From solution to mother equation
  • Thread starter Thread starter naviakam
68 replies · 6K views
What would be type of the potential responsible for the following equation:
In post #18 you let slip the crucial fact that your equations in post #1 come from attempts to fit data to readings. From then it was clear that attempting to find an equation that merged them over the whole range of x, as in posts up to that point, were a wild goose chase. Ignore all posts before #18.
Presumably what you have is a plotted curve that looks exponential over one part of the range and polynomial over another part. If so, there is probably no way to merge them into a single analytic expression.
E.g. consider a velocity/time graph for an object falling into water. There is no way to merge the equation for before hitting the water with the the one for after into a single analytic equation.
If my presumption is incorrect then please explain in detail what the situation is. Your response to @Fred Wright in post #30 sheds very little light on how you got your data.
capacitor discharge in a gas produces ions. these ions are measured by magnetic spectrometry in which particles pass through the magnet and curve according to their energy and form tracks on a plastic plate.
from magnetic spectrometry two types of ion spectra are obtained (not from a single discharge but from two separate discharges). the initial condition is similar for both discharges but two different spectrum are produced: one fits with power and the other with exponential fit.
what I am looking for is to guess the corresponding potential responsible for such spectra!
What is the difference?
You wrote that y is a number of ions and x is an energy. Does that mean y of the ions have energy x? If so, is that as a histogram, i.e. y is a count of ions in some energy range around x?
Just how good is the fit? How many datapoints? What value of n do you get?
Can you post the data in machine-readable form?
haruspex said:
Ok, so y is the log of the intensity?
As I asked, what is the power (n) in that fit, and what is the difference between the two runs?
1. yes y is the number of ions.
2. n=4
3. the difference is the gas pressure in which the capacitor discharges:
at 6mbar the spectrum fits with exp
at 10mbar it's a power fit
The "power fit" graph you posted is log-linear, so is y in the power equation the number of ions (intensity?) or the log of the number?
And does this mean your exponential graph is also after taking logs, so you really have log(intensity) is negative exponential?!
naviakam said:
n=4
Exactly?
So the full story is y=y(x,p), where p is the gas pressure.
Extremely artificially, you could write
##y=P(p)y_1(x)+(1-P(p))y_2(x)##, where P(6mbar)=0 and P(10mbar)=1.
I'm not seriously suggesting that would be valid, but you get the idea.
haruspex said:
The "power fit" graph you posted is log-linear, so is y in the power equation the number of ions (intensity?) or the log of the number? If you were to plot x-4 on log-linear I would expect a straight line.
Exactly?
1. it's been plotted in log format, y is number only not log
2. 3.8<n<4.1
3. then what is the estimated potential leading to each term in the equation ##y=P(p)y_1(x)+(1-P(p))y_2(x)##?
Why would you plot it log-linear if trying to demonstrate a power law fit? Plot y-y0 log-log against x, or plot y-y0 against ##x^{-4}##.
As I wrote, I am not seriously suggesting that is the correct form. I was just showing you how, given a function of two variables, the dependence on one might look very different for a different value of the other. To get any reliable sense of what is going on you would need results for several intermediate values of the pressure.
Anyway, what is this potential you are asking about? The voltage on the capacitor? Some potential function?
I was wondering if from the spectra we can guess a general potential function for each of the following equations:
As I indicated, I don't know what you mean by a "potential function" in this context.
Perhaps you could illustrate by starting from the other end: pick some example of such a function and show what y=f(x,p), or differential equation, it would lead to.
Also, please post your "power fit" data as a graph of ln(y-y0) against ln(x).
1. the capacitor discharge voltage is 10 kV, but ions are accelerated to MeV by an unknown potential. Then we try to guess this accelerating potential (starting from the other side: from spectra to potential!).
2. " pick some example of such a function and show what y=f(x,p), or differential equation, it would lead to. "
Would you please help me how to do this.
3. here is the raw data:
1026.35 2.12E+10
973.90 2.28E+10
925.86 2.53E+10
881.75 2.73E+10
841.16 3.43E+10
803.73 4.18E+10
769.15 5.28E+10
737.15 6.57E+10
707.47 8.61E+10
679.92 1.15E+11
654.29 1.42E+11
630.42 1.89E+11
608.16 2.57E+11
587.38 3.53E+11
567.95 4.66E+11
549.77 6.18E+11
532.74 8.32E+11
516.77 1.10E+12
501.78 1.52E+12
487.70 1.90E+12
474.47 2.60E+12
462.02 3.33E+12
1026.35 2.12E+10
973.90 2.28E+10
925.86 2.53E+10
881.75 2.73E+10
841.16 3.43E+10
803.73 4.18E+10
769.15 5.28E+10
737.15 6.57E+10
707.47 8.61E+10
679.92 1.15E+11
654.29 1.42E+11
630.42 1.89E+11
608.16 2.57E+11
587.38 3.53E+11
567.95 4.66E+11
549.77 6.18E+11
532.74 8.32E+11
516.77 1.10E+12
501.78 1.52E+12
487.70 1.90E+12
474.47 2.60E+12
462.02 3.33E+12
Are these the data that you claim a power law for?
