- 42,906
- 10,527
Not quite that directly - that's a popular misunderstanding.Robyn Gibson said:because the pressure is lower at higher altitudes,
First, it is not always true that it's colder at higher altitude. Temperature 'inversions' can occur. The primary reason it's colder is because the atmosphere is heated from the bottom by the insolation of the Earth's surface, and loses heat into space at the top. So with no convection it would be much colder at higher altitudes. But heated air expands and becomes less dense, so rises. This convection tends to spread the heat evenly up through the atmosphere (at least, as far as the tropopause). As against this, as a given parcel of warm air rises it expands further because of the lower pressure, and in expanding it 'does work', pushing aside other air. The energy for that work comes from the heat in it, so it cools. (This is an example of adiabatic expansion.) Thus convection can only occur when the temperature gradient is steep enough.
For the present problem, the key part in all that is the bit about air cooling as it is allowed to expand.
