From Indistinguishable to Completely Identical Particles
17 replies · 3K views
ObjectivelyRational
Is it possible to take two identifiably different particles of the exact same type (I previously called them indistinguishable in error?) which have different quantum states (say a different distribution in position or momentum Hilbert space) and physically cause them to have identical states, i.e. exactly the same momentum states and position states and spin states etc. so that they are in physical reality completely identical in absolutely every QM respect?
By possible, I mean is there a mechanism in reality which in principle could do this?
For clarity, I'm wondering about this when the process to remains in QM time evolution without any "measurement" causing any "collapse", just straight forward evolution of QM states... and only secondarily do I wonder the possibility of this using "measurement" or "collapse" in order to do it.
ObjectivelyRational said:
take two identifiably different indistinguishable particles
What do you mean? If they are identifiably different, they are by definition distinguishable!
Sorry I mean to say two different particles of the same type having different quantum numbers... like starting at different places in an experiment.
Corrected the OP, thanks!
This is impossible for fermions because of the Pauli principle. It happens for bosons in Bose-Einstein condensation.
OK so Bosons only.
Does Bose-Einstein condensation involve any "measurement" or "collapse" or is it only according to standard QM time evolution that the two Bosons originally from different positions can undergo Bose-Einstein condensation?
No. It is a collective effect that happens under certain conditions (zero temperature phase transition) and is reversible.
By reversible do you mean that starting with the completely identical particles in the Bose-Einstein condensate, hypothetically, reversing time would separate the distinguishable particles back to their original states (different Hilbert space distributions corresponding to "starting at different places" in the experiment)?
What kind of physical operators can take completely identical quantum states and cause them to become different quantum states through time evolution (here reversed time) without any "measurement" or "collapse"?
So I think this is coming down to:
How could any physical operators take completely identical quantum states and cause them to become different quantum states through time evolution (here reversed time) without any "measurement" or "collapse"?
IF true for some operator, what does it mean for quantum states to be "completely identical".
IF simply false, how can completely identical quantum states ever be achieved with a reversible process from two non-identical quantum states (assuming no measurement or collapse)?I'd appreciate hearing any "insight" from anyone who has the answers.
Reversible is meant in the sense of thermodynamics.
Not an operator, but a zero temperature phase transition. This is the technical term.
You state that "a zero temperature phase transition" can take completely identical quantum states and cause them to be different quantum states through time evolution without "measurement" or "collapse".Can you explain how the process of "phase transition" differentiates between "completely identical quantum states" to cause, as time evolves, different quantum states (without any measurement or collapse)?
Just design a temoral evolution that changes the parameters to cross the phase transition. https://en.wikipedia.org/wiki/Bose–Einstein_condensation
I've taken a look at this.
How do you design a quantum mechanical process that can "change parameters" over time of "completely identical quantum states" in ways which result with different quantum states (absent measurement or collapse)?
Isn't thought QM evolution deterministic (absent measurement or collapse)?
If we look at one of the particles in the "completely identical quantum state" and assuming QM works the way reality does, we apply the Hamiltonian on that state and get a resulting QM state (no collapse) with whatever its probabilities and eigenstates, how can we apply the same Hamiltonian "completely identical quantum state" of another particle with the exact same completely identical quantum state and get a resulting QM state (no collapse) which is different from the first?
The evolution of closed systems, yes. But people manipulate open systems, and every manipulation of knobs and buttons changes the Hamiltonian of the manipulated system. This is the key for all applications of quantum mechanics. Without being able to manipulate the dynamics, quantum mechanics would be completely useless and esoteric.
How does this manipulation by people differ from "measurement" or "collapse" of the particles in the completely identical QM state?
Changing the direction of a magnetic field in a Stern-Gerlach experiment does not constitute a measurement. but it changes the dynamics (and later measurement results) of systems passing the magnet. Similarly for other manipulations.
I like the Stern-Gerlach experiment... is there any example in that experiment where "completely identical quantum states" are "manipulated" (as you put it) so as to evolve into different quantum states (without measurement or collapse)? I cannot recall anything like that in the experiment...
No. I just gave it as the simplest example of how human manipulations change the dynamics of a unitary process.
Now it is up to you to generalize and put the pieces together.
I understand if you do not want to continue discussing this. You have replied many times. I appreciate it.I am still searching for how a unitary process acting on a set of "completely identical quantum states" could possibly cause them to evolve differently from each other (absent any measurement or collapse).
If anyone else can answer that I would greatly appreciate it.
