Gamma Explained: Reasons for Lorentz Transformation
  • Context: Undergrad
  • Thread starter Thread starter actionintegral
    Gamma
13 replies · 3K views
actionintegral
Does anyone have a brief explanation of why the gamma is necessary in the Lorentz transformation.
gamma?
in order to account for relativistic effects like time dilation, doppler shift...
sine ira et studio
But the constancy of the speed of light is preserved simply by
x'=x-vt and t'=t-vx/cc. I'm trying to see where the scaling factor comes in.
Comes from preserving dx^2 -( c dt )^2
Gamma, or sometimes called the Lorentz factor, represents the relationship between relativistic time and proper time or relativistic length and proper length.
Proper time and proper length are resp. the time and the length of an object in its restframe while relativistic time and relativistic length are resp. the time and length of an object that is moving relative to the frame of the observer.
The reason we need gamma to translate lengths and times from one frame to another is that the speed of light is always the same independent of motion. So, distance and duration cannot longer be absolute but instead depend on relative motion.
Fair enough - but why would I want to preserve THAT?
gamma@
you are perfectly right. in the paper
arXiv.org > physics > physics/0409121
Physics, abstract
physics/0409121
Three levels of understanding physical relativity: Galileo's relativity, Up-to-date Galileo's relativity and Einstein's relativity: A historical survey
Authors: Bernhard Rothenstein, Corina Nafornita
Comments: 10 pages, 4 figures
Subj-class: Physics Education
We present a way of teaching Einstein's special relativity. It starts with Galileo's relativity, the learners know from previous lectures. The lecture underlines that we can have three transformation equations for the space-time coordinates of the same event, which lead to absolute clock readings, time intervals and lengths (Galileo's relativity), to absolute clock readings but to relative time intervals and lengths (up-to-date Galileo transformations) and to relative clock readings time intervals and lengths.
we have called the equations you mention "uptodate" Galileo transformations. Please have a critical look at it
Because it represents the line element.
There are experimental results [as well as theoretical/mathematical results] that effectively lead to this requirement.
For special relativity, the set of transformations one considers has to satisfy some conditions, including:
they are linear [lines map to lines] and they form a group [which preserves the metric]. [I don't think your transformations form a group.]
Especially for a theory of relativity, the transformations cannot have a timelike eigenvector [i.e. no distinguished observer].
The equations
x1 = x - v*t
t1 = t - (v/c^2) x
do have an inverse, so they will form a group. (A mapping must be associative and have an inverse to be a group, and IIRC associativity is a general property of any mapping so it shouldn't be an issue).
But the form of the inverse reveals why it's not the right choice:
t = (t1 + (v/c^2) x1) / (1 - v^2/c^2)
x = (x1 + v*t) / (1 - v^2/c^2)
We _also_ want the transforms to have the property that the inverse is generated just by changing the sign of v. This is justified by requiring that the transforms be isotropic. Isotropy is the missing element in the proposal.
Thanks, perv. o:) I will investigate the lack of symmetry in the inverse.
Because people don't want to keep writing [tex]\frac{1}{\sqrt{1 - \frac{v^2}{c^2}}}[/tex]. :-p
Sorry... :biggrin:
If people wrote [tex]\cosh\theta[/tex] instead of [tex]\gamma[/tex] or [tex]\frac{1}{\sqrt{1-v^2/c^2 } }[/tex], these mysterious quantities might not seem as mysterious.
