Fusion and Nuclear Weapons Proliferation?
  • Thread starter Thread starter Delta Force
    Fusion Nuclear
The discussion centers on the potential for fusion technology to influence nuclear weapons proliferation. Experts assert that while the technology for pure fusion bombs exists, it offers no significant advantages over conventional explosives. Deuterium and tritium are identified as the primary fuels for fusion reactors, with deuterium extracted from heavy water, which is more accessible than highly enriched uranium or plutonium. The consensus is that advancements in fusion technology will not lead to increased proliferation risks, as the engineering challenges and the nature of fusion reactions limit weaponization potential.
  • Understanding of fusion reactions, specifically deuterium-tritium (D-T) reactions
  • Knowledge of heavy water reactors and their role in producing tritium
  • Familiarity with inertial confinement fusion (ICF) and magnetic confinement techniques
  • Basic concepts of nuclear weapon design and proliferation risks
  • Research the engineering challenges of fusion reactors and plasma confinement techniques
  • Explore the implications of deuterium and tritium availability on nuclear proliferation
  • Study the differences between pure fusion bombs and conventional nuclear weapons
  • Investigate the role of heavy water reactors in tritium production
Policy makers, nuclear physicists, defense analysts, and anyone involved in nuclear energy or non-proliferation discussions will benefit from this analysis of fusion technology and its implications for nuclear weapons proliferation.
Delta Force
Some experts claim that the technology to create pure fusion bombs already exists, although the resulting device wouldn't result in any real advantages over conventional explosives (source).
Deuterium and tritium are also considered the most likely fuels for a fusion reactor. The deuterium would likely be extracted from heavy water (interestingly, heavy water reactors are also well suited for producing tritium and plutonium), which isn't really that rare or exotic a material, certainly not when compared to highly enriched uranium or plutonium, and it would likely be less expensive and more readily available if used as a fusion fuel.
If fusion power were developed could improved knowledge of the fusion reaction process and the ready availability of deuterium lead to a situation of increased nuclear weapons proliferation?
Generally called Hydrogen bombs and they have already been proven and do exist. The largest made and tested H-Bomb was by the Russians at 50 Megatons.
No, he's referring to a fusion bomb that does not use a fission explosion as a trigger. See the Wikipedia article he links to as his source.
Yeah, it takes so much conventional explosive to ignite a small fusion target that there is not much point in making the explosive that way. A fuel-air explosive is much a much more practical way to make bigger explosions...
It wouldn't seem so. Advances in ICF will still be confined to pretty small fusion targets (with giant lasers required), and magnetic confinement wouldn't seem to offer anything that could be weaponized, IMO.
If fusion reactors based on DD reactions are developed, that will likely "lead to a situation of increased nuclear weapons proliferation", but not because of new techniques to generate fusion. The neutrons from the DD reactions can be absorbed in U238 to produce Pu239, and the tritium from the DD reactions can be removed for use in nuclear weapons.
Not a scientifically reliable source.
d+t is the easiest reaction to obtain, since it has higher cross-section at the lowest temperatures. d+d would be more preferable, as would aneutronic reactions such as d+3He or p+11B.
One of the problems with mixed-gas systems is that there are side reactions, and when Z increases, the energy losses from various radiation mechanisms increases.
We know a lot about fusion reactions. The challenge is in the engineering, which usually requires large EM-mechanical systems to confine and heat the plasma. Fortunately, that does not lend itself to weapons.
In short, the answer to the question is, No!
  • · Replies 0 ·
  • · Replies 66 ·
23K
  • · Replies 36 ·
15K
  • Poll Poll
