Gaah finding a power series out of a function
geomajor
1. Express the function as the sum of a power series by first using partial fractions. Find the interval of convergence.
f(x)= (7x-1)/(3x^2 +2x-1)
2. using the fact that 1/(1-x) =\sum from \infty to n=0 of x^n and the interval for convergence of that is (-1,1)
3. I know that (7x-1)/(3x^2 +2x-1) can be factored to (7x-1)/(3x-1)*1/(1+x).
So, using the idea of partial fractions and the method for changing functions into power series, 1/(1+x) would become 1/(1-(-x)).
Let u=-x so that \sum from infinity to n=0 is (-1)^n*x^n , interval of convergence is (-1,1).
But I know don't know how to do (7x-1)/(3x-1). Is there some way to rewrite that? Like (1-7x)/(1-3x), but I still wouldn't know what to substitute...(-7/3)x? At the end I would have the sum of two series, right?? Help...
Well you can use (7x-1)/(3x^2 +2x-1)
to be equal to \frac{A}{3x-1} + \frac{B}{x+1}
\frac{A(x+1)+B(3x-1)}{(3x-1)(1+x)}=\frac{7x-1}{(3x-1)(1+x)}
then equate numerators and find the values for A and B
then put the 2 partial fractions as power series and use the operations that you can do on a power series to put them into one complete series
Okay, so I have 1/(3x-1) + 2/(x+1)
when I went through and did all the work, I got this
(1/2)\sum(-1)^n(x)^n - \sum(3)^n(x)^n
Now when I put them together would I get ...
(-1/2) \sum[(-1)^n -(3)^n]x^n ...?
I'm not sure about that 1/2 thing... because I'm not sure if 2/(1+x) really = (1/2)\sum (-x)^n. I want to know for sure because I have an exam in a couple days and my professor had to rush over the last few things we learned about series, which leaves me worried about making stupid small mistakes that could be easily avoided!
well if you can represent \frac{1}{1+x} = \sum_{n=0}^\infty (-1)^nx^n then 2/(1+x) should be 2 by the power series
oh duh! 2 not 1/2! I don't know what I was thinking...
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
