Galilean relativity for 2 frames
52 replies · 5K views
gionole
TL;DR
Just want to see if I'm correct
Learning Galilean transformation and just want to see if I understand the concept well.
both frames are moving relative to some other frame(me standing all the time, not moving). frame A moving 5m/s, frame B moving 7m/s, which in turn means frame B moving 2m/s relative to frame A. Galilleo says: x=x′+vt. As far as I understand, x′ coordinates starts from frame B and x starts from frame A(and not from my origin - I'm standing). This means that frame B's object is always at x′=0 in its own frame, whereas frame A's object is at x=0 in its own respective frame. The distance between the objects is definitely vt. Also x coordinate system goes and even covers x′ coordinate system. We can also choose some point in frame B which's coordinat will be x′ in its own frame and x from frame A. Then we can write x=x′+vt.
Including the image ! I just want to see whether my 2 statements are correct.
* that if 2 frames are moving, in the real world case, this means 2 objects are moving relative to each other and their coordinates in their own frames always will be 0. It's just gallilean's formula is much more general and choosing some other points in the frame B for example.
* If x coordinate starts from frame A as shown on the image.
I think you have the right idea. A reference frame is essentially a system of coordinates. The principle of relativity says that the laws of physics are valid in all inertial reference frames. And, inertial reference frames differ from each other in terms of a uniform velocity between them. Also, generally we take the origin of the reference frames to coincide at time ##t =0##.
That means that if ##A## and ##B## are inertial reference frames, then (for some velocity ##v##):
$$x_A = x_B + vt$$where ##t= t_A = t_B## is the common time coordinate.
Now, for an object moving inertially, we can find define an inertial reference frame where the object remains at the origin. This is often described as the "rest frame" of the object. That said, once you have a specific object at the origin of a reference frame, you need to potentially allow an offset at time ##t = 0##:
$$x_A = x_0 + x_B + vt$$Because ##A## and ##B## may not be at the same place at ##t = 0##.
Thanks for the great analysis.
Whats the thing that seems wrong in my statements or in my image ? Just making sure I dont miss something
There was nothing wrong. You don't need a third, baseline frame (your "me" frame). And, just to clarify the relationship between reference frames and objects. Note that several objects all at rest relative to each other share a rest frame (in one sense), but they can't all be at the origin. You just need to note that.
Reply
I think this is an example of the 2 frames moving at the same speed where frames’ origins are not the same. In my image, if frame A and B moving at the same speed then we can say they are at rest. But In that case, v would be 0. And x would be equal to x’ which would not be the case as they are separated by some distance from the beginning. I think you meant something else which I dont think I understood but is it that important ? I mean in my examples, if v=0 then the only time galilean works is if from the beginning, frames started at the same origin.
More generally ##x' = x_0 + x + vt##. You can't in general ignore the ##x_0##. Only in cases where the origins coincide at ##t = 0##.
Reply
@PeroK After thinking some more, I realized 2 questions related to frames. If you don't mind, I'd appreciate it and thats pretty much it on this subject.
We know that inertial frame in a nutshell means:
  1. the velocity is constant(no acceleration) or
  2. there's an acceleration, but the acceleration can be explained by real force(no fictitious force needed). Newton's law will hold true in this case
It's said that galillean transform makes sense for only inertial frames.
Question 1: In my image, how do we define inertial frames ? should the inertial frame be in respect to their own ? for example: frame A can be inertial from its own point of view, but could be non-inertial from frame B's point of view. Which one should hold true ?
Question 2: Does galillean transform work for my (2) case above ? I wonder how, if frame B's acceleration is present, ##vt## won't be the distance anymore. Wouldn't this break ? can we then assume it only works for when both frame's velocities don't change ?
A reference frame is either inertial or non-inertial. The test is whether Newton's first law holds. This is an intrinsic property of the reference frame. It's not relative to anything else.
The surface of the Earth is approximately an inertial reference frame. We have to ignore the rotation of the Earth and technically all objects are subject to the force of gravity. The rest frame of an elevator moving up at constant speed is also approximately an inertial reference frame. These two frames are related by a single relative velocity; and their coordinates are related by a single parameter representing this velocity.
The rest frame of an accelerating vehicle is not an inertial reference frame. Newton's first law does not hold (even approximately) in this frame. The rest frame of a merry-go-round is not an inertial reference frame.
Note the following subtle point.
