What is the Electric Field in a Cylindrical Sheath?
The problem involves calculating the electric field in a non-conducting, infinitely long cylindrical sheath with specified inner and outer radii and a uniform charge density. The specific points of interest for the electric field are at radii of 5 m, 12 m, and 17 m.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to apply Gauss's law but is uncertain about how to calculate the enclosed charge (Q) for different radii. Some participants suggest calculating the volume of the sheath for the relevant sections to determine Q.
Participants are actively discussing the approach to finding the electric field at the specified radii. Some guidance has been provided regarding the calculation of charge based on the volume of the sheath, but there is still uncertainty regarding the application of these concepts for the radius of 12 m.
The problem is constrained by the defined inner and outer radii of the sheath, and participants are exploring how to handle the regions outside and within the sheath when applying Gauss's law.
abcdmichelle
A non-conducting, infinitely long, cylindrical sheath has inner radius r=10 m, outer radius r=15 m and a uniform charge density of 9 nC/m^3 spread throughout the sheath. Magnitude of electric field at r=5, r=12, r=17?
Q=rho(Volume) and phi=EA therefore phi=E(2pi(R)length)
phi=Q/epsilon_0
At r=5, Electric field=0
At r=12, phi=Q/epsilon_0, so E(2pi(R)length)=Q/epsilon_0
I just don't know what Q will be.
The same for r=17, I don't know how to find Q.
You are given the charge density. Figure out the volume of sheath enclosed in each case.
Thank you Doc Al!
So for r=17, if R is the outer radius of the sheath, then
Q=rho(length)piR^2, so E=(rho(length)piR^2)/(2pi(length)r(epsilon_o), thus
E=(rhoR^2)/(2r(epsilon_o))
is that correct, where i would use r=17 and R=15??
I still don't know how I would figure out E for r=12, the area IN the sheath.
Please help! :)
abcdmichelle said:
Thank you Doc Al!
Please help! :)
The sheath only starts at r = 10m and extends to r = 15m. So to find the charge contained in a Gaussian surface with radius 12m, you need the volume of the sheath from r = 10 to 12 m. Similarly, for r = 17 you'd use the entire sheath, so from r = 10 to 15 m.
Hint: To find the volume between r1 and r2, find the volume of each full cylinder and subtract.
Thank you very very much Doc Al! This makes so much sense!
  • · Replies 16 ·
