters/sec. The frequency of the whistle (in Hertz) is
Student response 9207.612
Correct answer 9164.147
frequency heard by the man = [1/(1-[u/v])} * frequency of whistle
u=39.9 m/s
v=343 m/s
frequency heard by the man=10419.7
so, the frequency of the whistle is 9207.612 but the correct answer is 9164.147
What did I do wrong? please help, thanks.
u=39.9 m/s
v=343 m/s
You are right if the speed of sound is 343 m/sec. That assumes temperature of 20 degrees C. If the temperature is 0 degrees C, the speed is 331.4 m/sec which results in factual = 9165 m/sec. What does the problem give for the speed of sound or temperature?
AM
It does not give the temperature nor speed of sound.
