A Gauge breaking and Faddeev-Popov ghost particles
Michael Price
TL;DR Summary
In QFT, if we add a gauge breaking term to the Lagrangian, do we still need to introduce ghost particles?
Summary: In QFT, if we add a gauge breaking term to the Lagrangian, do we still need to introduce Faddeev-Popov ghost particles?
Ghosts seems to be introduced to maintain gauge invariance. But suppose we have eliminated the gauge invariance, from the start, by explicitly introducing a gauge breaking term to the Lagrangian? Do we still need to introduce ghosts?
https://en.m.wikipedia.org/wiki/Ghost_(physics)
Likes Demystifier
Ghosts can be thought of as non-physical degrees of freedom that appear in mathematical expressions. They are non-physical in the sense that different values of these degrees cannot be distinguished physically. For instance, different values of the angle ##\varphi## in a rotation-invariant theory cannot be distinguished physically, so the variable ##\varphi## can be thought of as a kind of "ghost". When the symmetry is explicitly broken, those degrees of freedom do not go away. Instead, they become physical. The ghosts "materialize", so to speak.
Likes Michael Price
But why would the ghosts be introduced if there is no gauge symmetry, if we have destroyed it by added a gauge breaker to the Lagrangian? Haven't we just restricted the dynamics of the gauge bosons a bit more? I.e. removed a degree or degrees of freedom.
I am not sure what you are asking.
First, with your reference to gauge theories it makes most sense you are talking about Faddeev-Popov ghosts, but then the wiki page you linked lists a bunch of other possible meanings of ghost, so which one are you asking about?
Second, assuming you are talking about Faddeev-Popov, do you mean why we need ghosts after adding a gauge fixing term, or are you talking about explicit breaking like adding a mass to W and Z bosons in SU(2) theory in a naive way?
Likes Michael Price
Yes, I mean Faddeev-Popov ghosts and explicit symmetry breaking by adding a gauge breaking/fixing term (e.g. to enforce the Feynman gauge) to the Lagrangian. Not about W/Z mass terms.
Sorry should have linked to the more specific article.
https://en.m.wikipedia.org/wiki/Faddeev–Popov_ghost
PS I've edited my original post to clarify things.
In Gauge Theories the fields ##A_{\mu}## overdescribe the physics. In the path integral approach the space of all such fields ##\mathcal{V}## is too large. This is essentially due to the fact that the dynamics of massless spin-1 bosons don't exactly correspond to that of local fields. Note: The dynamics are still local, but just not in direct correspondance with local fields. However since local fields are so mathematically neat to work with and allow you perform renormalization easily we continue to use them.
An entire family of fields ##A^{G}_{\mu}## which are transformations of some fixed ##A_{\mu}## by a gauge transformation ##G## all describe the same physical situation. Such families are called gauge orbits.
So we should be integrating over ##\mathcal{V}/\mathcal{G}## and we do this by selecting out a surface on ##\mathcal{V}## by using a delta function or some similar trick. The delta function then selects out one field from each gauge orbit, defining a surface ##\mathcal{S}## which should give the same physics as ##\mathcal{V}/\mathcal{G}##.
However it turns out that the gauge orbits are more "clumped" at some points on the surface than others, i.e. there can be areas of the surface with a higher density of orbits intersecting it there. The density of orbits is given by ##\det\left(\partial^{\mu}D_{\mu}\right)##. To use perturbation theory one needs a way to evaluate this density perturbatively.
Luckily we know that functional determinants can be evaluated with fermionic path integrals. Thus we replace the determinant with a path integral over a new fermionic set of fields.
So in essence ghosts are ways of perturbatively evaluating the orbit density of your gauge fixed surface. There will be an orbit density to this surface regardless of whether you have a gauge breaking term or not. The gauge breaking term is present to prevent a contradiction between the Maxwell equations, non-triviality and local fields.
Likes mattt, dextercioby and Michael Price
Ok, in that case you still need ghosts. From a pragmatic point of view, there are contributions form unphysical states, and you need to subtract them out, and adding ghost particles is the way to do that. Without introducing the gauge fixing term, you would not even get to the stage where one can see this problem. It is probably better to view the introduction of ghosts as part of the gauge fixing procedure for non-abelean theories.