An inertial reference frame is one where Newton's first law applies. But, there is no concept of a velocity associated with an inertial frame. Two inertial reference frames have a relative velocity, as above, that appears in the Galilean transformation of their coordinates.
Likewise, there is no concept of a velocity associated with a non-inertial frame. Instead, there is a real (measurable) acceleration associated with such a frame.
Note also that all velocities are relative. There are no absolute velocities in Newtonian physics. But, in general, acceleration is absolute - in the sense that acceleration is absolutely measurable and is the same in all inertial reference frames. This is encapsulated in Newton's second law:$$F = ma$$Where all three quantities are invariant, which means they are the same in all inertial reference frames. Mathematically, if we have two inertial reference frames whose coordinates are related by:$$x' = x_0 + x + vt$$Then$$\dot x' = \dot x + v$$This is the relation between velocities (of a particle, say) as measured in the two frames. And$$\ddot x' = \ddot x$$And we see that the same acceleration (of a particle) is measured in the two frames.
The invariance of Newton's second law is critical. It's fundamentally important that acceleration does not depend on the choice of inertial reference frame.
By first question, I think you didn't fully get my point. What I asked was car moving with acceleration is a non-inertial frame, but seeing it from road, the road becomes inertial frame. I guess, the frame itself should be inertial from its point of view and not from point of others(I also understand that frame seen from another frame doesn't say anything in terms of what the original frame is). accelerated car is thought to be the non-inertial frame for Galilleo.
So if an object accelerates, from its own frame, it's never going to be inertial frame. That's what I arrived to because in the object, we can always imagine something else for which newton's law won't hold true. (example - car=our object and pendulum=our imagined something in the object and for pendulum, newton's law fails from car's frame)
Let's say frame A and B are both accelerating by the same uniform acceleration. In their own frames, they're non-inertial. one accelerates by 2, second accelerates by 4. Now, we got relative acceleration = 2. So each second, relative velocity between these changes by 2. Writing ##x' = x - vt## seems not to work, because we don't have the relative velocity as it changes. I mean, if you come up with a function for relative velocity, ##v = 2t##, then it works, but in terms of galillean, do we say this is enough or if not, why not ?
First, a car is an object, not a reference frame. Second, whether a reference frame is inertial or non-inertial does not depend on "who's looking at it". You can't look at a frame. A frame is a system of coordinates.
It's like asking if an apple is an apple from an orange's point of view. Or, from its own point of view. An apple is an apple, regardless of how you look at it.
No. You are misunderstanding the whole concept of a reference frame. It is NOT an object.
Reply
To me, reference frame is the point of view. What I mean by when I say accelerating car is an non inertial frame is that from car’s point of view, car is non inertial. If as you say car is not a reference frame, what do you call non inertial frame when car is in accelerating mode ? Lots of examples mention that when car accelerates, road is an inertial frame and car as non inertial. You can call an non inertial frame to be system of coordinates, but in nutshel, when we say car is non inertial, i mean that there exists a car frame(point of view seen from inside the car).
One should add that there can nothing go wrong with using a third auxilliary frame, because the Galilei transformations form a group. That's why symmetries are (usually) described by transformations build a group.
Further Galilei symmetry follows from the spacetime model of Newtonian mechanics. In modern terms you can state the Lex I as that there exists an inertial frame. Together with the usually not explicitly mentioned demands that (a) time is absolute (i.e., up to arbitrary choices of an "initial time" (time-translation invariance, as one subgroup of the Galilei group)) independent of the choice of the inertial reference frame and (b) that space for an inertial observer obeys the laws of Euclidean geometry.
Choosing the spacetime model implies restrictions to the physical laws, i.e., that they must be consistent with the symmetries of this spacetime model, and this explains why Newtonian mechanics looks the specific way it looks.
Finally you can use any non-inertial frame of reference too. The distinction from inertial frames is that then the physical laws do not take the same form as in inertial frames (i.e., there occur additional terms when expressing the acceleration of the particles in the coordinates of the non-inertial frame, which usually a reinterpreted as additional "inertial forces"), but they are still the same physical laws, and according to Lex I you can always introduce an inertial frame of reference to describe the physics in this inertial frame of reference, and there the laws take the specific form as they must take in inertial frames.
It's like asking if an apple is an apple from an orange's point of view. Or, from its own point of view. An apple is an apple, regardless of how you look at it.No. You are misunderstanding the whole concept of a reference frame. It is NOT an object.