For those data I get a decent straight line fit between ln(I) and V. Just a bit of a curve at one end. Looks like I is proportional to exp(-0.02V).
If it is not the "power law" data, please post that too.
This data and many others fit well with power law without any curve at the end.
However what I want to know is that if we have power law and exponential equations (as stated in post #39) how we can assign a potential function to them? This is what we need to present to the class! Please help on this.
Thanks
Do you mean a power law or a polynomial?
As I keep telling you, I don't even understand that question. Presumably you do have some idea of how a potential function would lead to an intensity versus voltage function, so give me an example. Pick some arbitrary potential function and show what I=f(V) it would lead to.
If we have ##Y=KX^{-n}## where Y is number of particles and X is their energy.
Then we have a potential like ##V=CI^{4}## where V is the potential, C is a constant and I is the current.
The potential lead to the particles to be accelerated!
How this two equations could be related mathematically?
What current is this? Is it the current carried by the flow of ions?
If so, seems to me that you are not looking for a "potential function" but rather two functions of potential: how the current (rate of ions) and the energy per ion depend on an applied potential.
I.e. I=I(V) and E=E(V) lead to an observed relationship between I and E, and you want to find out what I(V) and E(V) are.
Am I close?
Am I close?
Yes you are right, then how it is formulated mathematically?
There is clearly no unambiguous way to extract two relationships from the one, but an obvious guess is that in a vacuum the energy would be directly proportional to the voltage, leaving you with a simple way to extract the relationship between voltage and current from the observed data.
But you got different results at some other pressure, so this is not a vacuum. Presumably the gas present saps some of the KE, but should not affect the current.
Not sure how to calculate I(V) and E(V).
##E=ItV, V=CI^{4}, Q=KC^{-n}, Y=KE^{-n}##
Then
##Y=Q(I^5tV)^{-n}##
resulted in
##V=(QY)^{-n}(I^5t)^{-1/n}##
where t is the time, E energy, Y intensity, V potential, Q constant, I current.
If correct how it is written more in the math style?
What if the equation in post #39 is considered, how rewritten considering such potential?
naviakam said:
##E=ItV, ##
Isn't E here the energy of an individual ion?
But I am worried about my earlier interpretation. Your data say the current (ions per unit time) and energy (per ion) are negatively correlated. I cannot imagine what physical set up would lead to that. An applied potential that increases one should increase the other, no?
Is it possible for you to provide a far more detailed description of the apparatus? What is being varied to get the different readings?
I assume the two columns in the data you posted are respectively x, y.
I just tried plotting y against x-4. Nothing like a straight line.
Please post exactly what power law equation (constants included) you get for the relationship.
It is a plasma device called plasma focus consisting a chamber and electrode assembly of anode at the center and cathode around it. capacitor discharge (10 KV) in the gas filled the chamber accelerates the ions to MeV with the spectrum I sent the data earlier. The intensity of low energy ions are high and decreases with energy by ##E^{-n}## where n is around 4.
This is another plot with power law fit in origin for the same device:
##Y=KX^{-n}## where ##K=6.8*10^{23}## and ##n=4.56##
I need the raw data and the power law equation you believe fits it for the same data.
The fit above doesn't look that great to me.
power law was mentioned above and the data is:
1106.16 1.20E+10
1048.02 1.19E+10
994.96 1.27E+10
946.43 1.48E+10
901.95 1.92E+10
861.07 2.17E+10
823.44 2.79E+10
788.72 3.35E+10
756.65 4.31E+10
726.96 5.83E+10
699.44 7.19E+10
673.89 8.53E+10
650.14 9.91E+10
628.04 1.17E+11
607.45 1.32E+11
588.24 1.54E+11
570.31 1.79E+11
553.55 2.07E+11
537.87 2.30E+11
523.20 2.74E+11
509.46 3.13E+11
496.58 3.45E+11
484.51 3.91E+11
473.18 4.23E+11
462.54 4.83E+11
452.56 4.94E+11
1106.16 1.20E+10
1048.02 1.19E+10
994.96 1.27E+10
946.43 1.48E+10
901.95 1.92E+10
861.07 2.17E+10
823.44 2.79E+10
788.72 3.35E+10
756.65 4.31E+10
726.96 5.83E+10
699.44 7.19E+10
673.89 8.53E+10
650.14 9.91E+10
628.04 1.17E+11
607.45 1.32E+11
588.24 1.54E+11
570.31 1.79E+11
553.55 2.07E+11
537.87 2.30E+11
523.20 2.74E+11
509.46 3.13E+11
496.58 3.45E+11
484.51 3.91E+11
473.18 4.23E+11
462.54 4.83E+11
452.56 4.94E+11
Is this the data that goes with the equation in post #55?
Yes.
##Y=P(p)Y1(E)+(1−P(p))Y2(E)##, where P(6mbar)=0 and P(10mbar)=1.
How to calculate Y(V) and E(V)?
Potential is ##V=YE/It##.
where t is the time, E energy, Y intensity, V potential, I current.
