General Centre of mass derivation
2 replies · 2K views
shaggySS
Hello,
It's my first question here. So I'll try to give as much as information as I know
Actually I am stuck with a problem of centre of mass derivation of a triangle with its base on the X axis and symmetric about it.
The base is b and height is H
As far as I know I have to imagine it as a couple of 1d bodies and integrate them.
Thanks
SAGNIK
Since its symmetric about the X axis the y coordinate needs to be found only.
The y- coordinate of the center of gravity of an object with density function [itex]\delta(x,y)[/itex] is
[tex]\frac{\int y \delta(x,y) dxdy}{\int \delta(x, y) dxdy}[/tex]
In particular, if [tex]\delta[/tex] is a constant, it can be factored out of the two integrals and cancelled- that is the "center of gravity" is just the
geometrical "centroid". Here, we can set up a coordinate system so that the origin is at the center of the base of the isosceles triangle, base
along the x- axis, height along the y-axis. The equations of the two slant sides can easily be determined.