Likes Michael Price
With this term added you get an infinite family of inequivalent theories, parameterized by the new coupling constant ##\lambda## needed. The original theory is recovered only in the limit where ##\lambda\to 0##. All other values give theories with explicitly broken gauge symmetry.
Only if there is no explictly broken gauge invariance, i.e., when ##\lambda=0##. If ##\lambda\ne0##, the physics is changed, and all degrees of freedom of the fields ##A_{\mu}## are physical. Then no gauge can be fixed as there is no gauge symmetry in the classical Lagrangian with ##\lambda\ne0##.
But this orbit density is irrelevant except in the limit where the gauge breaking term vanishes. Of course, this is the situation where the original gauge invariant theory would be recovered.
Likes Michael Price
When the gauge symmetry is broken the state space is full of unphysical states with negative norm and forms a Krein space. So are these degrees of freedom really "physical" in any sense, the resultant space has no sensible physical interpretation, it's just an intermediate stage used to permit calculations in the physical theory with local operators.
If you don't implement the conditions that restore the physical theory then the path integral is just an abstract stochastic process with no relation to any sensible quantum field theory. So yes if you keep the gauge broken then the orbit density doesn't matter, but why is that fact even relevant?
A local gauge symmetry cannot be spontaneously broken (Elitzur's theorem). What happens instead is the "Anderson-Higgs-et-al mechanism", and you get massive gauge bosons by "eating up" the would-be-Goldstone modes. In non-unitary gauges the would-be-Goldstone bosons become ghosts as the Faddeev-Popov ghosts. These are good ghosts, cancelling unphysical degrees of freedom in gauge theories.
No. This is the case only assuming that you have already adjoined the ghost field. Without doing this, the situation is completely different:
When the gauge symmetry is explicitly broken the theory is unrenormalizable, which means that (unlike in the renormalizable case) the manifold of perturbatively (and canonically) renormalized field theories associated with it is infinite-dimensional, due to the infinitely many counterterms. Nothing at all is rigorously known about the resulting nonperturbative situation.
Likes Michael Price and vanhees71
A. Neumaier said:
When the gauge symmetry is explicitly broken the theory is unrenormalizable,[...]
Is this the reason for Faddeev-Popov ghosts? I.e. To keep the theory renormalisable we mustn't explicitly break the gauge symmetry, and so, to maintain gauge symmetry, we are forced to go down the FP ghost route?
More or less, yes. Actually the gauge symmetry is lost anyway but instead the BRST supersymmetry appears.
Likes vanhees71, Michael Price and dextercioby
Not necessarily. The unphysical states with negative norms have been introduced into the theory intentionally, by design, to make relativistic symmetry "manifest", by Gupta and Bleuer. They replaced another, earlier, quantization scheme proposed by Fermi and Dirac, which introduced different commutation rules for the temporal A_0 and the spatial A_i components. The resulting observable predictions were nonetheless Lorentz-covariant, but this destroyed the covariance at the fundamental level.
Once one does not insist on gauge invariance being fundamental (else, the question would not make sense), but considers it as something approximate, emergent, one can as well consider relativistic symmetry as emergent. Instead, negative norms make no sense at all. In this case, it makes sense to use the older approach, given that it avoids any negative norms.
I think gauge symmetry is pretty unavoidable when dealing with massless vector fields (and I guess also for massless fields of higher spin too). That's because the little group in the massless case is ##\text{ISO}(2)## or rather its covering group, i.e., the symmetry group of the Euclidean plane. If you do not want to have continuously many intrinsic ("polarization like") degrees of freedom, you must make the translations of this group act trivially, and this is afaik only possible using gauge symmetry. Then only the rotations around the three momentum are realized non-trivially giving rise to the two physical polarization degrees (it's only two for massless particles with spin ##\geq 1/2## and not ##(2s+1)## as for massive particles, where the little group is ##\text{SO}(3)## or rather its covering group ##\text{SU}(2)##) of freedom with helicity as the corresponding observable.
Exactly what way are we breaking gauge symmetry here? Adding a mass?