This is also a bit misleading. All the mathematics of Newtonian mechanics must be realized for their experimental observation in the real world, and thus you need to operationally construct a reference frame with real-world objects, e.g., three (rigid) rods fastened at a point pointing in three different directions, defining 3 coordinates for each point in space, and an arbitrary clock to define time (in Newtonian physics due to the absoluteness of time, a single clock is sufficient to define a synchronized time at all points in space). Only with such a operational realization of a reference frame (consisting of a clock and three non-coplanar rigid rods) you have a clear meaning of the four spacetime coordinates occurring in the math of Newtonian mechanics.
Given the fact that there is indeed no absolute space and time, it's not so trivial to a priori define an inertial reference frame. Usually in everyday work we just use a frame fastened at a point on Earth and work with the so defined coordinates as if this were an inertial frame of reference, which of course is not true, and we can nicely demonstrate this with the Foucault pendulum experiment, demonstrating that the frame is rotating against the class of inertial reference frames (due to the rotation of the Earth around its axis).
According to our best contemporary knowledge the best realization of a (local) inertial reference frame is to use a frame which is moving with constant velocity against the "thermal bath" of the cosmic microwave background radiation. With this, however, we enter the much more delicate issue of (inertial) reference frames according to General Relativity.
An object moves either inertially (no external force) or non-inertially (real external force). If an object is moving inertially then you can define an inertial frame with that object permanently at the origin. This is called the object's rest frame.
We can start by assuming that the road is moving inertially (this is not quite true, but it's a good approximation for most purposes). More precisely, we take the surface of the Earth locally to be an inertial reference frame.
If a car is moving with constant velocity relative to the surface of the Earth, then we know that the car is moving inertially. And, the car's rest frame is an inertial reference frame - in which Newton's first law applies. [Note that you haven't mentioned Newton's first law regarding inertial reference frames, which is a problem.]
If a car accelerates relative to the surface of the Earth, then it must be moving non-inertially. And we know that there must be a measurable, real external force on the car. And, the car's rest frame is a non-inertial reference frame, where Newton's first law does not hold.
Taking about a car's "point of view" is a little sloppy, IMO. What is a "point of view"? If you are in an accelerating car, then you know you are accelerating: you can feel the external force. Are you accelerating or not from your poin of view? Instead, it seems clearer to me to say that your rest frame is non-inertial. You can define your rest frame relative to the surface of the Earth. For uniform acceleration you have:
$$x_{car} = x_0 + v_0t + \frac 1 2 at^2$$Where ##a## is the (real) acceleration of the car. And ##x_0## and ##v_0## are its initial position and velocity relative to the surface of the Earth.
You need to start thinking in terms of Newton's laws and basic, 1D coordinate systems. Introducing fuzzy terms like "point of view" may be leading you astray.
Reply
Let me give you the idea of what I mean by point of view.
as we know, there can be multiple frame of references that we can construct for the accelerating car. Frame of reference is the point of view so there is a ground frame that exists for a car which means things/point of view seen from the ground. Alternatively, there is a car frame which is the point of view seen from inside the car. I know car itself is not a reference frame, but we kind of need to imagine expressing it like that because we are curious whether laws in the car seen from the car’s point of view obey newton. That is why I said car is an non inertial frame. Ofc, I get that frames cant see each other in a way to say that if I am a ground frame, I cant just look at car and say it is a non inertial frame.
So when we say frames moving and having velocities and so on, we mean that each frame is such a frame seen from its own. You can say it is a system of coordinates, but to me, it seems easier that in galillean, we focus on the object’s frames itself and dont look for other frames such as ground frame. So in a nutshell, when 2 objects move, their frames that we talk about in galillean is the frames seen from their point of view respectively. This kind of makes things easier for me. I think what you call rest frame, I call own frame and we must be saying the same thing in the end.
Now what I arrived to now is for the galillean transform to work is that frames should be inertial. If car moves, it should be inertial frame and the only time this can be true is if its not accelerating because if it does, it becomes non inertial and I brought example as pendulum inside an accelerating car.
Reply
  • Skeptical
  • Sad
Sure, if you have a car that is accelerating against the inertial reference frames and use its rest frame, that's not an inertial frame of reference. You can do that, but then to transform to the coordinates defined by this non-inertial frame you cannot use a Galilei transformation, but it's a different transformation, and then the natural laws take a different form than when using coordinates defined by an inertial reference frame. Nevertheless they are still the same physical laws.
vanhees71 said:
... you need to operationally construct a reference frame with real-world objects, e.g., three (rigid) rods fastened at a point pointing in three different directions, defining 3 coordinates for each point in space,...
