Function that returns 1 when x = 0 and 0 otherwise
  • Context: Undergrad
  • Thread starter Thread starter scikidus
    Function
10 replies · 3K views
scikidus
"Dual-output" Function?
This isn't homework: I am experimenting with factorization.
Does anyone know of a function f(x) which for some value of x returns one value for f(x), but for every other value of x returns some other value?
Example: I'm trying to find a function f(x), where
x = 0, f(x) = 1
x != 0, f(x) = 0
My function is only dealing with non-negative integers, if that helps.
I've already derived a function that does this, but it uses absolute values, which is a nuisance.
Anyone know of anything like this?
For reference, here is my formula:
[tex]f(x) =\frac{1-\frac{\left|2x-1\right|}{2x-1}}{2} = \frac{\left|4x-2\right| - 4x-2}{8x-4}[/tex]
Mathematics news on Phys.org
x = 0, f(x) = 1
x != 0, f(x) = 0
That's the characteristic function of zero (Sloane's http://www.research.att.com/~njas/sequences/A000007 ). But your post seemed to focus on giving it a closed form. Why?
What exactly do you want? When you say "f(0)= 1, f(x)= 0 if x is not 0" you have already defined a function. And if you want a closed form, why is absolute value a "nuisance"?
Thanks to those who have responded, you've helped a lot.
@Vid: The link you supplied helped me solve another problme I was working with, so thanks.
@CRGreathouse: That, too, is of great help. I wasn't sure if 0^0 would be considered defined, but that greatly simplifies my procedure.
@HallsofIvy: Yes, that techincally defines a function, but I was looking for a mathematical equation which would supply that result. Two ways are the one I supplies in ym OP, and f(x) = 0^x.
Also, I called absolute value a nuisance because I am build an equation and I need to then invert it. If there are absolute values, then things get very tricky, by which I mean impossible to solve.
It's interesting you decided f(x)=0^x is an equation that gives this, since 0^x has to be defined at x=0 separately anyway, so you haven't really gained anything. And there's no way in hell you're going to invert this sucker
This function (regardless of whether you view it as a closed-form equation or not) can't be inverted. f(9) = f(3) = 0, so what would f^-1(0) be?
Terribly sorry, I misspoke/posted. By "invert," I meant not the function, but the final equation that I'm working on.
Yes, but inverting the final equation will involve inverting that special function.
Actually, I've decided that using the characteristic function of 0 essentially allows you to build piecewise functions, so perhaps you can simply invert piecewise.
If your function only needs to be defined over the integers, you can try
[tex]f(n) = \frac{\sin \pi n}{n}[/tex]