The FP formalism fixes the gauge but doesn't break gauge symmetry. Choosing the background-field gauge you can even get a gauge-invariant effective action. Usually if you start with a gauge theory and break the gauge symmetry explicitly the theory becomes unphysical. Adding naively a mass term in non-Abelian gauge theories makes the theory unphysical, and thus you have to use the Anderon-Higgs-et-al mechanism to describe massive non-Abelian gauge bosons, and usually you have at least a physical Higgs boson left. (In)famously the predicted Higgs boson in the SM has been discovered. In the Abelian case you can introduce a mass term without breaking local gauge invariance (Stueckelberg formalism).
I know all of that, but I don't really understand in what sense we are "adjoining ghosts". My understanding is that if you break gauge symmetry by adding the usual gauge breaking term to the Lagrangian:
$$\lambda\partial_{\mu}\partial^{\nu}A_{\nu}$$
then the state space immediately has negative norm states.
When you add a symmetry breaking term (don't confuse it with a gauge fixing term, that's different), you don't remove degrees of freedom. Just the opposite, you add new degrees.
I've no clue what "adjoining ghosts" means, but we introduce them in FP procedure to get a perturbative handle on the functional determinant introduced when integrating over the gauge group. The unphysical gauge-field degrees of freedom and the FP ghost conspire such as to cancel the unphysical degrees of freedom in physical (i.e., gauge-invariant) quantities, leading finally (order by order perturbation theory) to a univary S-matrix. No negative-norm states are physical of course. Formally it's a bit tricky a proof making use of the BRST symmetry and the associated Slavnov-Taylor identities. Everything becomes much simpler in the background-field gauge, where you deal with gauge-invariant effective actions and you can do with Ward-Takahashi identities as in the Abelian (QED) case.
Likes DarMM
As I said I know all that, that's what I'm saying. I don't understand what @A. Neumaier is saying.
I know that you know that. I answered for the rest of PF readers too ;-). I'm reminded of Einstein's dictum about mathematicians in 1908 after he read Minkowski's famous article, but as is well known this was a premature statement since Einstein later realized how important math really is for his work, and he regretted not to have attended Minkowski's lectures in Zürich. Usually you have to work hard to translate the mathematicians' jargon into physicists' jargon. Sometimes it's impossible though...
Likes Michael Price, DarMM and weirdoguy
Ah of course, very sensible, my apologies.
It doesn't matter for my argument. Intended in the original question (made precise in post #5 was apparently a term proportional to ##(\nabla\cdot A)^2## or another gauge-fixing term.
This term is not a scalar, hence is not eligible. If you add ##\lambda(\nabla\cdot A)^2## with ##\lambda\ne0##, the Lagragian is no longer renormalizable, and renormalized perturbation theory needs new constants at each order. Apart from that, everything is canonical and hence in a Hilbert space setting.
Negative norm states are absent; they never appear in canonical quantization.
Negative norm states enter only through the coupling with a ghost field in a path integral approach, There the integrand only goes over a quotient space and integrating formally over gauged-fixed representatives (ignoring Gribov copies) needs to be compensated by a functional determinant, which is modeled by an unphysical ghost field. Only at this stage, definiteness can no longer be maintained.
The term I gave is the modification to the equations of motion, not the Lagrangian. The Lagrangian term giving it is essentially the same as your term there.
If you add such a term then the inner product cannot be positive semi-definite due to essentially a Reeh-Schlideder argument . See Strocchi "An Introduction to Non-perturbative Foundations of Quantum Field Theory" Proposition 3.3 p.155.
A. Neumaier said:
When the gauge symmetry is explicitly broken the theory is unrenormalizable, which means that (unlike in the renormalizable case) the manifold of perturbatively (and canonically) renormalized field theories associated with it is infinite-dimensional, due to the infinitely many counterterms. Nothing at all is known about the resulting nonperturbative situation.
This sounds strange, given that in the Wilsonian approach it is quite clear what to do with this sort of infinity. The non-renormalizable theory has to be understood as an effective field theory, and there is a critical length at which the effective field theory fails. One can now assume that all the terms have a similar order of magnitude at this critical distance. And then one can see what survives in the large distance limit. These are, first of all, renormalizable components. Then there are a few lowest order non-renormalizable ones.
Given this purely qualitative consideration, one can already make a qualitative guess. The renormalizable part of a massive gauge theory is the massless, gauge-invariant theory. The massive part gives a short distance force, thus, vanishes for large distances anyway (as suggested above).
