How to Solve Part (b) of the Water Pressure Problem?
  • Thread starter Thread starter MrInventive
The discussion focuses on solving part (b) of a water pressure problem involving a tank of water and a pipe. To determine how high the water could shoot from a broken pipe, the Bernoulli equation must be applied at the surface of the tank and at the opening of the pipe. The pressure calculated in part (a) is not applicable for this scenario, as the liquid is in motion, which necessitates a different approach. The key takeaway is that using the static pressure formula, ##\Delta P = \rho g h##, will lead to inaccuracies in this context.
  • Understanding of the Bernoulli equation
  • Knowledge of fluid dynamics principles
  • Familiarity with pressure calculations in flowing fluids
  • Basic trigonometry for analyzing angles in pipe orientation
  • Study the application of the Bernoulli equation in fluid dynamics
  • Learn about the concept of gauge pressure and its implications
  • Explore the relationship between pressure, height, and velocity in fluid flow
  • Investigate real-world applications of fluid dynamics in plumbing systems
Students studying fluid mechanics, engineers working on hydraulic systems, and anyone interested in solving practical water pressure problems.
MrInventive
A house at the bottom of a hill is fed by a full tank of water 6.0 m deep and connected to the house by a pipe that is 75 m long at an angle of 61° from the horizontal (figure below). (a) Determine the water gauge pressure at the house. (b) How high could the water shoot if it came vertically out of a broken pipe in front of the house?
P = pgh
I was able to answer the first portion of the equation
I don't know how to go about answering (b)
here's my work--^
For (b) you'll need to use the Bernoulli equation, applying it at the surface of the tank of water and at the opening of the hole in the pipe.
Note that the pressure you calculated in (a) won't help you here, since ##\Delta P = \rho g h## doesn't apply if the liquid is flowing/not at rest! Using it will make you a factor of ##\sqrt{2}## out...
MrInventive said:
Homework Statement:: A house at the bottom of a hill is fed by a full tank of water 6.0 m deep and connected to the house by a pipe that is 75 m long at an angle of 61° from the horizontal (figure below). (a) Determine the water gauge pressure at the house. (b) How high could the water shoot if it came vertically out of a broken pipe in front of the house?
Relevant Equations:: P = pgh
here's my work--^
What are your thoughts on (b) so far?
