girts
- 185
- 22
Please move this if it belongs to other subforums.
So i thought about some other stuff and then somehow this idea appeared to me, now according to physics it is impossible to communicate information faster than the speed of light through vacuum which is "c".
So for any two bodies moving in opposite directions with great speed so that the total sum of the speeds exceeds c it would be impossible to send EM radio signals between the bodies as he signals could not reach the other traveling body.
So please look at this thought experiment, what happens if we have say a train but instead of traveling in a straight line it would travel in a circle, as it travels around the circle there are 4 stations set 90 degrees apart, say the train somehow manages to travel faster than c with respect to an observer located at either of those stations as the train passes them by, the observer wants to send a direct radio message to the train (assuming there is vacuum) but since the train ravels faster than c the radio signal can't reach the train, so the observer sends the radio signal to the center point of the circle which has a certain radius to the observer and has a radio station located in it. from center the signal gets redirected to the train, and the train can respond back via the same path through the center,since the train is always a fixed distance (radius) away from the center point and so is the observer then given those distance are not very long they will be easily traveled by the radio signal traveling at c, so even though the observer can't reach the train for those 180 degrees from the point where it passes the observer to the point where the train crosses the midpoint, redirecting through the middle can solve this problem.
Please see the attached image,
my question is this does this is a violation of the FTL rule or does this not count because the two observers are not traveling on a straight line in opposite directions ?
