Friction : BLOCKS AND A PULLEY
The discussion revolves around a physics problem involving two blocks connected by a pulley, with friction affecting their motion. The first question addresses the force of friction required to keep the blocks moving together, while the second question seeks the minimum mass of the third block that causes the first block to slip. Participants clarify that the friction force must increase to prevent slipping as the blocks accelerate together. The conversation emphasizes understanding the forces acting on each block and the role of static versus kinetic friction. Overall, the thread highlights the complexities of analyzing forces in a system with friction and acceleration.
judas_priest
A block of mass m1 is on top of a block of mass m2. Block 2 is connected by an ideal rope passing through a pulley to a block of unknown mass m3 as shown. The pulley is massless and frictionless. There is friction between block 1 and 2 and between the horizontal surface and block 2. Assume that the coefficient of kinetic friction between block 2 and the surface, μ, is equal to the coefficient of static friction between blocks 1 and 2.
Q1 : The mass of block 3 has been changed such that block 1 and block 2 are moving together with a given acceleration of magnitude a. What is the magnitude and the direction of the force of friction exerted by block 2 on block 1?
Q2: What is the minimum value of m3 for which block 1 will start to move relative to block 2?
Force of friction exerted by block 2 on block 1 to keep them both moving without one sleeping over another is m3g - μ(m1+m2)g = μm1g Correct me where I'm wrong.
minimum value of m3 for which block 1 will start to move relative to 2 is m3g>μm1g
Therefore, m3>μm1
Both my answers are wrong. Not able to go any where with this. Someone please explaing, and I'll solve.
Take it in smaller steps. You are given that the acceleration is a. What are the forces acting on block 1? If it's accelerating at rate a, what does that tell you about the frictional force between 1 and 2?
Forces acting on 1 is friction between block 2 and block 1 towards left. It is accelerating with block 2, so friction gets stronger to maintain no slipping condition. The friction, since it is static, cannot be μN.
How do I get the value of friction force so that it moves with block 2?
Towards the left on which block? Which way is block 1 accelerating?
Why does the force need toi get stronger to accelerate at a constant rate?
Static/kinetic refers to relative movement of the surfaces in contact. If 1 is not slipping on 2 it's static friction.
You know the mass, you know the acceleration, so what's the force?
I figured out the second part. Could you hint me with the third?
Here's my attempt to the third part:
Since block 1 starts to move relative to block 2, it goes into kinetic friction. therefore:
m1a = mu*m1g. Cancelling m1 would give me the minimum acceleration. How do I relate it to m3?
After drawing FBD for block 2 and 3, and substituting the acceleration for in previous post, I et
(2*mu*m2+mu*m1)/(1-mu)
Is this correct?
Is this correct?
I get something slightly different, Pls post your working.
For block 3:
m3g - T = m3a
For block 2
T - mu*(m1 + m2)g = m2a
From block 1, a = mu*g.
Substituted a in equations of block 2 and block 3.
Where am I going wrong?
Need to learn Latex. Sorry for making it confusing.
You've left out a force on m2.
Which one? I don't see any more horizontal forces. Is it the reaction force of friction on block 1?
Still don't get the answer. What did you get? How did you do it?
Yes. What do you get when you include that?
Okay, got it! Thanks!
Why do not suppose that 1 "feeling" that 2 moves to the right generates a friction to the left to compensate m3g ?
I am unable to decipher your question.
Instead of asserting that 2 generates a friction to prevent 1 to stay steady, why don't you assert that it's 1 which generates a friction to prevent 2 to move ?
We are not concerned (in the last part of the question) with whether 2 moves. The critical point is whether 1 moves with 2 or lags behind. Besides, the friction between 1 and 2 could never prevent 2 from moving.
Hello. I've been working on this problem as well and I have not been able to get my head around both of these questions. Could you please help me? :)
As for a new thread, please post your attempt.
Yes, I have now.