We have to do this anyway, given that gravity is non-renormalizable, and this gives already a nice suggestion for the critical length. So, all that remains to be done would be to consider the lowest order non-renormalizable terms and what they give, say, for the massive gauge theories at Planck scale.
If this has been done somewhere, I would be very interested in the results. It not, I would be interested to understand why this has not been done.
(The same question appears for gauge theories with anomalies. Here I would guess that one can even predict qualitatively with more certainty that the anomalous part will be suppressed, thus, becomes very weak in comparison with the non-anomalous gauge fields. Here I would wonder why this method has not been used to extend the SM gauge group, given that one would not even have to invent a mechanism to suppress the additional gauge fields.)
I have currently no access to this book, but there cannot be any rigorous results of this kind on a theory that is by definition not gauge invariant. As I remember Strocchi assumes from the start that there is gauge invariance, and then shows that it cannot be locally realized in a Hilbett space. But once the extra term is added, the theory is manifestly gauge noninvariant, hence Strocchi's assumption is not met.
One gets the "negative-norm states" not only in the path-integral formalism but of course in the equivalent operator formalism too. You use the BRST symmetry of the complete gauge-fixed Lagrangian including FP ghosts to define the constraint conditions for the physical states leading to a positive definite norm and a unitary S-matrix. For details, see
T. Kugo, I. Ojima, Manifestly Covariant Canonical
Formulation of the Yang-Mills Field Theories. I, Progress of
Theoretical Physics 60 (1978) 1869.
http://dx.doi.org/10.1143/PTP.60.1869
T. Kugo, O. Ojima, Manifestly Covariant Canonical
Formulation of Yang-Mills Field Theories. II: SU (2)
Higgs-Kibble Model with Spontaneous Symmetry Breaking,
Progress of theoretical physics 61 (1979) 294.
http://dx.doi.org/10.1143/PTP.61.294
Formulation of Yang-Mills Field Theories. III—Pure
Yang-Mills Theories without Spontaneous Symmetry
Breaking, Progress of Theoretical Physics 61 (1979) 644.
http://dx.doi.org/10.1143/PTP.61.644
Likes DarMM
Perhaps I'm not really understanding what is meant here then. To me this all goes back to @vanhees71 post where vector fields have too many components to model massless particles directly as they are reps of ##ISO(2)##. For that reason modelling massless particles with local fields means there will be gauge symmetry. Unless you mean to model massive particles?
Yes, on the level of perturbation theory, one can say a lot. But I had meant nothing is known rigorously.
(DarMM is a mathematical physicist.)
But only if one adds ghosts (or other unphysical degrees of freedom) to preserve manifest gauge symmetry. Not for the family of modified theories where this is explicitly broken by nonrenormalizable terms.
  • #31
It's not clear to me, what you mean. Are you referring to something like the "unitary gauge"?
Also in the simpler abelian case, where you can use the Gupta-Bleuler formalism, you have "negative-norm states" first but then introduce the constraint conditions for physical states. In the original form of the Gupta-Bleuler formalism there are no FP ghosts introduced. This has been done for QED by Feynman first. Using the FP formalism for abelian gauge fields in the standard covariant gauges, the FP ghosts are non-interacting and thus play no role in the Feynman rules for physical S-matrix elements.
Of course all this is defined (though mathematically not rigorously) within perturbative QFT only.
  • #32
No; it was a general remark. If there is no gauge symmetry then there is nothing to fix. Adding a gauge symmetry violating term of any sort, in particular the one the OP requested,
changes the family of field theories considered to a bigger class, of which only a set of measure zero corresponds to the original gauge invariant family. Thus gauge considerations become irrelevant for the bigger class, since there the longitudinal component is physical (but with a singularity at vanishing couplng). Thus it doesn't make sense to introduce ghosts or unphysical Gupta-Bleuler degrees of freedom. Thus also no indefinite inner product.
  • #33
Thus it's describing a theory with massive bosons right?
  • #34
I guess so. The added term will generate infinitely many other counterterms, most likely also including a mass term. In the resulting infinite-dimensional manifold of theories there is probably a distinguished finite-dimensional manifold of theories corresponding in a nonperturbative sense to the original family, but for lack of nonperturbative theory no one knows how to select it. Thus one needs to truncate the family and live with an effective theory.
