Gauss' Theorem - Divergence Theorem for Sphere
7 replies · 2K views
FaraDazed
Using the fact that [itex]\nabla \cdot r^3 \vec{r} = 6 r^2[/itex] (where [itex]\vec{F(\vec{r})} = r^3 \vec{r}[/itex]) where S is the surface of a sphere of radius R centred at the origin.
[tex] \int \int \int_V \nabla \cdot \vec{F} dV =\int \int_S \vec{F} \cdot d \vec{S}[/tex]
That is meant to be a double surface integral but not sure how to do that in latex
Very new to this, so be kind :)
for the LHS
[tex] \int \int \int_V \nabla \cdot \vec{F} dV = 6 \int \int \int_V r^2 dV \\<br /> = 6 \int_0^R r^2 r^2 dr \int_0^{2 \pi} d\phi \int_0^{\pi} \sin{\theta} d\theta \\<br /> = 6 [\frac{1}{5}r^5]_0^R [\phi]_0^{\pi} [\cos{\theta}]_0^{2 \pi} \\<br /> = 6(\frac{1}{5} R^5) (2 \pi ) (2) = \frac{24}{5} \pi R^5[/tex]
for the RHS
[tex] \int \int_S \vec{F} \cdot d\vec{S} = \int \int_S r^3 \vec{r} \cdot d \vec{S} = \int \int_S r^3 \vec{r} \cdot \vec{\hat{n}} dS \\[/tex]
Then I calc [itex]r^3 \vec{r} \cdot \vec{\hat{n}}[/itex]
[tex] r^3 \vec{r} \cdot \vec{\hat{n}} = r^3 \vec{r} \cdot \frac{r^3 \vec{r}}{r^3 r} = \frac{r^2 r^3}{r} = r^4[/tex]
so...
[tex] \int \int_S r^3 \vec{r} \cdot \vec{\hat{n}} dS = \int \int_S r^4 dS \\<br /> = \int_0^{2 \pi} d \phi \int_0^{\pi} R^4 R^2 \sin{\theta} d \theta \\<br /> = R^6 [\phi]_0^{2 \pi} [\cos{\theta}]_0^{\pi} = 4 \pi R^6[/tex]
Well, for starters, I don't think that ## \nabla \cdot r^3 \mathbf{r} = 6r^2 ##.
That is a given though, it is part of the question. It says, "given that ## \nabla \cdot r^3 \mathbf{r} = 6r^2 ## ..."
I am assuming that the vector r=(x,y,z) as that is what is used throughout the coursework.
First, note that, if ## r ## has the dimension of length (##L##), then ##r^3 \mathbf{r} ## must have the dimension of ## L^4 ##. But the derivative has the dimension of ## 1 / L ##, so the result must have the dimension of ## L^3 ##, not ## L^2 ##. Second, you can just calculate it. Hint: Write ## r^3 \mathbf{r}## as ##r^3(x\mathbf{i} + y \mathbf{j} + z\mathbf{k}) ## and note that, for example, ## \frac{\partial r}{\partial x} = \frac{x}{r} ##.
EDIT: Yes I have just calculated it, and i do get [itex]6r^3[/itex]!
Even the greatest books have been known to contain errors. Besides, if you do the problem with the correct value of ## \nabla \cdot \mathbf{F} ##, everything works out the way it's supposed to.
Yes, see my edit above. I get [itex[6r^3[/itex] ! Haha. My lecturer may have told us about the error, but if he did, I was either not there or didnt hear it! haha
Thanks!
Yes I can see now that the LHS would also equal [itex]4 \pi R^6[/itex] when using the correct value for the divergence of F. No wonder they were not equal to each other! I should have realized the mistake myself to be fair, but this was my first actual problem using Gauss' Theorem, thanks for your help.
