Friction with two stacked blocks and friction
  • Thread starter Thread starter EEintraining
    Blocks Friction
7 replies · 11K views
EEintraining
Here is the problem:
Block A in the figure weighs 1.05 , and block B weighs 3.90 . The coefficient of kinetic friction between all surfaces is 0.32. Find the magnitude of the horizontal force necessary to drag block B to the left at constant speed if and are connected by a light, flexible cord passing around a fixed, frictionless pulley.See the attachment for a picture.
https://www.physicsforums.com/attachment.php?attachmentid=44607&stc=1&d=1330645523
ƩFx=Max, Friction=uk*n
My FBD for the upper block has N going up MG going down Fk going left and T going right (positive)
My FBD for lower has N going up MG going down (I included both weights) Tension and then both frictions going to the right, and the force required going to the left (which i made positive for this one)
I am not sure what i am missing in solving this. Help me see if I have the right set up please. For the bottem block I have:
Sum of forces in x = M*Ax
Pull - Tension - .32(4.95) -.32(1.05)= M*Ax
For the top block I have:
T-.32(1.05)=M*Ax
Am I correct for these equations, especially in the bottem block where I have subtracted both tensions, I am assuming this is correct because the table exerts friction but so would the top block as it is sliding across the top block.
It is correct if you specify what M*Ax means in both equations.
ehild
M*Ax is mass * accel in the x direction from Newton 2
Sum of forces in x = mass time accel in x
Can you possibly point me in the direction of what i am missing... i have 3 equations with 2 unknowns right now.
Is it the same for both blocks??
ehild
You meant two equation with three unknowns, didn't you?
What do you know about the tension along a single rope ?
Do you know the acceleration if the blocks if they move along a straight line with constant speed?
ehild
Ehild thanks for your help yeah I did mean 2 eq and 3 unknown. After looking at this question that was exactly what I was was missing I must have read it too quickly constant speed tells me exactly what the acceleration is.
You are welcome. :smile:
ehild