Likes DarMM
  • #35
Okay, if we are taking the gauge breaking term as a mass term not as a term to weaken the Gauss law, which it must be if it has physical longitudinal polarized states, then I agree.
As you said we know very little about the nonperturbative behaviour of such theories, they're usually ignored due to being nonrenormalizable, but that might not be valid.
  • #36
The point is that even when we start with a pure gauge fixing divergence squared term only, the presence of a further mass term is probably forced by the renormalization procedure.
  • #37
You are absolutely right. If the vector field is massive, it is possible to separate the negative-norm covariantly because of the compact nature of the corresponding little group, SO(3). But, for a massless vector field, it is impossible to avoid negative norms without violating manifest Lorentz covariance. This is because of the fact that the corresponding little group E(2) is noncompact. In other words, the reason for the presence of negative norms is mathematical and has nothing to do with the field content of the theory. Indeed, given a massless vector field A_{\mu}(x) together with the Poincare algebra, one can prove (without using any field equations or Lagrangians) the impossibility of covariantly quantizing A_{\mu} in the positive-metric Hilbert space. So, ghosts and/or gauge-fixing fields have nothing whatsoever to do with the appearance of negative norm states. In short, indefinite-metric Hilbert (Krein) space is indispensable in the covariant formalism of QFT.
Likes vanhees71
  • #38
... of QFT with massless vector fields (only).
  • #39
If one wants a highly mathematical take on ghosts.
If we consider the Yang-Mills action ##S##, the space of connections (fields) ##\mathcal{V}## and gauge group ##\mathcal{G}##, the naive path integral is given by:
\int_{\mathcal{V}}{e^{-S}}
However this is wrong since we are integrating over field configurations that simply correspond to coordinate shifts along the fibers of the bundle. That's what causes gauge symmetry. If the ##A_{\mu}## fields are fiber bundle connections (which ultimately means they are associated with massless fields) then several fields are simply the same field in different fiber coordinates.
For this reason we should really be integrating over:
\int_{\mathcal{V}/\mathcal{G}}{e^{-S}}
The problem is that ##\mathcal{V}/\mathcal{G}## is quite a complicated quotient of two infinite dimensional spaces and integration theory upon it is undeveloped.
However the space of functions on ##\mathcal{V}/\mathcal{G}## should be equivalent in some sense to the space of ##\mathcal{G}## invariant functions on ##\mathcal{V}##.
From homological theory this is equivalent to the space of ##\mathfrak{g}## invariant functions on ##\mathcal{V}##, i.e. we can consider the Lie-Algebra instead of the Lie-Group.
The space of such functions is known as the Chevalley-Eilenberg complex. Denoted:
\mathcal{C}^{*}\left(\mathfrak{g} , \mathcal{V}\right)
Again from homology theory we find that:
\mathcal{C}^{*}\left(\mathfrak{g} , \mathcal{V}\right) = \hat{Sym}^{*}\left(\mathfrak{g}\left[1\right] \oplus \mathcal{V}\right)
That is the space of Lie algebra invariant functions over ##\mathcal{V}## is isomorphic to the space of symmetric functions over ##\mathfrak{g}\left[1\right] \oplus \mathcal{V}##. The ##\left[1\right]## indicates you give the field a grade, i.e. make it fermionic. Thus we can consider the integration to be over the space of gauge fields and a fermionic Lie-algebra valued scalar. That's basically the origin of ghosts.
We would still have the problem that the quadratic part of the action ##S## is not invertible on this space. Thus although it is the correct space in a sense, we cannot perform perturbation theory.
Fortunately the theory of homology tells us that an integral on a vector space is equivalent in a certain sense to an integral on its shifted cotangent bundle. Thus we can perform an integral on:
T^{*}\left[-1\right]\left(\mathfrak{g}\left[1\right] \oplus \mathcal{V}\right)
instead. It turns out that this space is isomorphic to:
\mathfrak{g}\left[1\right] \oplus \mathcal{V} \oplus \mathfrak{g}^{\lor}\left[-2\right] \oplus \mathcal{V}^{\lor}\left[-1\right]
Which gives you the extra antighost and anti-gauge fields of the BRST formalism and a quadratic part of the action which is invertible.
