Garbage can suspended in the air
  • Thread starter Thread starter Saitama
    Air
42 replies · 12K views
Saitama
An inverted garbage can of weight W is suspended in air by water from a geyser. The water shoots up the ground with speed ##v_0##, at a constant rate ##dm/dt##. The problem is to find the maximum height at which garbage can rides. What assumption must be fulfilled for the maximum height to be reached.
Ans. clue. If ##v_0=20\, m/s##, W=10kg, dm/dt=0.5 kg/s, then ##h_{max} \approx 17 \, m##
I don't know how to begin with this problem. I think that I have to find the force due to water but I can't see how to form the equations here. I need a few hints to begin with.
Any help is appreciated. Thanks!
Does the momentum of the water change when it interacts with the can? Can you solve the problem if there were balls shot up instead of water?
ehild
The geyser alone reaches 20.4m
rude man said:
Think F = dp/dt with p = p(height).
BTW I got a very different answer. (I assume W = 10*9.81 = 98.1 N).
@ehild?
I also think that the example solution is wrong.
ehild
ehild
Yes, the momentum of water changes. If the base of garbage can is at a height h, the velocity with which water strikes is ##\sqrt{v_0^2-2gh}##. The problem is how do I find the change in momentum of mass of water striking the can. The question doesn't state the type of collision between water and can.
Pranav-Arora said:
1. The problem is to find the maximum height at which garbage can rides.
So under what conditions does it? :wink:
Yes, when is it maximum? At elastic or inelastic collision?
ehild
ehild
Elastic.
Does it mean the water bounces back with ##\sqrt{v_0^2-2gh}##? I guess that would be wrong because the garbage can is also moving. Correct?
Pranav-Arora said:
Does it mean the water bounces back with ##\sqrt{v_0^2-2gh}##? ?
Nope...
Yep, so what are you missing? What does the water do?
What does maximum height mean? Does the can raise higher from that? ehild
Same here. I think the correct answer for a 10 kg garbage can (and calling this "weight" in a physics text is not good) is zero. 20 m/s * 0.5 kg/s = 10 Newtons. Double that for a pure elastic collision and you get 20 Newtons, which is not enough to lift a 10 kg object off the ground.
The problem says "of weight W". So I'd think it should be W = 10 N, rather than 10 kg.
And it also says that W=10 kg. The text of the problem is confusing. ehild
Yes, giving weight as 10 kg is incorrect but the problem is from a very good book, errors may creep in despite the best efforts by the authors. :)
The source of the problem is "An Introduction to Mechanics by Daniel Kleppner and Robert Kolenkow".
Change in momentum of water at maximum height is ##2\Delta m\sqrt{v_0^2-2gh}##. The force applied on can in time ##\Delta t## is ##2(\Delta m/\Delta t)\sqrt{v_0^2-2gh}##. Taking the limit ##\Delta t\rightarrow 0##, the force acting on can is ##2(dm/dt)\sqrt{v_0^2-2gh}##. This is balanced by the weight of can. Hence,
$$2\frac{dm}{dt}\sqrt{v_0^2-2gh}=W$$
From here I can solve for h.
Looks correct?
Looks correct?
The method looks correct, yes. But as for the answer you'll get ...
In the 2010 edition, the answer clue is ## v_0 = 20 \ \text{m/s}, \ W = 8.2 \ \text{N}, \ dm/dt = 0.5 \ \text{kg/s}, \ h_{\text{max}} \approx 15 \ \text{m} ##.
Yes, the given clue doesn't satisfy the final result as said by the other posters.
Mine is a low priced Indian edition 2009.
The text as you gave it is an exact copy from the original 1973 edition.
I have checked my text again, I have copied down the same exact wordings.
Check this book on Google Books, this is the one sold in my country:
http://books.google.co.in/books?id=lYYL6qnDTGAC&printsec=frontcover#v=onepage&q&f=false
Look for the Momentum chapter.
Also, the clue you posted doesn't satisfy the result I reach. I have tried both values of g i.e 9.8 and 10.
Looks correct?
Yes. :smile:
ehild
ehild said:
Yes. :smile:
ehild
Thanks for the help ehild! :)
It is 17 m with these data.
And if I use 10 N instead of 10 kg, it comes out to be 15 m, lol.
Is it not what I said?
I cannot seem to be able to look inside, but I think this is just a reprint of the original edition, with all of its errors.
I agree there is still a discrepancy, but at least now the statement of the problem is consistent.
I misinterpreted your statement, sorry. :redface:
That's still wrong. 8.2 Newtons is the weight that can be suspended at 17 meters. It's about 15 meters for the 10 Newton garbage can.
Yes, that was already pointed out and it is exactly 15 meters if g=10 m/s^2 is used. :)