One can define an infinite number of different reference frames for analysis based on a single physical object, therefore using the term "reference frame" for both is just confusing. We had this discussion before.
Why is it confusing? Any such construction with real-world "clocks and rods" defines a frame of reference. If you arrange them in different ways you just use different frames of reference. If you find this confusing, you have to think a bit longer about it. It's at the very beginning of any learning of physics. Without a clear understanding, how reference frames are operationally defined and relate to the coordinates used in theory, there's no clear understanding of physics. Physics is more than just an axiomatic scheme defining the math of some physical theory!
Reply
Perok had difficulties to what I was saying by "point of view" = "reference frame". Do you find this confusing as well ? I don't know. Physics use lots of complicated words sometimes and I'm just a beginner trying to understand it intuitively. I'm not sure why I shouldn't be trying to imagine things in a clearer way.
Funny thing is when I said: by point of view seen from the car, it appears to be the same as "rest frame" mentioned by you guys.
If I'm in a car and the car accelerates, from my point of view, car didn't accelerate, just look at the ceiling, did it accelerate ? no. but i still felt the force even without acceleration and newton fails which is why from my point of view or car's point of view to itself, it's a non-inertial frame. I repeat that what you call "rest frame" seems to be the same what I call: "point of view of the object to itself".
Reply
  • Sad
Because it's not clear if by "reference frame" one means an abstract set of coordinates or an actual physical object.
Any such real-world construction can be used to define infinitely many abstract frames of reference. There is no 1:1 relationship.
I don't need to arrange the physical object differently. I can just specify how my abstract reference frame moves relative to the physical object.
A reference frame is an actual set of physical objects (something that defines the set of spatial coordinates and a (set of synchronized) clocks). Coordinates are coordinates, reference frames are reference frames. Nothing is confusing here.
If this were so, we had not well-defined physical theories, which obviously is not true. Of course, any properly constructed phsical reference frame leads to a 1:1 relationship (at least locally) between space-time points and space-time coordinates. That's implicit in the definition of what a reference frame is.
It's the other way round: To describe, how a physical object moves in terms of space-time coordinates, you need a reference frame. All motion is always relative to other objects, and to have a 1:1 correspondence (at least locally) between space-time coordinates of the object(s) under investigation you need a reference frame these space-time coordinates refer to.
I don't say, it's a simple concept, but it's also not confusing. You just need to think about it carefully!
The "... to itself" part is not included in "rest frame". The rest frame of the car can be used to analyze objects on the ground too. Just say "rest frame". It's shorter and avoids confusion.
Reply
We had this discussion before:
https://www.physicsforums.com/threa...nflict-of-two-definitions.990480/post-6359096
PeterDonis said:
I think a key issue needs to be clarified for this discussion: the term "reference frame" can be used to mean multiple things in physics. In particular, it can be used to mean any of the following three things:
(1) A coordinate chart;
(2) A frame field (i.e., a mapping of points in spacetime to 4-tuples of orthonormal vectors, one timelike and three spacelike);
(3) A concrete measuring apparatus that physically realizes #1 or #2.
These are three distinct things that should not be conflated.
You seem to misunderstand what I mean:
Using a single physical rod-set one can define multiple abstract frames of reference:
Frame A, where the rod-set is at rest.
Frame B, where the rod-set moves at 1 m/s along the X-axis
Frame C, where the rod-set moves at 2 m/s along the X-axis
And for every of those frames one can define multiple coordinate-charts, for example by rotating the axes by 90°.
So there is no 1:1 relationship between "physical object" and "abstract reference frame defined based on that physical object".
Reply
I'm with @AT on this one. One reason I was trying to get the OP to think in terms of specific coordinate systems is that "point of view" is vague and ambiguous, can't easily be generalised and isn't useful for specific calculations.
And this is still wrong. A frame is represented by some system of coordinates that extends over space and time. It is not the point of view of a single object. No matter how many times you repeat this misconception, it's still wrong.
You can think of the rest frame of an object (better terminology would be "that frame in which the object is at rest") that way if you want, but not all frames are the rest frame of anything. The Galilean transformation relates any two frames, not just ones that happen to have some object at rest in them.
Reply
I was starting to wonder whether "Niel" and "gionole" were one and the same.
Reply