Likes dextercioby, mattt, vanhees71 and 2 others
  • #40
Could you please give a reference where this is discussed in the terms you just described? Can one descrbe the Poisson bracket on functions of the quotient space in these terms?
  • #41
Kevin Costello, Renormalization and effective field theory, Mathematical Surveys and Monographs, Volume 170, American Mathematical Society (2011)
Chapter 5 in particular and the references there in. Which I believe can be read in isolation. Most of the book concerns a "rigorous" attempt at perturbative Wilsonian effective field theory.
I think it's good to see the gauge antifields in physicists language first:
https://arxiv.org/abs/hep-th/0506098
The Poisson bracket can indeed be described. It's encapsulated in the Chevalley-Eilenberg differential and its equivalent on the final space:
  • #42
Why are we discussing about gauge theory when the theory in question is none? The gauge-fixing terms introdcuced to gauge-symmetric Lagrangians via the FP path-integral quantization procedure do not break the gauge invariance but fix a gauge and this procedure thus necessarily involves the introduction of the FP ghost fields.
The abelian case is special, because there the FP ghosts decouple and can thus be lumped into the indefinite and irrelevant diverging factor of the path integral. That's the a-posteriori explanation within the FP formalism and its "translation" to the covariant operator formalism, why the Gupta-Bleuler quantization, starting from a non-gauge-invariant Lagrangian works out to describe QED as a gauge theory.
  • #43
Because I answered the question of the poster of #1, clarified in #5:
Likes Michael Price
  • #44
A. Neumaier said:
... of QFT with massless fields (only).
1) If you are in the business of nitpicking, then you should have said “... of QFT with massless vector fields ”, because the QFT of massless scalar does not require indefinite-metric.
2) By QFT, I meant gauge-invariant quantum field theories such as QED and QCD (which come naturally with massless vector fields) or any field theory that admits a quantum BRST complex[*]
[*] A quantum BRST complex is a triple \left( \mathcal{V} , Q , N \right) consisting of a vector space \mathcal{V} (with non-degenerate norm) graded by the eigen-spaces of an anti-self-adjoint operator N (the ghost number operator) with integer eigenvalues \mathcal{V} = \bigoplus_{c \in \mathbb{Z}} \mathcal{V}_{c}; and a non-trivial self-adjoint operator Q (the BRST charge operator) which has a degree 1 with respect to the grading and satisfies Q^{2} = 0.
It is clear that for the BRST charge Q to be non-trivial, the norm of \mathcal{V} must be indefinite. Otherwise \forall \varphi \in \mathcal{V}, \lVert Q \varphi \rVert^{2} = \langle Q \varphi , Q \varphi \rangle = \langle \varphi , Q^{2} \varphi \rangle = 0 , and hence Q would vanish identically. Thus \mathcal{V} must contain zero-norm vectors. But because the norm is non-degenerate, \mathcal{V} must also have negative norm vectors. Thus, indefinite-metric spaces are inherent to BRST quantization.
Likes vanhees71, weirdoguy and dextercioby
  • #45
Corrected.
You didn't say this before; it is a nonstandard usage of the term. If QFT were generally understood in your sense, Volume 1 of Weiberg's treatise on QFT would have missed almost totally its declared subject matter...
  • #46
I didn’t have to, because the whole of #37 was about the covariant quantization of the massless vector field A_{\mu}(x). I wouldn’t use the term “covariant formalism” if my QFT was that of massless scalars or spinors which I did not even mention in #37.
  • #47
samalkhaiat said:
... But, for a massless vector field, it is impossible to avoid negative norms without violating manifest Lorentz covariance. ... In other words, the reason for the presence of negative norms is mathematical and has nothing to do with the field content of the theory. Indeed, given a massless vector field A_{\mu}(x) together with the Poincare algebra, one can prove (without using any field equations or Lagrangians) the impossibility of covariantly quantizing A_{\mu} in the positive-metric Hilbert space. ... In short, indefinite-metric Hilbert (Krein) space is indispensable in the covariant formalism of QFT.
Sorry, but the decision to require manifest Lorentz covariance is nothing forced on us by mathematics, and also not forced on us by something physical - for physics, all one needs is covariance of the observable predictions, which is much less than manifest Lorentz covariance. It is a purely metaphysical decision to prefer such a theory.
