Gas radiation question - He, H2 vs O2, N2
  • Context: Graduate
  • Thread starter Thread starter Tandem78
    Gas Radiation
The discussion revolves around the radiation properties of gases, particularly focusing on the differences between diatomic molecules like O2 and N2 and lighter gases like H2 and He in the context of the sun's photosphere and atmospheric physics. Participants explore the implications of molecular symmetry, ionization, and thermal radiation mechanisms.
  • Exploratory, Technical explanation, Debate/contested
  • One participant questions the standard explanation that the sun's light comes from the photosphere, suggesting that either the light originates from a lower layer or that O2 and N2 might absorb visible and infrared radiation minimally.
  • Another participant challenges the assertion that diatomic molecules like O2 and N2 do not absorb or emit radiation, noting that CO2 and CH4, which are symmetric, are still effective greenhouse gases.
  • A later reply proposes that the photosphere may consist only of ionized gas, which could interact with electromagnetic fields and radiate thermal energy.
  • One participant suggests that ionization might be key to understanding radiation mechanisms, while another elaborates on the distinction between thermal radiation and emissions due to electron transitions.
  • There is a discussion about the nature of thermal radiation, with participants noting that not all substances behave as perfect black bodies and that thermal radiation is a universal phenomenon.
Participants express differing views on the radiation properties of diatomic molecules and the role of ionization, indicating that multiple competing perspectives remain without a clear consensus.
Participants acknowledge limitations in their understanding of radiation mechanisms and the complexities involved in the behavior of different gases under various conditions.
Tandem78
A question has been bothering me for some time - when we look at the sun, what are we looking at?
The standard answer is - the photosphere. The sun consists mostly of hydrogen and helium, and that the radiation from the photosphere is approximately a black body continuum spectrum at 6000K with some absorption lines in the visible light range.
However, in atmospheric physics, we learn that diatomic molecules like O2 and N2 as well as noble gases like Argon neither absorb nor emit infrared nor visible radiation, because they are symmetric and have no dipole moment. Their energy levels are so far apart that they only interact in the UV.
This the reason why the atmosphere is transparent to visible light, and why N2 and O2 cannot act as greenhouse gases, whereas H2O and CO2 do.
I have a problem trying to reconcile these two pieces of information, which seem to contradict each other. H2 and He are just like O2, N2 and Argon, diatomic or noble gases. If visible light from the photosphere is radiated by He and H2 at 6000K, why do N2 and O2 on Earth at 300K not radiate or absorb at infrared wavelengths?
I haven't seen any explanation of this contradiction. I suppose either a) the sun's light is not coming from the photosphere but a lower layer or b) O2 and N2 do indeed absorb visible and IR, but the interaction is so minimal that it can be ignored.
Is one of these correct, or is there another explanation?
T.
Science news on Phys.org
Tandem78 said:
...However, in atmospheric physics, we learn that diatomic molecules like O2 and N2 as well as noble gases like Argon neither absorb nor emit infrared nor visible radiation, because they are symmetric and have no dipole moment...
Hmm... that part is fishy to me...
Tandem78 said:
...N2 and O2 cannot act as greenhouse gases, whereas H2O and CO2 do.
CO2 is symmetric and has no dipole moment. Same with CH4, which is one of the worst greenhouse gasses. I think maybe the information you received was "simplified".
I don't know much on the subject, but I'm going to spend some time on google and see what I find.
You may assume there are no diatomic molecules in photosphere, only ionized gas.
That makes things even worse, as ions are perfectly symmetrical as well :wink:
Hey, that might be the explanation - at least ions have an electric charge. So an ion moving with thermal energy can interact with the electromagnetic field and convert the thermal (kinetic) energy into radiation. Not a very good formulation, but does that makes sense?
T.
PS thinking about this more, it means that only ionized hydrogen can radiate this way - does that mean a star consisting only of helium would be invisible?
Helium is ionized as well.
The explanation I saw in a lecture was that when one of the vibrational modes of a complex molecule (H2O, CO2, CH4 etc) is excited, this creates an asymmetry in the structure, and this creates an asymmetry in electric charge - in other words a dipole. This is not the case for diatomic molecules.
T.
You're right - I'm thinking of ions like in chemistry, duh...
So is the ionization the key to the answer?
Part of the answer, but honestly I am not sure about the radiation mechanisms, or it is too early for me to think clearly. There are two parts of it - one is emission when electrons go from excited state to the ground one, that means we can observe well defined discrete spectrum. Second part is a thermal radiation, which is continuous and observed for each object (and approximated by black body radiation). As far as I remember emission of thermal radiation is universal and doesn't require any assumptions about the body (well, perhaps one - its temperature must be above 0 K) - so whether it is made of ions, atoms, molecules, doesn't matter.
Yes, this is not the same as emission of photons due to changes in electron orbits or vibrational states, it's about how an atom or molecule can convert its thermal (ie kinetic) energy into electromagnetic energy, even when it carries no charge. You say that thermal radiation is universal, however it's true to say that not all substances are black bodies, correct?
T.
Yes. In reality black body doesn't exist - it is just an approximation. As it happens with some approximations it turns out to be good enough for many applications and good enough to understand basic properties of thermal emission.
  • · Replies 19 ·
18K
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 76 ·
34K
