Fresnel Zone Equation Problem
8 replies · 4K views · last reply
sinus
TL;DR
I'm a little confused with the fresnel zone equation, although this topic is more specialized in telecommunications, but since physics is basic knowledge and every advanced science major is based on the laws of physics, so please help me on this one.
In telecommunication system there's a fresnel zone, it's an area between transmitter and receiver (i'm sure all the experts in this forum already knew about that).
So, in this website (Fresnel Zone Calculator - everything RF) provide a Fresnel Zone Calculator, it also tells the equation, which is:
That formula above is obtained from the general equation if using n (fresnel zone number) = 1
Because the website didn't tell the unit of the distance and wavelength (I know the SI unit is meters, but still, incomplete equation without telling the unit can make confuse since there are a lot of conversion of unit), so I search another source, I found in this article Utilization of Trendlines in Determining Antenna Heights for Microwave Communications, and the equation is
For making sure, I check the dimension for both the left and right side, but using the unit instead of the real dimension, it turns out to be false if the distance is in km unit.
From this step, I'm surely use d in unit meters cause the general equations only true if d in meters.
Next, i want to know how to obtain equation 1) from the general equation. So, I did this:
The red bold is when I miss calculate it, so I was happy when I thought I reach my goal to obtain the same equation
So yeah, it become different with equation 1), if it should be same, it must 17.320,51 divided by 1.000, but when I calculate, it multiplies them. Please help me find my mistake calculating this equation.
Note: I also looking any explanation video on youtube, but they only tell the equation 1), didn't explain any further how to get that equation.
Your mistake is not keeping track of units for the number you say is the square root of the speed of light.
sinus said:
TL;DR Summary: I'm a little confused with the fresnel zone equation, although this topic is more specialized in telecommunications, but since physics is basic knowledge and every advanced science major is based on the laws of physics, so please help me on this one.
Because the website didn't tell the unit of the distance and wavelength (I know the SI unit is meters, but still, incomplete equation without telling the unit can make confuse since there are a lot of conversion of unit), so I search [...]
Perhaps the typo in the first image (below) is creating some confusion?
Because I think the speed of light is a constanta. But I give it a try to include m/s^2, but still, it doesn't solve the problem.
In here: [1] and [2], both the frequency is in MHz unit
Source: [1]
Source: [2]
I calculate to check both the right and left side, it turns out that they just same.
I'm still confuse 'cause I can't find the way to obtain Equation (1) from general equation whose had n parameter. There's additional 1.000 that should multiply with 17.32, when in every fresnel zone equation that I see, there's no 1.000
well, it could be.. cause the website give unclear unit that should be use
$$ \sqrt{c}\approx 17.31*10^{3} \sqrt{\frac{m}{s}}=17.31*10^{3}\sqrt{{m Hz}\frac{1 km}{10^3 m}\frac{GHz}{10^9 Hz}}=17.31*10^{-3} \sqrt{km GHz} $$
ohh, thanks Haborix, I used the wrong unit for c with m/s^2, but please, I'm stuck again :(((
Isn't that what you wanted to show? Part of the problem here that makes this confusing is the substitution of numerical values for some constants while leaving variables in the equation. That's not your fault, it must just be the practice in this area of technology.
The consequences of that are pretty scary. In the same way, relying on simulations is also dangerous. Science has only advanced because people stopped just using measured or observed numbers and used symbols to describe the patterns of how things behave. It's a real cop-out to avoid the Maths and to use 'magic numbers'.
