What is the relationship between gas expansion and work done in a cylinder?
  • Thread starter Thread starter Lamoid
    Cylinder Gas
The relationship between gas expansion and work done in a cylinder is defined by the equation W = ∫ F dx, where F is the force exerted by the gas on the piston, calculated as F = π(r^2)P. The work done by the gas during expansion from volume V1 to V2 can be expressed as W = ∫ P dV, with the substitution V = πr^2x allowing for the integration limits to change accordingly. This discussion emphasizes the importance of correctly substituting variables and understanding the integral calculus involved in deriving the work done during gas expansion.
  • Understanding of integral calculus and substitution methods
  • Familiarity with the ideal gas law and pressure-volume relationships
  • Knowledge of basic physics concepts related to work and force
  • Ability to manipulate equations involving pressure, volume, and area
  • Study the derivation of the work done by gas during isothermal and adiabatic processes
  • Learn about the ideal gas law and its applications in thermodynamics
  • Explore advanced integral calculus techniques for variable substitution
  • Investigate real-world applications of gas expansion in engines and compressors
Students studying thermodynamics, physics enthusiasts, and professionals in engineering fields focused on fluid mechanics and energy systems.
Lamoid
When gas expands in a cylinder with radius r, the pressure at any given time is a function of the volume: P = P (V). The force exerted by the gas on the piston is the product of the pressure and the area: F = π(r^2)P. Show that the work done by the gas when the volume expands from Volume V1 to Volume V2 is
I was having a problem doing this question so I just sort of trudged ahead to see if I could get something and I ended up using substitution with u = n(r^2)x and du = nr^2 and then adjusted the limits of integration which were x+a and x. I am fairly certain this is wrong though and would appreciate help.
What is the usual definition of work?
Integral of Force times distance
Yes.
Can you make substitutions and rearrange terms to get that integral in terms of P and V?
Ok so that's the integral. So I replace (pi)(r^2)x with V ?
Um, wait a moment.
If a force F moves an object over a distance dx, then the work done in that small distance is F*dx.
For extended distances, we would integrate F * dx
Try working with that expression ... you were on the right track otherwise.
Hmm, so I am confused. This is my best guess.
f * dx = W
πr^2P * dx = W
PV = W
P*dv = W'
Then you integrate it using the change in volume as the limits of integration?
Try this:
W = \int F dx
and do the same substitution F = P * pi * r^2
Okay, when I do that I end up, obviously, W = integral P * pi * r^2 * dx. I know I have to get V's in here, but I am unsure if I substitute pi * r^2 * dx with a V or a dv since I am talking about the change in x.
V = \pi r^2 x where we take the origin to be wherever the piston starts. What's dV?
So dv is pi*r^2*dx. Now, must I do anything to make the limits of intergration V1 to V2?
This is a change-of-variable as taught in integral calculus.
With the substitution V = pi r^2 x, the limits simply change accordingly so that:
x1 becomes V1, where V1 = pi r^2 x1
and similarly for x2 and V2.
In other words,
<br /> \int^{x2}_{x1} ... \ dx<br />
becomes
<br /> \int^{\pi r^2 x2}_{\pi r^2 x1} ... \ dV<br />
or just
<br /> \int^{V2}_{V1} ... \ dV<br />
  • · Replies 60 ·
10K
